We have a maytag neptune front loading washer, the spin cycle does not kick in now, so the clothes come out dripping wet. We called a local repair man, who said it was in the electronics and beyond his ability to dianose or repair. Is the a common problem and with a machine that is appromately 8 years old should we get another repair man or just replace the washer? He was $50.00 just to come and look at it?
    Brigadier General:
  • Washing Mach... Master
  • 3,614 Answers
If he came back and you think there was nothing he can fix.. try to contact someone else.
Posted on Apr 22, 2008
    Master:
  • 555 Answers
What region are you located in?
  • Matt Jurach
    Matt Jurach Apr 22, 2008
    This is the list of possible causes and fixes for a Maytag Neptune that fails to spin:
    ApplianceAid.com
    I'm sure there are technicians in your area that have the capability of diagnosing and replacing the main control board and door lock assembly. It's just a matter of finding them.
  • Matt Jurach
    If you're in the Philadelphia area, try these guys. Or maybe your name is Phil Younker... I don't know :)
    When finding a repairperson for this job, tell them the symptom (not spinning), but also that you suspect a main control board problem, and do they have the capability of replacing that?
    Their answer should help you sort out the folks who only do mechanical repairs from those who can also perform circuitry repairs.
I have a Maytag Neptune front load washer model MAH400AWW that will not drain properly. I have it set to "max extract" and the clothes come out dripping wet and there is always a significant amount of...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 08, 2010 | Maytag Washing Machines
Maytag neptune frot load will not reach full spin speed.
It will not spin while washing, it's more of a rocking back and forth. As far as the spin cycle. If it's not reaching full speed I bet you'll notice that it's not doing the full cycle because the load is bouncing around and cause the washer to shut off. take some of the clothes out and watch it spin the water out.
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH6700AWW spins but not fast enough
Too much laundry in your machine. Try a smaller load and see if you have the same problem
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytage neptune front load washer not spinning
sp is the pump not running remove the hoses and clean out the pump the pump is in the back the dran hose goes to it
Nov 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer spin cycle
Hi joystoy
I would start with the belt. it sounds like the belt is going and that is the least expensive to fix. try that, if that doesnt work then i would call a repair company to look at it.
brent
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Spin Cycle Fails on Washer
This solution is 100% correct, change the : wax motor &control board.I'll be happy to guide you through this if you need me to.
Apr 23, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Neptune washer
If the water is draining out o.k. then either there is no signal from the water level pressure switch, no signal from the control board or a problem with the Spin windings.
Mar 11, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
