Vacuums Logo
A
Anonymous Posted on Jul 21, 2010
My vacuum no longer has suction to pick up dirt. In fact it spits what it picks up back out now..
Anonymous
Level 3:
  • Master 43,501 Answers
  • Posted on Jul 23, 2010
Anonymous
Master
Level 3:
Answers
43501
Questions
0
Helped
10837959
Points
101584
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 • Vacuums
1helpful
Vacuum picks up some dirt and debris but not all, and spits some back out?
Some blockage at the pickup or in the hose if it uses one---dirt etc being kicked back out is a clear sign of this----if it has a tube check that first, and if a head with turning brush do not miss looking for a blockage there.
The suction will pick up and spit dirt back out on floor
This is an indication that the intake is clogged. Needs disassembly and cleaning.
Charlie
Vacuum cleaner not picking up and sometimes spits ouit dirt
Check to see if bag (or if not bag then chamber is full).
Check to see if filter is clean.
If your vacuum has a bag, check to see that it is properly mounted.
Sorry I couldn't be more specific but it would help if you would specify what type of vacuum you have, whether you are using the hose or just the floor part, and where it is spitting the dirt from.
Hope this helps. If not, let me know the answer to the above questions and we'll go from there. Good luck!
Mar 13, 2010 • Vacuums
2helpful
Vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
1helpful
Vacuum doesn't work on bare floors!
does it have a bare floor setting that shuts off the beater bar? if the brush is revolving it will scatter dirt instead of picking it up
Kenmore vacuum- no suction, brush wont turn
Sounds to me like you have a plugged vacuum. Check all the way through.
1helpful
Hoover Windtunnel spits dirt back out the back
Your problem sounds to be an obstruction in the foot (lower body) of the windrummel. Most all windtunnel's have a second cavity for suction to go over the top of the roller. When you remove the bottom plate, next remobe the belt and roller, under the roller will be a removable cavity, take it out. remove the dirt and clean out any debris. also check the suction path connecting hose. if your belt has not been changed in the last 12 months, I would recommend changing that as well.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Dirt Devil Featherlite not picking up
It sounds like you have a blockage somewhere. The brush roll will still gather material, but if the suction is insufficient, it will spit it back out eventually. Take the bag out and check at the connection for blockage. When you are sure it's clear, put in a new bag and turn the machine on. The bag should inflate rapidly. If it does not, check elswhere for blockage.
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
