Question about Apple iPod MA446LL/A MP3 Player
Ipod not working??
My husbands ipod will not turn on anymore. It won't even charge. It's just a black screen. What could this be??
Smash it with a hammer that alwas works for ne
Posted on Apr 24, 2008
My ipod won t charge
It could be 1 of 2 things. The first 1 I have had the experience of accidentally leavng my iPod plugged in charging for over a day. What happened...it killed the ability of the iPod to hold a charge & yes I tried with another battery & it was a no go. The second issue could be that your actual power supply cable has gone bad and won't work anymore. Now you didn't specify on which manner you're trying to charge it so if I didn't address your issue my apologies. There is a 3rd thing and no its not a combination of the 1st 2 I mentioned happening in conjuction...The 3rd thing could be that the power outlet you're trying to use doesn't work anymore so try another outlet plug.
Oct 23, 2013 | Audio Players & Recorders
Tip
Ipod not charging when i connect it to the usb port. or iphone.
If an alert says that your accessory isn't supported or certified. These alerts can appear for a few reasons: Your iOS device might have a dirty or damaged charging port, your charging accessory is defective, damaged, or non Apple-certified, or your USB charger isn't designed to charge devices
If your iPhone iPad or iPod touch won charge
How to Fix an iPad iPhone or iPod Touch That Won Charge Anymore
Help My iPad Won Charge
Help My iPod Battery Won Charge
ipod do not charging when connect it to the usb port Google Search
on Dec 06, 2017 | Computers & Internet
Ipod won't work with Pioneer DEH2500UI anymore. Worked fine at first but won"t even recognize the Ipod now.
Check the cable connection, they can go wrong and downgrade the signal so it doesn't recognise the device anymore.
Aug 04, 2013 | Audio Players & Recorders
Updated my ipod software and now it wont play on my home theatre system
This is always tricky with 1st generation iPod touches. After a while they can't handle the new software anymore and some functions won't work anymore. Maybe try to downgrade the software. Otherwise you should probably get a new iPod.
Aug 21, 2012 | Samsung Home Theater: HT-C5500 MULTI...
Cant unlock my ipod
What generation? What do you mean, the slide to unlock, or the screen lock? If you mean the screen lock, you should connect to iTunes, because some iPods unlock after connecting to iTunes. Otherwise you should reset it with iTunes. But then all your data will be lost. Otherwise you should try try try. You've got 10000 chances ;-) If you have an iPod Touch, you might mean the slide to unlock screen is frozen. I had that one time, after trying out spoken feedback. After that it locked the screen and the touch screen wouldn't work anymore. I couldn't do anything anymore, not unlocking, not turning off spoken feedback, not even turn off the iPod. I was lucky to find there was an update for the iPod so iTunes turned it off. Then it responded also again.
More details next time please!
Jun 22, 2010 | Apple iPod nano
I plugged in my i pod and came back a hour later and the screen was black and was frozen and none of the buttons would work
you will need to reset your ipod this will not delete songs. 1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold Menu and the Center button for at least 6 seconds, until the
Apple logo appears.
If iPod nano won’t turn on or respond
â Make sure the Hold switch isn’t set to HOLD.
â The iPod nano battery might need to be recharged. Connect iPod nano to your
computer or to an Apple USB Power Adapter and let the battery recharge. Look for
the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving
a charge.
To charge the battery, connect iPod nano to a USB 2.0 port on your computer.
Oct 21, 2009 | Apple iPod nano MP3 Player
Husband got Christmas ipod Classic wet
Hi what seemed to happen here is your HDD drive got wet and crashed. Yes take it back. Next time this happens the second it gets wet put it in a bowl of white rice. The rice absorbs the liquid and all better. But this time you can't do it. But yes take it back.
Jan 06, 2009 | Apple iPod classic MP3 Player
The new ipod nano
How old is it? if it's under warranty apple may fix it.
Simply, if you charge your iPod through you computer then the battery could be damaged. USB ports only put out 5 volts. If you have an AC charger that puts out 9.5 volts then consider charging it with that. Some AC adapters only put out 5 volts for the purpose matching the USB standard, but it's not good for the ipod.
Check out VaxTex @ http://www.vaxtex.com
hope this helps
Jun 27, 2008 | Apple iPod nano 3rd Generation
I charged it. And now it want turn on or even light up. I plugged it back into the compulter and it still want even light up.
My ipod was fine and then the battery died. Now im trying to charge it but it won't work, the screen is always black, and it doesn't even turn on itunes when i plug my ipod into the computer, what shoudl i do??
Mar 07, 2008 | Audio Players & Recorders
Frozen screen and different format
Hold the Menu and Center Button until the screen goes blank.
you will then see the apple logo and you should be set.
Nov 29, 2007 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
18 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
