Question about Nintendo Wii Console
  • 4 more comments
  • mlaser Apr 23, 2008
    Remotes will not turn power on. Sync button would not solve problem either.
  • Anonymous Jul 04, 2008
    controller isn't working
  • spacin23 Oct 13, 2008
    Controllers working fine yesterday, this morning, nothing tried new batteries, re-syncing and reseting the unit, no luck
  • Anonymous Jan 25, 2009
    it won't work
  • Cory Jones May 11, 2010
    did you sync the controllers?
  • mansil May 11, 2010
    the was unplugged for a few days connect it up again the batteries red flashing to say charged but the controller wont switch on no blue lights thanx
  • 66 Answers
I think you need to register the wii controller to the wii because sometimes the PS3 when you buy another controller you have to register the device to the Ps3 before you can play so i think the Wii may have the same controller registeration. So if it doesn't work try using the controller you 1st got from the box because in order to use the controllers it has to be registered hope it helped.
Give me some credit
and rank my solution.
Posted on Apr 22, 2008
SoundLogic XT #BOW-6/5998 No power anymore. Won't recharge anymore.
Make sure the charger is working properly. if ok, replace the battery.
Apr 13, 2015 | Audio Players & Recorders
WELLTECH 40699 FKH51A repair
I the red led only comes on dimly, the new batteries are suspect, or they are not charged. You need to establish if its the headphones or the batteries at fault. To check the headphones remove the batteries and connect up some none rechargeable battery of the same voltage to the headphone battery connections. To check the batteries use a multimeter to measure the voltage at their terminals while they are out of the headphones. If its low compared to the value printed on them, you can either try more new batteries again, or replace the headphones completely.
Dec 15, 2013 | Televison & Video
How do I revive a Hilti 36 volt battery from a TE6 nicdm
There is no way to revive a rechargeable battery once they go bad. Rechargeable batteries have a lifespan that is affected by how many times they have been discharged and recharged and how fully discharged they are between recharges. Most batteries will last longer if they are fully discharged before recharging and allowed to cool completely before recharging, heat being the main culprit to their longgevity. They will eventually reach a point where they will not charge anymore or if they do they will not hold a full charge for any appreciable time. The best test for the batteries ability to take a charge is to completely deplete the battery either through working it or sitting on the couch with the trigger pulled until it stops working completely, let it cool down then put it in the charger. If it charges, use it to see how long it lasts. If it dies quickly it needs to be replaced.
Dec 29, 2011 | Drills
It won't light up when you hit the switch. It doesn't appear that charging it does any good.
sounds like there might be a connection problem inside the flashlight. or, simply the batteries just will not hold a charge anymore. Some rechargable batteries tend to die after awhile and wont hold their charge anymore.
Aug 11, 2010 | Streamlight Camping, Backpacking & Hiking
Battery icon doesn't change
Hello :
Simply your battery is dead [ can't be recharged anymore ] and needs to be replaced .
Batteries have lifetime . At the end of this lifetime the battery can not be recharged anymore . There are chemicals in the battery that become inactive anymore . In this situation there will be no other solution than replacing the battery with new one .
please rate !
Apr 16, 2010 | SkyGolf SkyCaddie Handheld GPS Unit
I got this camera and it wont charge
Hello :
First check the charger . If the charger is fine , then you need to check the charging jack on the Camera . Last thing will be replacing the battery . I would think at last that the battery is dead [ can't be recharged anymore ] .
good luck .
please don't forget to rate !
Apr 07, 2010 | Vivitar ViviCam 8025 Digital Camera
Ipod touch won't charge, connects to charge for half a second then stops
Hello :
You need to check the power transformer and power cord . If they both are OK , then you need to replace the battery , because I think that the battery is dead [ can't be recharged anymore ] .
good luck .
please rate !
Mar 30, 2010 | Apple iPod touch Second Gen (8 GB,...
My controller wont turn on without the charger cord
If you are using a rechargeable battery and it hasn't been used for a year it is possible that it is not holding a charge anymore. You may have to buy a new rechargeable battery. A good way to test that there is nothing wrong with the controller is to throw some AA batteries in there to make sure. If the controller works fine with two AA batteries then you know that you most likely need new rechargeable batteries. If it doesn't work you have have a bigger problem with the controller or the cord, but I doubt that there is a problem with the controller.
Jun 26, 2009 | Microsoft Xbox 360 Controller
Battery not charging
Possibly the batter may have gone dead. How long have you had the MP3 player? If maybe it hasn't been used in a while how was it stored? Cold? Heat? Lots of moisture. But really if it is old most likely then it can't hold a charge anymore. Thing to try is just buying another battery and see if it will work and if that doesn't work well, say goodbye to the MP3 maybe unless you know of a place that can fix the internals.
Jan 24, 2009 | Audio Players & Recorders
It won't charge the rechargeable batteries anymore
I have the same problem , the only logical reason i could think of is that the charger connecting to the base station has malfunctioned .
Aug 30, 2008 | Philips VOIP8411B/37 IP Phone
Nintendo Wii Console Logo
117 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
