Question about Refrigerators
Fridgefreezer makes clicking noise
  • 3 more comments
  • charleyboyd Sep 20, 2008
    makes a clicking noise
  • davidinsd Sep 21, 2008
    I have the same problem. Mine is making a clicking or beeping noise that is constant and will not stop. Also noticed that the LED temp lights on the front of it are off and it doesn't seem to be cooling....
  • lynda withem Oct 28, 2008
    I have this problem also, when you open the door when refrigerator making this noise the inside light is blinking on and off.
  • Anonymous Mar 03, 2009
    Our freezer makes a rhythmic "ta ta ta ..tick tick tick" noise
  • Anonymous May 09, 2009
    At first, the ice dispenser worked off and on and then clicking noises started off and on. When the noise was going, water would dispense in spurts. Now ice dispenser has stopped completely and clicking still comes and goes. If I turn the ice maker off, it stops. When I need ice, I turn it back on and the refrigerator gets cooler. Last night my juice bars were mushy. I thought the refrigerator was defrosting. Today it was warm and I knew it was basically dead. I turned the ice maker on, removed the ice holder that had partially defrosted ice and could see the fan trying to turn and barely heard the clicking and the fan turned a quarter of a turn with each click.
    I at first thought it might be a relay because of the ice dispenser but did not do anythoing about it. Today I tried to remove the fan but after practically dismantling the freezer portion, I can't get just the fan out to take for testing. There was a lot of ice on the "fins" also. I don't know if that affected anything. I know I need to pull the unit out and clean the coils. I don't know if that is the problem either. If anyone can shed some light, it would be greatly appreciated. Thanks, Beverly
Back too near wall. i vacumed vent at back
Posted on Apr 29, 2008
My kenmore refrigerator has just recently started clicking CONSTANTLY. What could be the problem? It is not very old.
Ariston fridge/freeser BCB31AA
Call out the warranty supplier. Where is the noise coming from? If no warranty, check the electrics to the compressor and fan. sometimes the noise is the fan. Also switch off overnight and leave doors open. When restarting, if the noise has gone it will have been the internal fan hitting on ice buildup.
Mar 25, 2014 | Freezers
Tip
Samsung fridgefreezer troubleshooting
hello and thanks for checking out my samsung fridgefreezer trouble shooting section ..<br /> <br /> most of the appliance,s i deal with are made for europe but they seem to be sold worldwide under a different model - so hopefully the info i can give out will apply to most models ? ..<br /> <br /> probally the best way for you to find out about common problems on samsung fridge freezers is to have a look at some of these videos on youtube ..<br /> <br /> samsung fridgefreezer channel /...<br /> <br /><utube src="RP9XLji-gdw"><br /><br />rsh1 model video below<br /> <br /><utube src="wLFcmJEGJMs">(do not delete) </i></b><img src="utube.png" /> <br /> rs21 model video below <br /> <br /><utube src="7xEBoJRBD5Y">(do not delete) </i></b><img src="utube.png" /> <br /> rs21 ice maker fault video below <br /> <br /><utube src="R-va_Siu3zw"><br /> feedback for customer who have received help <br /> <br /><utube src="TGIrwv3xkWg"><br /> hope these videos are able to shed some light on whats causing your samsung fridgefreezer problem..
on Dec 02, 2010 | Refrigerators
Hotpoint quadrio fridgefreezer 2 years old ,not cooling and not freezing,motor was running but has now also stopped,someone surgested moduel was broke any surgestions
These types of refrigerators usually have cooling issues related to defective defrost heaters and failed evaporator fans. I don't believe the compressor has failed. The compressor has a run capacitor and a separate klixon, contact, and fuse attached to the compressor shell that has a tendency of failing. I would check that. It usually makes a clicking sound, but the compressor will not start.
Aug 30, 2013 | Refrigerators
How long should a logik fridgefreezer last
try listing in major appliance area--this is tv area.
Aug 24, 2012 | Televison & Video
Whirlpool tropical fridgefreezer making clicking noise and getting heat from top freezer
Hi, you will need to post this to the FixYa Fridge/freezer forum as this is the washing machine one, sorry ;-0( John C
Oct 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I bought my samsung rsa1wtmh fridge/frezer over two years ago and it has been troublefree for all that time. Over the past two days it has now developed what I can only describe as a motor noise behind the...
YOU MORE THAN LIKLEY HAVE A OVER FROST PROBLEM
ie freezer has made to much ice , you probaly will only need to switch off for 24 hours to let excess ice to defrost ....
click here for
samsung fridgefreezer problems
also have alook at .......
rsa model really only developes this type of problem , which as i said can be easily sorted by allowing appliance to defrost ...">
Oct 22, 2010 | Kitchen Ranges
Wate light onfront of rangemaster sxs fridgefreezer turned red
After you have changed the filter, select water then hold the select button down and it will go blue again.
Jul 08, 2010 | GE PDS22LBN Bottom Freezer French Door...
Noisy high pitched noise from fridgefreezer fan despite being replaced
The insulation in these units is taped in place. This will slip and rub the fan. That is what usually causes this noise. The inner back panel comes out fairly easily by removing the screws and then the panel. Simply re-tape the insulation with a strong bonding tape and give it a try. Hope this helps. Good luck.
Dec 08, 2009 | Fisher and Paykel Active Smart E522B...
Haier Model No. HSA04WNC WW/BPG fridgefreezer loud rumbling noise
Rumbling sound is not good. Check to see if it is making the noise with the door open. If so - it probably is a fan blade scraping. If it keeps making the noise - it is likely the compressor - either a faulty relay or capacitor. Or maybe the compressor is faulty. You'll need to be handy with a multimeter to check these out though.
May 30, 2017 | Haier HSA04WNC Compact Refrigerator
Refrigerators Logo
618 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
