Question about Compaq Presario 5000 PC Desktop
Computer keeps rebooting
I have a Compaq Presario, for awhile now it keeps rebooting after I use it for a little while. I downloaded speedfan fan1 1713 RPM Temp 46C fan2 0 RPM Temp 82C HD0 37C. I have cleand out the dust and it continues to do this. Any help?Thanks
  • Donna Nov 24, 2008
    Replaced power supply still doing it
    Problem Solver:
  • 6 Answers
Easy one...try replacing the power supply
Posted on Apr 24, 2008
No power on will shutdown
Hello
First of all press ALT+CTRL+DEL and start Task Manager, there is probably some application (or other process) that is not reponding. You can kill them to let the shutdown continue, and know what is causing the problem and maybe find an update for it.
Also this means that your computer has not been rebooted properly since the installation of important system updates. If you have "Automatic Updates" scheduled on your machine, these updates could have downloaded and installed without your knowledge. To fix this issue, let the updates finish installing, reboot and then shut down your computer as normal.
Click "Start."
Click "Windows Update." Click "Install Updates" to begin the installation of any updates that have been downloaded to your Compaq Presario. When the "Restart Now" button becomes available, click it once. Your Compaq Presario will shut down Windows, finish installing the updates and then reboot your computer.
Click "Shut Down." Because the updates have finished installing and have been installed properly, your Compaq Presario will now shut down normally and will not immediately boot back up.
Feb 17, 2011 | Compaq Presario 700 470024-192 Notebook
My compaq presario v2000 often shuts down unexpectedly
Hi. Thanks for your question.
My first guess would be that your laptop is overheating. To confirm this you could download program called speedfan using this link http://download.cnet.com/SpeedFan/3000-2094_4-10067444.html please click donwload and once downloaded install on your computer.
Once you have this program you can monitor your computers temperatures and see if they're rising before laptop shuts down.
Laptops often overheat while being used on beds, carpets or any not flat solid surface. This causes air vent at the bottom of laptop to be blocked. That vent is crucial for laptops cooling. The other reason for laptop overheating could be dust and dirt that clogged any visible vents. Removing dust is fairly easy and can be done with little paint brush and can of compressed air which can be bought from any computer shop and some supermarkets.
I hope this helped you to understand your problem better. Please do not hesitate to ask more questions if this is needed. Thank You for using FixYa
Dec 08, 2010 | HP Compaq Presario V2000 Notebook
My audio is not working on compaq presario c700
Go to the Compaq website and download the latest drivers for the computer.Uninstall the present drivers .Reboot and reinstall the drivers you downloaded this should take care of the problem.
good luck
Oct 31, 2009 | Compaq Presario 700 470024-192 Notebook
My compaq presario C700 model #C765TU easily gets hot and is crashing
Make sure that there is no dust in the Fans of teh unit. The Compaq's are famous for overheats.
Download a program called SpeedFan available from
www.almico.com/speedfan.php
once you donwload the file install it, it will put the computer's temp in your system tray by the clock
Try and watch the temp and see what its at when the computer shuts down.
If it is an older unit your processor will most likley need to have heat paste applied to the processor.
You can call your local repair shop, some will do it for about 25.00... Make sure that when you use the machine that you provide enough room for the fans to breath, do not set the laptop on a couch, or bed where the heat cannot escape.
Also check to see that the fans on the bottom of the machine are running. they sometimes fail, however you should receive notification of this on the POST when your computer starts.
Hope this helps
May 26, 2009 | Compaq Presario 700 470024-192 Notebook
Remove and re-seat the memory. if this is not helpful, do not rate me.
Apr 25, 2008 | Computers & Internet
Compaq Presario 5000 PC Desktop Logo
76 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
