Question about Vizio L32 32 in. LCD HDTV
Vizio liquid crystal tv l32hdtv
When i switch over to av2 input my tv picture turns into lime green tint and when i play my vcr, it plays the tape in lime green tint. I tried to adjust colors did not help. tv about 18 months old. Tv works fine in digital hd mode and in dvd mode. please help thank you
  • 1 more comment
  • hotrod3 Apr 25, 2008
    tried doing that, all av 1, 2, 3 inputs are green, switched cables, changed vcr and dvd as well as ps2, outcome is still green
  • travisrobert Jan 15, 2009
    I have a cable box hooked up to my 32" VIZIO LCD HDTV, along with a Samsung VCR/DVD combo. When I switch to AV2 and activate the VCR, I have picture but no sound. I have been doing this for awhile now...any help?
  • Anonymous Mar 30, 2014
    neck and clothing blurred
  • 124 Answers
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Posted on Apr 24, 2008
  • Jeffrey Johnston
    Jeffrey Johnston Apr 26, 2008
    It is definitely a TV problem with the AV2 input and a trip to the repair shop, I'm afraid.
How do I get the DVD to record what is on the VHS tape not the TV?
You can record from an external component, such as a camcorder or VCR, connected to any of the Recorder's external inputs.
1. Make sure that the component you want to record from is connected properly to the Recorder. See page 14.
2. Press AUX repeatedly to select the external input to record from.
• AV1: Audio/Video Input mounted on back panel.
• AV2: Audio/Video Input mounted on front panel.
• DV: DV Input mounted on front panel.
page 37 from manual:
http://resources.jvc.com/Resources/00/01/15/LVT2016-001B.pdf
If this fails, try to disconnect the tv input cable and connect the vcr cable.
Feb 04, 2016 | JVC DR-MV150B DVD Recorder/VCR
Why GE TV plays color DVD/VCR tapes in black and white
Some inputs on tvs won't process the color signal. Try one of the other inputs. Mine does the same. If u have already used the working ones on something else, U will need a switch to select one or the other available at Radio Shack if u can find one.
Jan 22, 2018 | GE Televison & Video
How do u turn to scart channel without a remote
Not knowing what model of TV you have, the most common ways are either by using the Source button then scroll to AV1 input or if you have a Menu button there may be a sub-menu for Input, again select AV1 (depending on which AV connector you are linked you maight have to select AV2). If you have a DVD or VCR connected to the AV source, then when pressing play the DVD/Tape should automatically switch over to AV.
Jul 08, 2009 | Televison & Video
Magnavox zv427mg9 sound problem - VCR/DVD combo connected to a Vizio VW42LFHD TV. After some playing around we got the DVD running OK. We can see video and hear the audio. However, the VCR does not play...
sr you can disconect hdmi cable and use a litle speaker and check for audio in rca cables output , when you put your vcr play you can have audio in rca red cable and rca white cable i think when you put hdmi your loose in rca the audio , remember in hdmi you have audio and video , if you dont have audio in vcr the audio head are bad thias is used only in vcr mode. good luck
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
Need codes for proscan to put in direct tv remote
phone_header_def.png saveupto_a.png phone_callnow_def.png DIRECTV Specials DIRECTV Packages DIRECTV Receivers DIRECTV DVR DIRECTV HD DIRECTV vs. Cable DIRECTV vs. Dish DIRECTV Sports Home > Remote Codes DIRECTV Remote Codes remote_codes_header.jpg TV CODES VCR CODES DVD CODES STEREO RECEIVER CODES
STEREO AMPLIFIER CODES DIRECTV RECEIVER CODES
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
May 06, 2009 | Proscan 32LA30Q Television
There green tint in my picture on all my connections on vizio 47
Try shielded video cables and make sure you have your cables hooked up correctly. Sometimes you can conect them wrong, specially the red one. If you are using componet in on your tv, make sure the red one is not connected to your audio. The green tint is because you are missing red in your picture.
Mar 16, 2009 | Vizio VO47L 47 in. LCD TV
Rca tru flat tv has a red picture
Is your video input (from cable or satellite or fiber optic, etc.) coming from a coaxial cable, a component cable (red, green, and blue connectors), or an RCA cable (yellow connector for video)?
If you can, try an alternate input method and see if that makes a difference. Does it happen when watching DVDs or tapes, or when playing video games, or just when watching television?
Mar 13, 2009 | RCA TruFlat 27F520T 27" TV
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Blue screen
At least a couple of possibilities, check the yellow video cable that runs from the VCR to the TV, is it plugged into the side of the combo unit that says vcr?
Is your TV on the right source? You could have plugged the audio into say AV2 and the video into AV1, causing a mismatch. Make sure the yellow, red, and white are all plugged into one input section on the TV (AV1, AV2, Video 1, Video 2, etc).
Dec 09, 2008 | Philips MRV700VR DVD Recorder/VCR
Vizio L32 32 in. LCD HDTV Logo
320 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
