Mitsubishi 35 Can I fix this? The picture rolls from top to bottom (or bottom to top). Can't afford a new one right now and can't afford the cost to have it looked at and/or fixed. THanks
  • 121 Answers
Sounds like you have a defective vertical output ic let me know if you need more information put your model number please
Posted on Apr 23, 2008
The horizontal hold
If model number correct (the one posted here) set does not have a horizontal (rolls left to right) or a vertical (rolls top to bottom) control.
Verify model and brand so I may offer some suggestions
Mar 22, 2012 | Mitsubishi VS-5075 50" Rear Projection...
I have lost my keys to my 1993 ford taurus and I cant afford to have keys made right now, But I need to get it into neutral so I can get my other car out. Is there anyway for me to do this
THIS IS DANGEROUS YOU HAVE TO DISCONNECT REMOVE SHIFT LINKAGE AT TRANSMISSION BY DOING THIS ONCE CAR KNOCK OUT OF PARK CAR CAN ROLL ON TOP OF YOU.CHEAPER GET NEW KEY AT DEALERSHIP.93 MODEL IGNITION KEY WONT COST AS MUCH ONLY NEW VECHICLE WITH TRANSPONDER GOING COST YOU MORE.
Sep 11, 2011 | Ford Taurus Cars & Trucks
My almost 10 yr old Mitsubishi HDTV intermitently has color flux
The Main issues with the Mitsubishi HDTVs that size are the projection bulbs in the rear. A large TV like the Mitsubishi can allow dust build up on the lamps and the mirror in the rear that projects the picture to the screen. An easy fix would be to clean off the dust off of the mirror and bulbs. You would need to go through a tough processto do this since the mirror can be quite heavy and is in an ackward place. The only other alternative would be the need to replace the projection lamps themselves which can cost any where fromm $150 - in some cases $300 a piece for the lamp itself. The Television is still a great set but can cost quite a bit right now to fix if the problem is with the Lamps. If you can afford the Lamp replacement if it is needed the set would last you another 10 years plus. If you wouldn't like to go through the hassle of repairing the set or finding a place to repair the set there are so many new sets out in the market that will give you an amazing picture and quality.
Mar 29, 2010 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi dlp 52525 garbled rolling picture. Picture just colored lines, rolling slowly. Sound fine, fairly new lamp.
You most likely have defective capacitors in your electrical chassis. It's best to send the entire chassis back to the manufacturer for total rebuilding. The cost is about $350 + labor, unless you can remove the chassis yourself.
Good luck.
Aug 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi 55 inch rear projection tv, ws55819 on which the convergance is gone bad. I'm getting a concave picture with multiple colors and black lines with a blurred picture. this happens mutiple...
Your reference to concave picture suggests a high voltage problem and not convergence. If the raster can't scan from left to right , top to bottom, your having High voltage trouble. if your colors are not dropping on top of each other that is convergence. I would suggest it may be time to consider a purchase of the new HD set for the cost of this repair. good luck
Jul 03, 2009 | Mitsubishi WS-55819 55" Rear Projection...
The picture is curved in at the top and bottom of the sides.
This issue is caused by the micro capacitors and the convergence module, the capacitors are part of the main circuit board, the job will cost around $600 to repair, better option is a new TV.
Nov 29, 2008 | Mitsubishi WS-65857 65" Rear Projection...
Mitsubishi WD-62825 vertical lines, blue snow, picture jumping
I have the same problem with my tv, my tv tech said mitsubishi knows of the problem and knows how to fix it, but it would cost me 700.00 plus his labor to take out the chassis and send it in to mitsubishi, plus I would be without a tv for up to a month. this is b.s.
Oct 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Rolling picture
Try replaceing capacitors C2C52 10uf 50V capacitor and also C2P05 100uf 16V capacitor. these are both on the signal board. It that doesnt correct the issue replace IC2P01 which is the 9volt regulator also located on the signal board. That should take care of your problem
Jun 08, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Olympus Stylus Zoom 140 All Weather 35 mm
Make sure the flash is coming up all the way. If it gets stuck even slightly down from fully raised, it will do what you describe.
I agree, digital P&S won't work as well as your Olympus. Plus all your shots will have to be stored on a hard drive-
Jan 01, 2008 | Olympus Stylus Zoom 140 35mm Point and...
Horizontal roll on mitusbishi 35" tv
is this a horizontal black line going up or down? if yes, this sympton is caused by a trouble in the integrated circuit or in the vertical oscillator circuit. this symptons has 2 variations. one is the intermittent rolling of the picture. this referred to as the "loose vertical hold" the other variations is the continuous upward or downward rolling of the picture
Jan 15, 2007 | Mitsubishi CS-36509 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
