Question about Dishwashers
Bosch Classic xx dishwasher; not pumping out, unable to release strainer to check for blockage.
  • dogand3k Aug 16, 2008
    Bosch Classic Electronic bought yesterday - put on Normal cycle & ran for 20 minutes then stopped - 3 lights on incl Check Water. Did the Reset, pulled filter out but was clear, turned off and on several times but still have a lot of grey water sitting there waiting to be flushed out
  • Anonymous Jan 02, 2009
    Exact same problem
Slimline classic xx bosh dishwasher not pumping out water??
Posted on Jan 17, 2010
Water salt and rinse buttons flashing on bosch tabletop classic xx dishwasher ?
Disconect power completely, wait 5 minutes, reconnect power. Still flashing, needs serviceman
Jan 12, 2017 | Bosch Dishwashers
Bosch dishwasher model SMV40T10GB/29. Scrubbing brush flashing on control panel. What does this mean?
I believe that is a no drain error. You can check to see if there are objects in the sump area like glass and food. If the water from the dishwasher can not drain into the air gap the dishwasher will be unable to drain. The sump is the area where your filter sits. You might have a bad pump or a blockage somewhere.
Mar 10, 2015 | Bosch Dishwashers
Dishwasher not draining
Check the strainer, then the pump. Debris can get stuck in the line to the pump.
Nov 28, 2013 | Bosch 24 in. SGS43C12 Classixx...
My bosch classic xx diswasher is not emptying - what should I do
Recirculate/drain selenoid may have failed. Remove bottom kick panel and watch selenoid durind exhaust cycle. If it does not open to all water to empty, it must be replaced.
Jan 05, 2012 | Bosch Dishwashers
Bosch classic xx diswasher not emptying
Open kick panel under front of dishwasher. With flashlight, observe drain selenoid during exhaust cycle. If it does not operate, it must be replaced.
Jan 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
The light for the drain glog is on and I lifted the strainer cover off and cannot get the light to go off or the machine to continue draining....
Hello & Welcome to FixYa
The light is on as the unit won't drain or is unable to drain due to blockage in the drain hose. This problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 22, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Where do I find the pcb on a Bosch dishwasher classic xx?
Check at front door top. You may have to open the screws around the door.
May 21, 2010 | Bosch 24 in. SGS43C12 Classixx...
I bought my bosch dishwasher just over a year ago and it is not working at the moment because there a red light on the say to check water
flow sesor problem, blockage in drain pump, or a leak all will cause check water light to come on i suspect a blockage as your appliance is new.
Jan 09, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch shv56c03uc/114 Water is not draining
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Apr 06, 2009 | Bosch 24 in. SHV56C03UC Built-in...
Dishwashers Logo
1,005 people viewed this question
Top Dishwashers Experts
