Question about Hitachi CP-S335 Multimedia Projector
Resetting the air filter timer
Hi, I cleaned the air filter on the Hitachi CP- RX60 projector and followed instructions on the resetting of the timer. Using the remote it jumps (in the menu) out of the cancel mode to sub menu and it will not let me high light the reset. There is no reset on the projector itself. How can I clear the air filter message when I start up the projector?
How can I reset a lamp timer after replacing a new lamp in a hitachi cp-s335 multimedia projector, or where is the reset switch located?
  • carlyalbee Jul 31, 2008
    I can't reset the filter or the lamp...nor can I do a "factory reset." I have used the manual instructions and it still won't work.
  • timle Jan 27, 2013
    Thank all, i'm done successfully.
If you do not have a remote here is how to reset the filter time. Use the "Menu" bottun to get the "easy menu" to display. Push the down arrow until you get to "Filter Time," then push and hold the RIGHT arrow to reset the filter time. DO NOT try to reset using the "Reset" option on the easy menu, it will not work.
Posted on Oct 02, 2008
    Scholar:
  • 105 Answers
Hitachi CP- RX60:
Press the RESET button on the remote control or the right-pointing triangle button on the projector for about 3 seconds. Once you see the RESET dialog, use the upward-pointing triangle to RESET. I can't see what you are or are not doing...so please see page 39 of the user's manual (download found below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-RX60-projector.html
Hitachi-CP-S335 :
"The lamp time is the time counted after the last resetting. It is shown in the OPTION menu as the use time of the lamp. Pressing the RESET button on the remote control for about 3 seconds displays a dialog. To reset the lamp time, select the RESET option using the (triangle) button."
Taken from pg 36 of the users manual (download link below)
Source:
http://www.aboutprojectors.com/Hitachi-CP-S335-projector.html
Posted on Apr 24, 2008
Hi there, I can not reset the filter timer on a Hitachi CP-x4445 projector
Sometimes the reset on that timer can be picky. Here is the snippet from the manual that suggests you hold the reset for 3 seconds:
If it were me I would skip using the remote and follow these steps using the panel on top of the projector (using the arrows, etc) . Hold the right arrow to get the reset until it shows, rather than trying to count the seconds...
Mar 10, 2011 | Hitachi CP-X445 Multimedia Projector
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here. http://www.aboutprojectors.com/pdf/hitachi-cp-x1250-manual.pdf
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
Hitachi projectors cp rx60 cp r555 same remote control?
Specifically i don't know. What i do know is mfg's use the same codes, whether they map them to the same functions across a series of remotes can't say for sure. Experiance tells me it will be just fine...
Jun 10, 2009 | Hitachi CP-S335 Multimedia Projector
Cleaning the filter/blinking LAMP and TEMP
Goto Advanced menu and select option then lamp Time hold down the reset button on the unit for 3 seconds until a new screen comes up then hit reset. Do the same for resetting the filter time
Feb 01, 2009 | Hitachi CP-X445 Multimedia Projector
Lcd projector beeps every minute
Hi Jenrowe
Try resetting the lamp and filter timer , if this still occurs reset the whole mashine.
Apr 24, 2008 | Hitachi CP-X275 Multimedia Projector
Hello Wardens wife
What you want to do is go to the advanced menu, find the filter time and using the remote hold down reset button for 3 seconds or so while the filter time is selected. This will bring up a reset menu and reset the timer.
Mar 23, 2008 | Office Equipment & Supplies
Resetting Air Filter Timer once cleaned.
Menu, options, filter time. When the filter time is displayed, press the reset button for at least 3 seconds. The reset menu will appear and you can select RESET.
Feb 01, 2008 | Hitachi CP-X385 Multimedia Projector
Hiya there, just worked out how to reset the filter timer so for those that need to know here's the solution;
Bring up the menu and go right the way down to "Option" where it shows you the lamp and filter hours.
Next highlight/select the filter timer section and while its on there hold the RESET button on the remote for 5 seconds.. this then pops up with a resert option and hey, 0h again, good as new! :-)
Oh and if you dont have a remote, just hold the right arrow button instead for 5 seconds in place of the reset and follow instructions as above!
Hope this helps.
Regards,
Omar.
Dec 12, 2007 | Hitachi Office Equipment & Supplies
Hitachi CP-X250 LCD Projector
clean filter and reset the filter timer by advanced options filter timer and hold reset till menu shows then arrow up and it will zero out.
Oct 19, 2007 | Hitachi CP-X250 Multimedia Projector
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Hitachi CP-S335 Multimedia Projector Logo
4,907 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
