Question about Xerox Phaser 8400 Laser Printer
The Phaser just keeps shutting down...
Our Phaser 8400 has always had a problem with freezing up and frequently restarting and cycling through cleaning and warm up modes. I have checked the power supply and it is plugged directly into the wall. Is there anything we can do?
    President:
  • 2,072 Answers
That really sounds like corrupted software.There are some procedures you can try, but they will require setting up the network on the printer , so print a configuration page before you do this.
First though. shut the printer down, on the back of the machine is 2 D shaped knobs. Line them up to the edge of the printer then remove the main board. Reseat your memory cards and reseat that main board assebembly. Be sure everything is seated.
Then do memory resets
PS NVRAM AND JUST A NVRAM reset.
Under troubleshooting
Enter service diagnostics then l and reset PS NVRAM as follows: 1. From the diagnostics Main Menu use the UP and Down arrow keys to highlight Print Engine Menu and press OK. 2. In the Print Engine Menu, use the UP and Down arrow keys to highlight Function Menu and press OK. 3. In the Function Menu, use the UP and Down arrow keys to highlight Clear PS NVRAM and press OK This will set the values in PS NVRAM back to factory defaults. 4. Power the machine off for 30 seconds then power on.
Posted on Apr 23, 2008
  • Rick Kasper Apr 23, 2008
    Problem:
      The Printer Hangs During Initialization, Boot Up, or Power Up
    Cause:
    Solution:
    Fixed! Did not fix.
    TRY FIRST (Solutions without parts):
    1. Verify the printer is plugged directly into a known good wall outlet. In many cases the printer cannot pull enough current thru a power strip, a surge protector, or from a Uninterrupible Power Supply unit. Verify the printer's operation directly on another AC outlet before replacing any parts.
    2. Reseat the printer's RAM.
    3. Reset the printer NVRAM.
    Problem:
    Cause:
    Solution:
    Fixed! Did not fix.
Why does my mouse courser keep freezing?
You have answered your own question... be restarting every two days you are cleaning and clearing your systems ram memory, history,,,etc,,,
Sounds like you have a lot of stuff running that isn't necessary..ALWAYS clear your history,,, its would be good to shut down every night and restart fresh everyday...
Sep 30, 2017 | Computers & Internet
Phaser 8400 DX printer error 07,010.43:2838
check all cables and ink, restart pc and printer, uninstall printer software, then reinstall, if none of those work, the printer has gone bad and needs replaced.
Mar 31, 2008 | Xerox Phaser 8400 Laser Printer
Phaser 8400, can not pull the orange maintenance kit, it seems that it is stuck
It is stuck when the machine is properly shut down?
You can remove the left side cover and gently rotate the process drive until the kit lowers and releases.
Mar 30, 2010 | Xerox Phaser 8400 Laser Printer
Phaser 8400 only prints first page of multuple page print job. help!!!!
I would reload the driver, or switch drivers. Best on an 8400 to be using the most current PS driver. You can find it on the Xerox.com site.
Just click Drivers and downloads, then in the search box type in 8400.
Then click drivers and downloads once again and download the newest driver.
I hate to ask you to do this, but that also sounds like machine software ( firmware) corruption and shutting it off and on could cure your problem also, But yes I know, that wastes ink.
Jan 06, 2010 | Xerox Phaser 8400 Laser Printer
Our printer (8400) light keeps turning red saying it is out of paper when it isn't. Every time this happens you have to open and shut the drawer to get it to print. How do I fix this.
That sounds like a false jam. Your feed roll probably needs replaced if I am reading this correct. If you can run some prints and then that comes up I would believe it to be a feedroll problem.
Feb 02, 2009 | Xerox Phaser 8400 Laser Printer
Maintainence Kit
Normally if you shut the machine off and on and let it totally cycle it will release.
Jan 30, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8400/8500/8560 maintenance kit
No, it will not work because the chip (CRUM) is not compatable.
Jan 13, 2009 | Xerox Phaser 8400 Laser Printer
I have a Phaser 8400 printer that needs to be repaired. Where are your authorized service stations in my area (Miami, FL 33142)?
