How do I move apps from one screen/"page" to another? I tried dragging it and it doesn't transfer it from one screen to the other, even though there is room for more apps on the particular page. (I just want to have each page full of apps, and only the last page partially full, rather than every page being partially full)
depends on your country and provider you need to delete and re ask the question.
generally you call your provider and look up sim and or ime number under settings and about and read those numbers to your service provider and they activate the device on your account
If your apps were from the apple AppStore they should be in the cloud and you should be able to retrieve them on your new Apple device as long as you know your Apple ID and password along with your iCloud password
It is easy to transfer contacts from Samsung to iPhone using a third-party Phone Data Transfer. In the video below, you will find a reliable tool that helps you make the transfer easily.
You may want to try resetting the phone by holding the home and power button simultaneously until the phone shuts down and the apple logo appears. If that doesn't help, connect it to your computer and do a restore using iTunes.
Touch and hold app to move until it starts to jiggle.Drag app to bottom of screen placing with other apps ,scroll screen to home screen,take app from bottom and move to home screen.Apps can be moved to any screen as long as they jiggle.
hello,ensure you are not clicking on the key wrongly,i would advice you put the phone off and on back to see if the problem stops.if it doesn't i would also advice you ensure you close any application you are not making use of.it could also be as a result of accumulated opening of applications.
if that does not stop the problem,i would suggest you get the phone flashed by a mobile phone authorized repair engineer around you.
wish you good luck,
take care.
Turn the iphone off, hold the menu button, now plug in the usb cord that is connected to the computer. Keep holding the menu button until a dock connector appears on the screen. You're now in recovery mode and should be able to restore your iPhone. If that doesn't work you may have a broken logic board. Here is an iPhone Repair Guide that shows how to open an iPhone. Boards are easily available on Ebay. If you want somebody else to do it for you go to iPad Repair
