Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Checkered screen so what was the outcome of this? i am experiencing the same problem!!!
  • Mitsubishi Master
  • 8,617 Answers
Bad capacitors, All jamicom caps 1000uf and above need to be replaced on the PWB, FMT and DM boards. You can get a service manual at the following link plus free tech support.
http://servicemanuals.vstore.ca/
Posted on Apr 24, 2008
Samsung hlr6167wx xaa
Bad main board part number BP94-01858A.
Feb 15, 2014 | Televison & Video
Screen is crack
This is a factory job best outcome for price and outcome. Hope this helps gabe
Feb 03, 2014 | Citizen PROMASTER HYPER AQUALAND DIVE...
I have an lenovo all in one computer and i am trying to update my windows........i am having a problem doing this, what can i do
First run The System File Checker tool: The System File Checker tool scans system files and replaces incorrect versions of the system files by using the correct versions.
To run the System File Checker tool, follow these steps:
  1. Click Start, and then type cmd in the Start Search box.
  2. Right-click cmd in the Programs list, and then click Run as administrator. If you are prompted for an administrator password or confirmation, type your password or click Continue
  3. At the command prompt, the following line, and then press ENTER: sfc /scannow
  4. When the scan is complete, test to see whether the issue that you are experiencing is resolved.
Mar 03, 2011 | Microsoft Windows Vista Home Premium with...
How can i make my window media center work again .it always appear that it can not work again.
Try the system File checker tool! The System File Checker tool
To determine whether the issue that you are experiencing is caused by one or more system files that are used by Windows Vista, run the System File Checker tool. The System File Checker tool scans system files and replaces incorrect versions of the system files by using the correct versions.
1.Click Start, and then type cmd in the Start Search box.
3.If you are prompted for an administrator password or confirmation, type your password or click Continue
4.At the command prompt, type the following line, and then press ENTER: sfc /scannow
see if this works!!!
Jun 12, 2010 | Computers & Internet
I have word 2007 and windows 7. The speller ignores many very obvious spelling mistakes in my document. I think that I've embedded text with paragraphs that are somehow marked as "not for spelling"....
Open word 2007
Go to tools->Optios->Spellin and Grammer.
Then enable all checkboxes then apply and ok.
If still face same issue then you need to repair your word 2007.
Let me know if you need further assistance.
Thanks for using FixYa.
Nov 24, 2009 | Computers & Internet
SCREEN FREEZE-CHECKER BOX
reboot your computer and during starting type f 8 keys then start in vga enable mood then setup vga 1024 .
May 16, 2009 | Gateway FX7026 PC Desktop
Black/white checker pattern on screen. Sound okay
Sounds to me that the menu is in convergence adjustment mode. Try the menu key on the remote and follow the prompts.
Oct 21, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Samsung SyncMaster 712n monitor will have small blue & white tiny checkers on the screen. will go away if i click the mouse. sometimes the entire screen has those tiny blue & white checkers.
Surely the monitor lets you change it's 'standby' settings so that it doesn't show that; or change your computer's power savings modes not to include standby?
May 29, 2008 | Computers & Internet
Problem with my Acer
hello Aznarel,
Firstly we need to establish if the problem is caused by the notebook's display or by it's on board graphics adapter. To do this I need you to connect an external display to the notebook. I see that the 292 has a VGA I/O port to which any VGA display can be connected.
When the notebook's screen is displayed on the external display one of two scenarios may be experienced:
  1. The problem's symptoms may manifest on the external display, indicating a problem with the notebook's on board graphics adapter. Since this problem can only be solved by replacing the notebook's motherboard, it may be more economical to buy a new one, depending on the status of the notebook's warranty.
  2. The problem's symptoms are not experienced when the screen is displayed on an external display, indicating a problem with the notebook's display. If this is the case I will suspect a malfunctioning inverter.
    Reason: When the LCD TFT display starts flickering it is a sign that the backlight is not receiving the correct current (the inverter provides the backlight with the required current).
    As opposed to a malfunctioning backlight. When a dark, faint output display is the only experienced symptom (that is; no flickering of the screen and no lockup of screen display) the LCD's backlight is at fault
    In case of scenario 2 the solution will be to take the notebook to a computer repair shop where a certified IT technician can order and replace the malfunctioning inverter.
I hope you find this information helpful in solving the problem.
Please take the time to rate this solution.
Kind regards and thanks for using the FixYa service.
Mar 22, 2008 | Acer TravelMate 292LCi Notebook
Hour glass screen
Your problem is a bad main B+ capacitor. The right way to find this would be with a good ESR type capacitor meter. If you do not have an ESR cap. checker or do not know how to use a cap. checker. a local repair shop should be able to assist you in this repair at a decent price. Let us know what you did to get this set fixed?
Oct 05, 2006 | RCA F32665 32" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