Here you go
clear.gif UNITED DATA TECHNOLOGIES INC
8825 NW 21ST TERRACE
DORAL, FL 33172
Phone: 305-882-0435
Fax: 305-882-0436
Products Serviced: Phaser 8200, Phaser 860
clear.gif MONARCH ELECTRONICS INC
SUITE 319
1440 79TH STREET CAUSEWAY
NORTH BAY VILLAGE, FL 33141
Phone: 305-866-1885
Fax: 305-865-8087
Products Serviced: Phaser 6120, Phaser 8400, Phaser 8500, Phaser 8550, Phaser 8560, WorkCentre C2424
depot_logo_small.gif IT SOLUTIONS
7210 NW 58TH ST
MIAMI, FL 33166
Phone: 305-513-0059
Fax: 305-513-0062
Products Serviced: DocuPrint 4508, DocuPrint N2025, DocuPrint N2825, FaxCentre F110, Phaser 3150, Phaser 3400, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 740, Phaser 7400, Phaser 750, Phaser 780, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8550, WorkCentre C2424, WorkCentre PRO 423, WorkCentre PRO 423/428, WorkCentre PRO 428
clear.gif LASER PRINTER SOLUTION / FIX A FAX CORP
7240 NW 31 STREET
MIAMI, FL 33122
Phone: 305-471-0093
Fax: 305-471-0113
Products Serviced: Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 840, Phaser 8400, Phaser 8500, Phaser 8550, WorkCentre PE120, WorkCentre PE120I
clear.gif P M E INC
SUITE 130
10800 NW 21ST STREET
MIAMI, FL 33172
Phone: 305-994-9222
Fax: 305-994-9922
Products Serviced: CopyCentre C20, DocuColor 2006, DocuPrint 4508, DocuPrint 4512/4512N, DocuPrint N17, DocuPrint N2025, DocuPrint N2125, DocuPrint N24, DocuPrint N24/N32, DocuPrint N2825, DocuPrint N32, DocuPrint N3225, DocuPrint N40, DocuPrint N4025, DocuPrint N4525, DocuPrint P1202, DocuPrint P1210, FaxCentre F110, FaxCentre F116, N2025/N2825, N2125, N3225/N4025, N4525, N4525, Phaser 1235, Phaser 2135, Phaser 3150, Phaser 3200MFP, Phaser 3400, Phaser 3450, Phaser 3500, Phaser 4400, Phaser 4500, Phaser 5400, Phaser 5500, Phaser 560, Phaser 6100, Phaser 6120, Phaser 6200, Phaser 6250, Phaser 6300, Phaser 6350, Phaser 7300, Phaser 740, Phaser 7400, Phaser 750, Phaser 7700, Phaser 7750, Phaser 7760, Phaser 780, Phaser 790, Phaser 8200, Phaser 840, Phaser 8400, Phaser 850, Phaser 8500, Phaser 8510/8560MFP, Phaser 8550, Phaser 8560, Phaser 8560MFP, Phaser 860, WorkCentre C2424, WorkCentre M20, WorkCentre M20I, WorkCentre PE120, WorkCentre PE120I, WorkCentre PE16, WorkCentre PE220
clear.gif ADVANCED BUSINESS COMPUTERS
1523 NW 89TH COURT
MIAMI, FL 33172
Phone: 305-477-2320
Fax: 305-477-3735
Products Serviced: Phaser 4400
Oct 01, 2008 | Xerox Office Equipment & Supplies
Phaser 8400 paper Jam
The preheat entry assembly has paper detectio arms/sensors that will get brittle and break off, leading the machine to think there is a paper jam. This problem usually will require a trained technician to diagnose & repair.
Sep 12, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400
The first obvious question is, "Does it have blue ink/wax?" Is it displaying any errors? Have you tried the Xerox support site? They have a fantastic utility that can connect to your printer and diagnose many problems. Here's the URL for the utility: http://www.phasersmart.com/ They also have a wealth of information in their knowledge base. Here's the URL for the support page for the Phaser 8400: http://www.office.xerox.com/printers/color-printers/phaser-8400/sprt-enus.html Did anything happen before the blue quit printing? Have you tried running a cleaning cycle?
Aug 21, 2007 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
395 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
