Question about JVC HR-XVC27U DVD Player/VCR
From kimchan The brand of my television is a Polaroid LCD. Model No. TLA-01511C. There is no home theatre connected. Thanks
  • kimchan Apr 24, 2008
    Thanks. Everything is connected!!
    kimchan
    Master:
  • 788 Answers
This is not the best solution but since your DirecTV receiver doesn't do UHF/VHF and the only other input is in the front you will have to have it that way
Connect your H21 to your TV however you wish but I would use HDMI if I were you.
Connect either V1 or V2 and the L and R from the H21 to the front inputs on the VCR/DVD. Due to the lack of outputs on the H21 and the lack of inputs on the VCD/DVD that is all that is available.
Now connect the VCR/DVD (Yellow/Red/White) output on the JVC to the video in and matching L and R audio ins on the TV, this will allow you to watch VHS tapes and DVD over the analog connection.
Lastly, you want to connect the component video out on the DVD to the Y, Pb, and Pr inputs as well as the L and R audio out on the DVD side to the matching L and R audio in on the TV to get a better picture when watching DVDs and to enable widescreen DVDs.
Know what I will take a few minutes and will draw up a diagram that will hopefully make more sense than this. I should have it for you by the end of the day.
Posted on Apr 23, 2008
  • 2 more comments
  • Dean Joly
    Dean Joly Apr 23, 2008
    Here you go:
    This is the best way to connect everything up. If you don't want to use HDMI for the DirectTV then you would have to sacrifice the component output from the DVD and go component from the DirecTV straight to the TV. In that case you would need to connect the coaxial digital audio out on the H21 to the coaxial in on the TV to get digital sound. Then I would use the S-Video out of the DVD to the TV, you would not need the second set of Audio L-R cables going from the DVD to the TV in that case. But you DVD picture quality would suffer greatly in this case. Connect everything up like I have on my diagram and you won't be disappointed.
  • Dean Joly
    Don't forget to also rate my solution in the original problem thread. Thanks.
  • Dean Joly
    Actually I modified my original design to enable digital audio from the DVD to the TV, this way you are not sacrificing audio quality when watching a DVD.
  • Dean Joly
    This is how you would connect everything if you wanted to skip HDMI. This method would greatly reduce DVD picture and sound quality.
I have a Polaroid Tla-01511b that goes blank after a few seconds from power up. I replaced all 1000uf and 470uf 25v 105 degree caps on inverter without luck. What else should I replace?
Nothing more to do. Contact any service technician.If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 02, 2013 | Polaroid TLA-01511C 15 in. LCD Television
My Polaroid TLA-01511C has sound but no picture...what do I do
Replaced the LCD inverter backlight board is dead.After U replaced this LCD inverter board.U will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board.It a long board shape.
Feb 21, 2010 | Polaroid TLA-01511C 15 in. LCD Television
I have a Polaroid TLA-01511C 15 in. LCD Television that has no picture but does have sound. Solution #1 in this page says "a bad cap in the power board, the can like device will have a puffed up top from...
Radio Shack is your best bet. I replaced two 680uf 10v caps and one 1500uf 10v cap. It now works just like brand new. The caps I replaced had higher voltage values hopefully this will help prolong the life of them.
Nov 27, 2009 | Polaroid TLA-01511C 15 in. LCD Television
I have 3 Polaroid TLA-01511C 15 in. LCD Televisions that have no picture but does have sound. Is this a common problem with this model?
I replaced three capacitors on my power supply board and the unit started working again, There was two 680uf 10v caps and one 1500uf 10v cap bad.
Nov 20, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Screen goes dark after few minutes
check your LCD inverter maybe there is loss connection or some parts damage from inverter.
May 05, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Manual for TLA-01511C
olsonde,
Here is your product info. Please let me know if I can help you in any other way! If not, I would appreciate you rating this as "FixYa".
http://www.polaroid.com/CES/SupportProductDetail.jsp?prod_code=PT261&folder_id=0
-DRebel
Apr 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Polaroid TLA-04641C no sound
You should go into the menu SOUND section of your tv. Look for the TV Speaker choice option.
This will have to be turned on to get sound from the tv.
Feb 23, 2009 | Polaroid TLA-01511C 15 in. LCD Television
How do i find the AUX on the Polaroid TLA-01511C? I want to run a DVD player and it needs to be set up on the AUX. If I run a scan on the channels it does not pick up the AUX
I would recommend using the S-video connection for the DVD to the TLA-01511C TV's S-video. Then, press the input button and go down to the S-video option and you should be good to go - it worked for me. Hope this helps you!
Dec 21, 2008 | Polaroid TLA-01511C 15 in. LCD Television
JVC HR-XVC27U DVD Player/VCR Logo
88 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
