Question about Vacuums
How do I change the drum bearing on a White Knight CL427WV tumble dryer, please?
I found a Haynes Manual in my local library that covers this problem!
Posted on Apr 24, 2008
How do i get access to the motor on a hoover vhv781c tumble dryer as i need to replace the capacitor
Hoover vision hd tumble dryer VHC680F 16/10/2012 ...
? 0:19
https://www.youtube.com/watch?v=WCiQ9qc2TWk
Oct 16, 2012 - Uploaded by Ben Smith
Ben did you manage to change the capacitor? I got the same problem but I cant actually get close enough to the capacitor to replace it!.
Nov 26, 2015 | Hoover Vacuums
I was vacuuming my tumble dryer fluff build up out thoroughly and my miele s5280 cut out. It was obviously overheated but how do i re set it? i cannot see where ther is a reset on the machine or in th...
do not think there is one . try turning the juice off at the breaker then back on .if that doesn't work call a service man not good idea to have a dryer running when vacuuming tho
Mar 04, 2015 | Miele Vacuums
Change drum belt on a 38AW tumble drier
A dryer in the vacuum area? I will give some advice here:
Google the model number with "how to replace belt" and if lucky you will find a You Tube video that shows what you want to know.
I did this on more than one dryer I have owned and it may take some dismantling of the dryer that the average person cannot do, consider at least talking to a repair shop to see what it costs to be done right the first time and in your home.
Dec 18, 2012 | Vacuums
Loud when drum is spinning
needs new drum bearings
Oct 26, 2012 | Vacuums
How do I clean the vacuum?
You can clean your DC07's outer casing by wiping it with a damp cloth. The clear bin can be washed, but do not attempt to wash or submerge the cyclone assembly.
The filter should also be washed every 3-6 months - use cold water without detergent. Leave to dry in a warm place for 12 hours - do not dry the filter in a tumble dryer, microwave, oven or near a ***** flame. Ensure the filter is completely dry before replacing it in the machine. For guidance on doing this, please refer to the video below.
If you have any further questions about using or maintaining your Dyson, please get in touch with us directly - you can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Sep 26, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
I took apart my dryer to investigate a noise. While it was apart I noticed arcing at the terminals. L1 had completely melted. I purchased a new terminal block and installed it. Everything went back...
Hi herbert hurt...
The noise you are hearing could be your drum rollers.
They could need cleaning and lubrication or replacement.
If they need lubrication they will make a squeeling noise, if they have flat spots on them they will make a thumping type of noise.
If that is you noise then take the dryer apart and lube,clean, or replace the drum rollers
Please take time to rate me
Aug 17, 2011 | Vacuums
Hi my nilfisk alto e140.1 has just cut out i have changed the fuse its not that could someone please help because i have borrowed it off a friend :( helen....
Hi Helen,
I checked the owners manual. Here are some things you can check:
The thermal sensor has shut it down. The manual says to let it cool down for 5 plus minutes, then try it again. I imagine you've tried that already, so ....
The nozzle could be partially blocked. The nozzle MUST be detached in order to clean it. Use something as long as the nozzle, like a stiff wire or needle like object, to clear it. Then flush it backwards with water.
Since the fuse blew, try the machine without the extensions hose or use a little higher rated fuse or both.
The pump/spray gun is leaking.
If none of these works, please reply back.
I hope this does work. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 06, 2011 | Nilfisk 350-01 Wet Washer
The vac just goes red hot and switchs itself off no idea why. alyx pets 2000w is the model of the vac.
Its activated its thermal cut off. Check the filters - if the paper pleated cone filter is blocked throughly tap it gently to loosen dirt before washing it completely and drying it in a low temp tumble dryer (put it in a pillow case with a towel inside the pillowcase to stop it knocking off the sides in the dryer.) Also check the main dust channels behind the bin and also behind the beater bar as it may well be clogged. Then reinstall everything and check again.
Mar 04, 2009 | Vacuums
HOW DO YOU WASH THE JC0280-000 FILTER SAFELY? IT'S FROM A BAGLESS VACUUM. THANKS
The easiest way to wash this is to put it in lukewarm / to the touch warm tap water in a basin and drop in some washing up liquid/dish liquid as this is one of the more gentler cleaning agents you can use. Leave it for a few hours without doing anything. Rather than use a brush which can tear the paper pleats/folds, inspect the filter to see if it has been rid of dust then use your fingers to gently widen the pleats to ensure all the dirt is gone.
Sadly for this type of filter it is near impossible to get it looking white again. However in lieu of letting it room dry for 24 hours (sometimes the JC0208-000 can take up to three days until it is bone dry)
Slip the filter into a pillow case and put into an electric tumble dryer. Select a low heat and check every 30 mins to see if the filter has dried.
Dont forget to rate this, thanks.
Jul 30, 2008 | Dirt Devil Vacuums
Vacuums Logo
270 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
