Question about JVC AV-32120 32" TV
In mute operation: Want to read what is being said
What settings do I need to set in order to be able to read what is being said when I mute sound using the remote? Where do I get an owners manual? Thanks, Ed
  • Wylie777 May 23, 2008
    I had tried this suggestion earlier without results. I also changed the text and received the big black box as mentioned. Thanks for trying to help, I apprecidat it.
  • 100 Answers
Hi Wylie77,
The feature you are looking for would is called CC or Closed Captioning. Per your owners manual you would press the menu button, then move up and down to select "CLOSED CAPTION" from the list. Then to edit the feature press left or right. Select CAPTION to on. The manual lists four different types of captioning (C1-C4) and also four different types of "Text" (T1-T4). Usually one of the caption listings will display only when the mute is selected...its just not very clear which one exactly will do it.
One word of warning, you would not want to activate the Text features. This will sometimes have a large black box appear in the middle of your screen providing other information.
Unfortunately JVC does not have a link to your manual on their website, but the manual should be able to be found by entering JVC AV-32120 Manual in a search engine. I would check a few of the results because some maybe free others may ask for a "nominal" fee.
Hope this helps.
Go Ahead. Use Us.
Posted on Apr 22, 2008
Why do i hear no sound from the tv
Most often caused by a mute circuit or the mute button pressed. Others are a wrong sound setting. Such as being set for Dolby Digital sound.
Oct 16, 2014 | Vizio L32 32 in. LCD HDTV
I have voice, but no sound
Plug the USB connector into an available USB port.
• Check your computer's volume level.
• Check if your computer's volume is muted.
• Check your operating system's audio input and output settings.
• Check the headset's volume and mute settings.
• Restart computer.
May 11, 2012 | Dynex DX-840 Headset
The sound is distant?
• Restart computer.
May 04, 2012 | Dynex Radio Communications
No sound only the speaker is good
I would make sure the sound on the computer isn't mute and everything is connected correctly. You can test the sound in "Start, Control Panel, and, Sounds and Audio Devices" Here is where you can check it the sound has been mute and you can check the settings. Hope this was helpful.
Apr 17, 2011 | Computers & Internet
No alarm clock sound
The alarm volume is muted by default, and every now and then, it will reset itself to mute. I haven't figured out what causes it to reset (possibly reboots?).
Anyway, in order to set your alarm volume, you will need to get to the list of alarm sounds. From this list, you can adjust the volume of your alarms using the volume rocker on the left side of the phone.
There is no other place to set your alarm volume.
Good luck.
Mar 08, 2010 | HTC Hero Smartphone
Can not get audio working on hp2159m
Has sound been working in the past? If so - it's possibly a hardware issue but not always.I'll presume you're using Windows XP as the operating system.
Check these in the following order:
1. Check that windows volume is not muted. Depending on version of Windows, you may have a volume icon in the bottom right hand corner - it looks like a speaker - and if muted there will be a red circle over it.
2. Go to Windows Control Panel and Sound and Audio Devices settings.Check all volume are maximum.
3. Check that the right device is being used to output the sound by checking in Control Panel > Sound and Audio Devices > Audio tab. There are drop down lists. Check that Default Device is your soundcard (usually something like Soundblaster or similar.
4. It could be your Windows sound drivers. You need to go to HP website and look around for drivers.
5. Hope this helps and please report back how it goes...
Nov 20, 2009 | HP 2159M Monitor
Sharp MX-3501N ---- My copy machine you can hear sending out the fax, it dials and then sends and then beeps really loud. Is there any way to shut the sound off so we don't hear the fax go through?
There's a Key Operator setting for muting the fax speaker. Press the 'system settings' button, then the Key Operator button to enter the access code to the key operator settings (default is all zeros),
Find the Fax settings button and then the fax default. The option to mute the speaker should be within the speaker volume settings.
Aug 18, 2009 | Sharp Office Equipment & Supplies
My mute does not work
You will have to isolate the problem. HDTV, remote unit, infrared receiver in set.
Operate the mute from the buttons on the set to see if it works.
If it works then the problem is probably in the the remote unit since the infrared unit on the set is receiving other commands from the remote unit.
If it does not works then the problem is in the TV set.
(This is a better problem than having the mute on all the time.)
Feb 19, 2009 | Vizio L37 Television
1)double click on the speaker icon and see if it is muted.
2)Try another mic to see if it is the mic
3) go to control panel>system>hardware>device manager>sound device and make sure there are no X's or !'s on any component of your sound card if there is read what the problem is or reinsstall the driver.
May 28, 2008 | Asrock 775VM800 Motherboard
JVC AV-32120 32" TV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
