Question about Linksys Wireless-G WRT54G Router
WRT54G Config I was given one from my company that no one could use due to the fact that the tech that had configured it is no longer with us. Just need to find out how to get into it and wipe out the current configuration and just let it be wide open. I have tried the trick to hold reset then plug in power to reset defaults but this did not work for me.
  • Gilmor Apr 24, 2008
    Mine won´t reset or won´t open after I write the 192.168.0.1 address in my browser
    Guru:
  • 1,342 Answers
To reset your router, use the following steps:
  1. Press the reset button for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot, and once the WLAN light stops blinking the router should be reset.
  3. Open up your Web browser and enter 192.168.0.1 in the address bar.
  4. For the login, enter admin as the ID and leave the password blank.
The router has now been reset.
Posted on Apr 22, 2008
Can I load a backup config from my Linksys WRT54G to my new Linksys E1500
Have you tried doing so? Most likely presets from one device will not work on another. You can try though, it should not cause any problems. Worst case you just perform a factory reset on your router if the configuration gets messed up by trying to load the preset from your WRT54G.
Oct 14, 2013 | Linksys Wireless-G WRT54G Router
I no longer can access the internet with my hard-wired computer WHEN my router is attached. If I remove the router and reboot, I can get the internet with my hard-wired computer.
You still need to bridge your moded to the router. Then configure your router for the PPPoE using the account information given to you by your ISP. Your username and password.
Mar 25, 2011 | Linksys Wireless-G WRT54G Router
Cant setup or connect to internet through router
Different ISPs require different configurations. If you have a Linksys router, such as the WRT54G, there are 2 ways on how you can configure it, either by running the Setup CD or by doing manual configuration. This particular router has its own web utility and you can access it by typing its IP addres on your web browser, ex. http://192.168.1.1. By default, it doesn’t have any username and its password is admin.
Once you’re inside the setup page, you can configure now the router for DHCP, PPPoE or STATIC IP settings. For DSL customers using a PPPoE account, some modem needs to be configured into BRIDGE MODE first and then the router will be set to PPPoE with the correct username and password (given by ISP). If your a DHCP account, modem doesn’t require any configuration. It will work with its default setting and the router would be set to DHCP. Once done, powercycle your devices to establish internet connection.
Jul 02, 2010 | Linksys Wireless-G WRT54G Router
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Dyn dns config
you haft to log in to the routers settings and set it up in there.
go to 192.168.1.1
Jan 18, 2009 | Linksys Wireless-G WRT54G Router
Program issues
You may in the wrong section.
Go to :
Start
Control Panel
Administrative Tools
Services
Click on the Services shortcut.
Then scroll down to the 3rd item from the bottom.
Wire Zero Configuration
Make sure that it is set to automatic,
Then click on Start.
Joe
Oct 12, 2008 | Linksys Wireless-G WRT54G Router
Installation linksys wireless-g router
In order for you to setup the WRt54G to work with your Ibook you nee d to manually configure it since the setup CD for the WRt54G wont run on your MAC computer, In manually configuring the router you need to access the setup page of it and there you can set it up, I will advice you to contact Linksys tech support so one of their tech can walk you through with the process the number 800-3267114 they are open 24/7...
Hope that helps...........
Oct 10, 2008 | Linksys Wireless-G Broadband Router
Phone number for trouble shooting
You can Linksys tech support for that this is the number 8003267114 and they will help you for your router.
Jul 27, 2008 | Linksys Wireless-G WRT54G Router
Catalyst ws-c2926 password recovery problem
  1. Attach a terminal or PC with terminal emulation to the console port of the switch. Use the following terminal settings:
    9600 baud rate
    No parity
    8 data bits
    No stop bit
  2. Unplug the power cable.
  3. Hold down the mode button while reconnecting the power cord to the switch. You can release the mode button a second or two after the LED above port 1x is no longer illuminated.
    The following instructions appear:
    The system has been interrupted prior to initializing the flash file system.
    The following commands will initialize the flash file system, and finish loading
    the operating system software:
    flash_init
    load_helper
    boot
  4. Type flash_init.
  5. Type load_helper.
  6. Type dir flash:. The switch file system is displayed:
    Directory of flash:
    2 -rwx 843947 Mar 01 1993 00:02:18 C2900XL-h-mz-112.8-SA
    4 drwx 3776 Mar 01 1993 01:23:24 html
    66 -rwx 130 Jan 01 1970 00:01:19 env_vars
    68 -rwx 1296 Mar 01 1993 06:55:51 config.text
    1728000 bytes total (456704 bytes free)
  7. Type rename flash:config.text flash:config.old to rename the configuration file. This file contains the password definition.
  8. Type boot to boot the system.
  9. Enter N at the prompt to start the Setup program, Continue with the configuration dialog? [yes/no] : N
  10. At the switch prompt type en to turn on enable mode.
  11. Type rename flash:config.old flash:config.text to rename the configuration file with its original name.
  12. Copy the configuration file into memory: Switch# copy flash:config.text system:running-config
    Source filename [config.text]? (press Return)
    Destination filename [running-config]? (press Return)
    The configuration file is now reloaded.
  13. Change the password: switch#configure terminal
    switch(config)#enable password Cisco
    switch#control/Z
  14. Write the running configuration to the configuration file:
    switch(config)#write memory
Jun 07, 2008 | Cisco Catalyst 2926 (WS-C2926) Networking...
FAx & modem config
hi kababayan!
i think it's on VoIP feature...
please visit this site for more info:
http://www.microsoft.com/windowsxp/using/setup/learnmore/crawford_02october21.mspx
hey, what company do you work for?
Apr 23, 2008 | 2wire 2700HG-B Router (2700HGB)
Linksys Wireless-G WRT54G Router Logo
124 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
