Question about HP Photosmart M425 Digital Camera
Memory card Hi, can you tell me how to transfer photos from my computer to my hp photosmart M425 memory card.?
  • 3 Answers
Plug in and turn on your camera to link it. when the option to open the folder comes up, select open folder to view files. when you have that open, simply drag the photos you want to that folder and drop them. they will then be on the memory card.
Posted on May 07, 2008
My picture wont show up
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Oct 29, 2012 | HP Photosmart M425 Digital Camera
Lans error.m425-11 ..............m425-21
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 17, 2011 | HP Photosmart M425 Digital Camera
HP Photosmart M425, "Card Lock" message, camera
Take the memory card out of your camera. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Nov 05, 2010 | HP Photosmart M425 Digital Camera
Need a way to upload pics from my HP photosmart M425 camera (regulatory model:SNPRB-0503) to my computer
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Oct 03, 2010 | HP Photosmart M425 Digital Camera
I want to transfer pictures from my computer onto my memory card in my PhotoSmart M425 camera to then put on my digital photo frame. How can I do this?
Put the card into a card reader attached to your computer. The card will then appear to your computer as another hard drive. You can transfer pictures to the card the same way you normally transfer any other type of file.
Dec 30, 2009 | HP Photosmart M425 Digital Camera
I lost my HP Photosmart M425 USB connector.How do I get a newone
Consider getting a card reader instead. You should be able to pick one up at just about any department, electronics, or office-supply store for less money than a USB cable.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 07, 2009 | HP Photosmart M425 Digital Camera
How do i move pictures on my HP Photosmart M425 to my computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Mar 11, 2009 | HP Photosmart M425 Digital Camera (5MP,...
Help with camera?
Do you have a pc with an SD card reader on it? If you do, you can insert the card into that slot and it will act as a removeable drive. You can find it in My Computer under removeable drives.
When you connect the camera to the pc, it will become a removeable drive. Just transfer from one drive to the other.
Let me know if I can be of anymore help, and thanks for coming to FixYa. If you would, rate my solution a fixya.
Rob
Jan 27, 2009 | HP Photosmart M425 Digital Camera
Camera says "establishing connection" when trying to transfer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Dec 09, 2008 | HP Photosmart 433 Digital Camera
Can't reformat my memory card
Hello
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Jun 25, 2008 | HP Photosmart M425 Digital Camera
    HP Photosmart M425 Digital Camera Logo
    59 people viewed this question
    Top HP Cameras Experts
    Fred Sops
    teddyboy
    Lawrence Oravetz
    Are you a HP Camera Expert? Answer questions, earn points and help others
