Epson ELP-3300 powers up bulb light is green but...
Thank u but how do I reset it, it doesn't projects
  • Sylvester Williams
    Sylvester Williams Apr 23, 2008
    ok here it go's yes it powers up power light comes on, all fans come on, the bulbs' power light starts to flash on and off bulb is warming up ,now here is where its gets trickey at. power light switches to stand by, bulb light stay green,but there's no images projecting out, I did check the fuse,fues is in working condistion, The epson tech said it could be my sensors the projector needs to be service. So where is the ballast located at. Where the lamp go's at.
  • 563 Answers
Ah ok , so it doesn't start up at all.
Is there any power at all on the unit , like LED's lighting up ?
If there is then it would be your Ballast ( lamp's powersupply ) that need replacement.
If there isn't - then you should check on the Powersupply Board ( where your AC inlet sits in ) if the fuse is blown and if not , then you will have to replace the Powersupply Board.
Posted on Apr 23, 2008
Epson 1925W projector has a brand new bulb but the lamp light flashes red. Power light is solid green and Temp is off
Reset the Lamp Hours, see if that helps. Also clean the filter and reset filter hours too
Nov 08, 2016 | Epson 1925W Projector
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Dec 06, 2012 | Epson PowerLite 410W LCD Projector
Epson ELP 3000 clicking noise and all lights flashing
1,Check the fans ,whether each fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 26, 2009 | Epson (1023661) Projector Lamp for...
ELP 3300 lamp problem?
probably. try to check the number of light hours( you can check the manual on how to view it) usually 10000 hours could mean that you need to replace the bulb. also check the physical appearance of the bulb, if it has cracks on the ceramic at the back, then you need to replace it.
Jan 29, 2009 | Epson (1023661) Projector Lamp for...
EPSON POWERLITE BULB REPLACEMENT PROBLEMS
ok
look at your users manual.
all epson models need to have lamp life reset befor the lamp will light.
I have had this same problem befor.
Daniel.
Jan 11, 2009 | Televison & Video
EPSON EMP 3000
There is an adjustment in the Video section for adjusting it to look square.
Aug 13, 2008 | Epson ELPSC07 for PowerLite Home 10,...
Epson ELP 5500 projectors
Hi technoteach
Will try and get my hands on a Service Manual for this model - in which you would find the circuit diagrams. This is a faulty Mainboard that is causing the problem.
May 09, 2008 | Epson PowerLite 5550C Multimedia Projector
Epson ELP-3300 powers up bulb light is green but stays on stand by
Hi djSilver
Try resetting the lamp timer.
This normally solves this problem.
Apr 22, 2008 | Office Equipment & Supplies
357 people viewed this question
k24674
jasbo
jasbo
