Question about Dryers
Maytag de8410 new power cord installation. the cord is not color coded so I do not want to wire this product incorrectly.
    Genius:
  • 1,073 Answers
Black on the left screw white on the middle screw red on the right screw and green to frame ground
Posted on Apr 23, 2008
Since moving the light will come on in the tumbler but the power won't turn on. Any idea what the problem is?
If you installed the power cord I am guessing this is a 240 volt electric dryer. Electric dryer terminal blocks have 3 screws in a straight line. The center is neutral with a hot line on each side. The hot lines don't matter which is on the right or left. Now if you have the big flat power cord, the 3 wires are already in line for you. the center is neutral and the 2 hot lines are on the outsides. Install all wire in a straight line. If you have a big round power cord it may have 4 wires inside that are usually color coded. White is Neutral (center screw). green is a secondary ground and can be attached to any screw going into the dryer body. That should leave 2 more wires--red and black, These are your hot lines. put one color on each side of the neutral screw. Doesn't matter if red is on right and black on left side or if you reverse those 2 colors. It should still work properly.
May 11, 2015 | Dryers
Tip
3-prong to 4-prong Power Cord Conversion.
This advice is on how to correctly install an ELECTRIC DRYER or ELECTRIC RANGE 220-240VAC power cord (US Standards).
3-Prong or 4-Prong – The Difference:
3-prong color code:
BLACK (HOT – 110-120VAC) – May also be referred to as L1
RED (HOT – 110-120VAC) – May also be referred to as L2
WHITE (NEUTRAL – 0VAC) – Usually grounded to the equipment frame via a jumper wire or metal strap.
4-prong color code:
WHITE (NEUTRAL – 0VAC) – DO NOT ground to equipment frame.
GREEN (GROUND) – Attach to equipment frame.
Which One to Use: According to the National Electrical Code (NEC), Article 250, installations after the year 2000, require the use of a 4-prong plug which incorporates a separate ground and neutral wire. If you currently have a home that uses the 3-prong receptacle and cord, you can continue to use it. You will have to upgrade to a 4-prong configuration, however, if you plan on relocating your current receptacle, or if the internal wires of the receptacle become damaged in any way and require repair.
Converting from 3-prong to 4-prong: Make sure you UNPLUG the appliance prior to any repairs. CAUTION: Voltages dangerous to life are still present even with the appliance turned off and still plugged in. Notably in the area of the terminal block where the power cords are installed. You will need to remove the old cord by following these steps:
  1. With the appliance UNPLUGGED, remove the access panel on the back of the unit where the power cord enters.
  2. With the cover removed, you will see a terminal block where the power cord is attached. The terminal wires will be colored with the WHITE wire in the middle, and the BLACK and RED wires on either end. NOTE: There should be a green jumper wire or metal bonding strap attached to the NEUTRAL (white) terminal wire.
  3. Remove the terminal lugs holding the old power cord wires in place. CAUTION: Use care not to drop any nuts or screws inside the appliance.
  4. Remove the bonding strap or ground wire from the Neutral terminal lug. NOTE: If disconnecting a ground wire, make sure you re-attach it to the appliance frame.
  5. Loosen the screws on the strain relief connector that holds the power cord in place and remove old power cord. NOTE: If your appliance does not have a strain relief that clamps down and hold the power cord in place, it is highly recommended that you install one. This prevents chaffing of the power cord against the appliance casing, and prevents the terminal wires from being pulled and broken loose. This could pose a potential shock hazard or cause damage to the appliance.
  6. Install new power cord by threading it through the strain relief connector and tighten down the screws.
  7. Connect the new power cord to the corresponding colors at the terminal block (Black goes to Black, Red goes to Red, White goes to White). The difference is going to be a Green (ground) wire that will connect to the appliance frame. There’s usually a green grounding screw for this. NOTE: If you disconnected a green grounding strap in Step 4., you can connect these two wires at the same point.
  8. Re-install access cover. Turn off the service breaker to the appliance PRIOR to plugging it back in. With the breaker in the off position, plug the appliance in, and THEN turn the breaker on. In the event, something was wired incorrectly, it is far better to have your hands away from the receptacle and controlled from a distance. Safety first.
on Jul 16, 2008 | Whirlpool LER5636P Electric Dryer
I HAVE A MAYTAG LAGACY AND IS TO HOT , TWO DAYS EGO I CHANGE THE CABLE OF THREE FOR ONE OF 4 AND THE RED CABLE IS IN THE RED CABLE OF THE DRYER AND THE BLACK CABLE IS THE BLACK CABLE OF THE DRYER THIS CAN...
Double check your power cord installation. The following link explains in detial how a power cord is to be installed and the differences between the 3 and 4 wire configurations:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
There is a difference in how the power cords are installed. Pay particular attention to how you have the ground and neutral wires terminated. If installed incorrectly, the dryer may not run, you could damage the appliance, or you could create an electric shock hazard. If you have questions, please post back and let me know. I hope this helps you.
Mar 14, 2011 | Maytag Dryers
How do i hook up a different electrical cord on a maytag LDE712
The following link explains how to correctly install a power cord to your dryer:
There is a difference in how to terminate the connections on a 3-prong and a 4-prong power cord. Pay particular attention to this and make sure you match the corresponding wires correctly. If your wires are not color coded, the outer two wires on the power cord (left and right) are the HOT leads. The center conductor is the neutral.
If you have any questions about this repair, please post back and let me know. I hop this helps you.
Mar 29, 2010 | Dryers
Maytag electrical dryer model # PAV2300AWW power supply layout
The following link explains how to properly connect the power cord to your dryer:
Pay particular attention to WHICH configuration you have. Your power cord will either be a 3-wire or 4-wire configuration. NOTE: If the wires are not color coded, the outer two wires (left and right) will be the HOT leads. The center conductor is the neutral.
If you're new home is equipped with a 4-wire outlet, you are required to update the dryer to a 4-prong power cord to be in compliance with the National Electic Code.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 27, 2010 | Maytag PYE2300AY Electric Dryer
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
Switching to a 3 wire plug from a 4 wire plug for maytag dryer. what do i do with green ground screw
3-prong color code:
4-prong color code:
These steps will work for nearly all appliances that require a 220-240VAC power cord conversion. The power cords are usually rated at 250VAC, 30 amps, and are carried by any hardware store or appliance parts retailer.
ADDITIONAL NOTES:
  1. If you desire to convert an appliance from a 4-prong to a 3-prong, make sure you reconnect the bonding strap and/or ground wire to the Neutral (white) wire at the terminal block.
  2. On some newer appliances, it is REQUIRED that you use a 4-prong plug in order for the timer or clock circuits to function properly due to the way they are configured. Refer to your owner’s manual for the correct recommendation. Even if you currently have a 3-prong receptacle, you still may be required to upgrade to a 4-prong if you encounter this situation.
  3. In many circumstances, new appliances are NOT sold with the power cord due to the various power configurations in homes. Always refer to the contents description on the shipping container the appliance comes with to see what additional items or tools may be required for installation.
Aug 03, 2009 | Maytag Dryers
New Wire Not Color-Coded
when you line up the new cord have the cord point down and the cord is ok to install. either of the outside wires go to outside terminals . th important thing is to get the middle wire to the center terminal
Dec 29, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Power cord connection on back of maytag dryer model LDE8416ACE is not color identified in order to install a 4 cord power line.
center is always neutral ..white on cord or center wire on 3 wire cord other 2 are hot but doesn't matter red or black on cord will work
Jun 30, 2008 | Maytag Dryers
Dryers Logo
89 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
