HP LaserJet 1012 Fuser assembly - Office Equipment & Supplies
  • 19,396 Answers
2 Suggested Answers
Soulvisitor
  • 1113 Answers
SOURCE: hp 4300 laserjet
Does it jam at the fuser when doing a single print?
These machines have a Maintenance kit required every 200 000 prints, these MK's include all feed rollers, a transfer roller and the entire fuser assy. To replace the kit fixes all issues I've seen in these printers besides when the cartridge affects print quality.
If it is jamming at the fuser on a single print done via the printer operations panel, and your paper is fresh, it could only be the feed roller having trouble gripping the paper or the fuser not turning/stuffed.
Feed Kit, I have my doubts as to this being your problem
Maintenance Kit Fixes 98% of the time
Was is noisy before it died?
I have seen a few with stuffed fuser drive gears but not many and customers could hear it wearing.
How many prints since last MK? via keypad print a configuration page, count is there ie pages since last maintenance xxxxxx
Posted on Jan 31, 2008
The printings in my hp laserjet 1010 keep appearing with a white band at the right side of the page, i've tried to reinstall the toner but still appears...can you help me guys? please!
Go to paint shoot black colord print page, while printing half page switch off the printer remove cartrige gently, check on catridge drum surface is there any while patch in black image on drum ? if yes *** open laser scanner assembly clean the reflect mirror with ear buds gently fix it back then try once..****check image on paper is there any white band? id no replace teflon sleeve/fuser.*****If white patch is not in image clean/replace the transfer roller. best of luck..
Sep 12, 2011 | HP LaserJet 1012 Printer
HP Laserjet 1012 - Little smudges on page.
You probably have an excesive amount of toner building up on your rollers or fuser. A cleaning done by a certified technician should take care of this problem for you.
May 28, 2010 | HP LaserJet 1012 Printer
My HP laserjet 1012 smears the ink and wrinkles the paper on one side of the paper. What may be causing this problem?
Probalbly the upper fuser roller has some of the film torn off. Look close with a flashlight through the back of the machine.
May 14, 2010 | HP LaserJet 1012 Printer
Hp laserjet printer is printing a large vertical
if the band is white, you may have a problem in your laser scanner assembly, if the band is black, you may have a problem in your fuser assembly
Mar 30, 2010 | HP LaserJet 1012 Printer
I have an hp laserjet 1012. The roller is making noise and it creases the paper as it prints it off. Can this be fixed or do I need a new printer? Thanks Lesley
This problem may be due to the dust or any any other foreign particals on the roller or may be due to the alignment problem of the roller.
First please try to clean the roller using moist cotton with cleaning liquid .Clean it properly to to remove the dust or any other partical on it. If the problem still continue then this problem is due to the alignment problem of rollers. Contact any printer specialist then to resolve the issue.
Nov 06, 2009 | HP LaserJet 1012 Printer
The printer is printing little black dots on my documents
If the dots are all over the paper you may need to replace your toner cartridge. If the dots are smearing, you may need to check your fuser assembly (have it checked by a professional).
Oct 06, 2009 | HP LaserJet 1012 Printer
Piece of plastic film when printing
yes. the fuser film sleeve is part of the fuser units.
Oct 06, 2008 | HP LaserJet 1012 Printer
1,432 people viewed this question
jasbo
jasbo
