The proceedings are as follows: 1. on the PHS 46 G release all Phillips screws. 2. On the underside of the trimmer, remove the metal cover.(4 screws). 3. Slide the scissors form as far as possible to the front , then we see two more small Phillips screws . Loosen these screws too. Now, the entire blade detaches from the ex-center gear. 4. The housing can well be apart!
We had exactly the same problem...the answer is you also need to remove the blades to get the case appart.
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
SOURCE: reassembly of trimmer blades to stihl HS 80 hedge trimmer
My request from you was for a schematic of assembly for my stihl HS 80 hedge trimmer. You did not send but rather gave general advice. I solved the problem by calling a small engine repair shop and asked them to fax me a photo copy. You all were of no help and appear more to want money via bait and swithch. THUMBS DOWN to you!
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
