Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Clearing paper jam - HP Officejet Pro L7780 All-In-One InkJet Printer
  • 3 more comments
  • Laurens111 Apr 28, 2008
    Paper fed off try into the unit and rolled itself tightly around the roller inside, and there's no way to get access to the paper to pull it out.
  • monkeesmommy Jul 07, 2008
    i was printing a 8 x 11 and i put in a stack of 4 x 6 paper so the 4 x 6 paper is stuck inside, the whole stack ...... and so is the 8 x 11 it is half out.
  • Anonymous Oct 01, 2008
    i just printed regular paper and this is the second time that the paper has been jammed!! the directions on the screen tell me to remove the back of the printer...but the instructions don't even work! the paper is stuck in the middle of the printer...i have no idea how to get it out!!!
  • Anonymous Nov 14, 2008
    I put in a stack of about 15 typing paper, as usual. When I went to scan and print, it fed the entire stack into the printer! I can't see a way to open the back to remove it, so I carefully pulled it out from the front, and now the front green lights blinks and nothing else happens. How do I clear future paper jams, why did this happen, and what can I do to make this work again? Kate
  • ljcprague Nov 19, 2008
    Me, too.
To get a paper jam that can't come out of the back place your hand under the front panel and lift up both the scanner lid and the scanner base. This is where there is access to the ink cartridges. You can move the print head over to the right and pull out the paper.
Posted on Dec 01, 2008
On a HP photosmart 7960, for instance, there is on the back of the printer a large door than you can easily open by using the simple locking mechanism the door has. From there you should be able to reach any jammed paper.
Hope it helps.
Posted on Oct 20, 2008
There is access from the back of the unit. I accidentally found this out as there is nothing in the reference guide or even HP.Com that talks about it.
Posted on Jun 06, 2008
Remove paper jam
you MUST get the tiny paper out of the machine. It will make more jams for sure. If you do not have a manual or someone handy try looking up your printer model on the web for jam clearing advice at the location where the paper ripped. Usually there are numbers. Sorry!
Feb 20, 2015 | Office Equipment & Supplies
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Paper jam
Dear sir,
i am giving u setp to solved your problem,
Step one: Remove any loose paper.
Step two: Clear the jam from the back of the All-in-One
Step three: Clear the paper jam from the front of the All-in-One Step four: Clear the jam from the automatic document feeder Step five: Print a self-test report Thanks For Your Time,
Apr 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Clear paper jam
may be there is small pice of paper inside just remove that.
Jan 20, 2010 | Canon FAX JX200 - Fax / copier - ink-jet...
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam
Solution one: Clear the jam from the back of the All-in-One Follow these steps to clear a paper jam from the back of the product. Step one: Remove any loose paper Remove any loose paper from the input tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back CAUTION: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the product slowly and gently. Avoid touching the internal components of the product.
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear door. Push in the two release tabs, and then pull the door toward you.
Feb 01, 2009 | Lexmark P6250 All-In-One InkJet Photo...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
227 people viewed this question
Ben Johnson
