Question about Cell Phones
Cannot find a driver to connect my Samsung SCH u550 cell phone to my computer.
I bought a usb cable that says it works with my new Samsung SCH u550 to connect to my computer but on the cd that came with it, there is no driver listed for that particular model. Can't find any place to download one. Is there another model of phone that the driver works for this one too? I just want to put music on my cell phone but this is becoming a major project.
Thanks for any help you can give!
  • Anonymous Sep 25, 2008
    Likewise- I have a Samsung SCH-u550 and a compatible cable, but the usb driver software I've used for other CDMA phones in the past isn't compatible. Can anyone recommend a driver? Thanks.
  • Alarming One Dec 21, 2008
    Same problem. The Driver that I downloaded from the Samsung site wouldn't install correctly in Windows Vista (even though Vista is listed as compatible). Please advise where I can obtain a driver for the Samsung SCH-u550.
I had the same problem connecting with bluetooth. Then upon a suggestion I found on another discussion board, I changed my port settings to 115200 bits per second, and it now connects just fine using Bitpim. Port settings are found this way: Computer>View System Information>Hardware>Device Manager>Ports. Then right-click the port through which you are connecting, and select Properties>Port Settings. There you can change the connection rate to 115k. Good luck.
Posted on Apr 07, 2009
I have a samsung 450 and bought a usb data cable so that I can download my pics from my phone to my computer. Could you tell me how to do this?
Connect the phone to the PC with the USB cable and set the phone to Mass Storage Device in settings->phone->USB. Then a new FAT4 Drive will appear in My Computer. Use this drive as you would any other drive.
Mar 02, 2011 | Samsung SCH-U450 Cell Phone
Tip
How to replace a Samsung SCH-U550 cell phone battery
The Samsung SCH-U550 is an older-style flip phone that doesn't see much use today. If you still have an SCH-U550 and you need to replace its battery, here's how.
First it's a good idea to turn the phone off. (You don't have to, but there's less chance of data being corrupted if you do.) Hold down the End button for a couple of seconds until you see the phone start to power down, then the screen will go black.
Once the phone is off, turn it over so you're looking at the back side. Most of the back cover, from the bottom about 2/3 of the way up toward the top, is one piece. To remove the cover, push down on it with your thumb and slide it downward. If you press on it closer to the top it will be easier to slide, but you may have to push firmly.
With the cover off, you should be staring at the battery. It's black and rectangular, and it probably says "Samsung" on it. Remove the battery by sliding your thumb into the groove on the bottom side and lifting it up.
When installing the new battery, slide it in from the bottom up -- towards the three gold pins sticking out of the phone. Those pins should line up with the three gold contacts on the battery itself. The battery will also probably have an arrow on it, in the direction that you should slide it.
With the new battery in, reattach the rear cover. There are three tabs sticking out of the top of the cover that will line up with three notches in the back side of the phone. Insert the tabs about halfway into the notches, then push the cover down (toward the phone) and slide the tabs the rest of the way in to snap the cover into place.
Now just turn your phone on to verify that the new battery works. If your phone doesn't turn on, remove the battery and reinstall it, being certain that the contacts and pins are touching and that everything fits into place.
on Jan 18, 2011 | Samsung SCH-u550 Cellular Phone
I have 2 SCH-U550 phones, both on my Verizon plan.. One has a fried display, the other is fine. The "Good" phone has just had its number/account upgraded into a new phone (not yet activated) ,...
Hi, unfortunately the SCH-U550 with Verizon service doesn't use a SIM card... everything is internal to the phone. You should be able to take the two phones to a Verizon store and have an associate swap the numbers for you, however. I've had this done before and it was free.
Hope that helps!
Dec 22, 2010 | Samsung SCH-u550 Cellular Phone
How to transfer my pictures from my phone to my pc?
Hi, you need a Samsung SCH-U450 Intensity USB Data Cable with Driver CD.
Just like this: http://www.bargaincell.com/samsung-sch-u450-intensity--usb-data-cable-with-driver-cdrom-p-24883.html?cPath=2830_2831_23492_23497
Hope this helps. Please help me also by voting and writing a testimonials. Thanks. :)
May 12, 2010 | Samsung SCH-U450 Cell Phone
Hook samsung to pc
before you connect cell to pc. change the (cell) connection settings to either usb/bluetooth. now connect.
go to my computer and you cell icon or harddrive should have appeared. and you be able to continue using studio 3.
May 21, 2009 | Samsung SCH-R400 Cellular Phone
Samsung eternity cant get pics onto computer
There was software that came with the eternity. Use it, or buy it off amazon.
Apr 19, 2009 | Samsung SCH-u550 Cellular Phone
Changed nam on phone that changed lock code,need unlock code
when phone turns on it probably says something in the way of needs initial set up or something simular? at that screen just hit clear button which will take you rt back to default screen then hit center menu button go to settings and then to phone settings,nam and chaNGE back to nam1,hit ok . phone will restart and come back on with everything normal again,let me know if different happens!
Mar 11, 2009 | Samsung SCH-u550 Cellular Phone
Vista won't recognize my phone.
You need to go to the samsungmobile.com and download the vista drivers for the phone
Sep 10, 2008 | Samsung SCH-u740 Cellular Phone
Syncing won't work
youll need the drivers for them i cant find them online but you may want to try bitpim its a free program that would let you do it without drivers
Apr 01, 2008 | Samsung SCH-u740 Cellular Phone
Cell Phones Logo
511 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
