Question about Yamaha DV-S5350 DVD Player
Dvd player just freezes and wont do anything - Yamaha DV-S5350 DVD Player
  • 5 more comments
  • maryjom Aug 03, 2008
    I have the same problem - this machine has rarely been used (6 times in past year). Would like a solution. Thank you
  • schmel99 Aug 26, 2008
    dvd player used maby 15 times now started ok frooz up ,unpluged does it all over agian
  • tbebee Sep 18, 2008
    Our player which is a few years old just started this same behavior. At first I thought it was the DVD's from NetFlix, but each time we take the DVD to our old APEX player, it never encounters this freezing problem.
  • fixya-joem Oct 14, 2008
    When power is supplied, the front panel says WAIT for a moment and then goes black. Unit will turn on with remote. I get a TV program picture on the TV for about 2 seconds and then the TV goes black (I can see where the picture would be, so I think the unit has power on the output, just no content. The front panel shows 00:00:00. The unit freezes and will not respond to the remote or buttons. I must remove poer to reset.
  • Anonymous Nov 06, 2008
    My DVD is was rarely used until recently and now when we try to use it it freezes up and show multicolored vertical lines on the tv. The only way to unlock it is unplug the unit and restart it, but the same thing happens and in various spots of the DVD.
  • robipete Nov 11, 2008
    freezes after a minute with virt lines
  • Anonymous Jan 26, 2009
    I have the same problem and I have 3 different players. They start then stop no matter what player or disc I use.
I suggest the garbage can. I bought my husband the DVDR05 and it has not worked from day one. It will play about 15 minutes and then freeze up. We have read the book to see if it was something we did wrong. We finally shut off the tv and turned the player on before turning the tv on and we got half way through a movie that way. It is very upsetting.
Posted on May 24, 2008
I called tech support on this DVD player, and they had the solution. you have to reset the unit, but the way you reset the unit is quite unusual! You open the cover of the DVD, not the view screen but the cover of where you insert the DVD itself for playing, and then plug it into the wall and turn it on with the battery removed and the cover open, and leave it that way for at least six hours. The unit will work normally afterwards, just turn it off and back on and try it out. Mine plays now just like it used to. Seems like they could have supplied a hidden reset switch to save time but they didn't. Amazing...
Posted on Jan 12, 2009
I had the same problem with an relatively new DVD player (driving me nutz!) and searched all over the net for a solution. What worked for me was to open the DVD drawer and blow as hard as I could into the opening to dislodge any dust affecting the lens. Worked perfectly-- my player stopped freezing. Have played 3 movies since it started working again. I suppose a hair dryer would work even better but I was too lazy to go upstairs to get one. Good luck!
Posted on Apr 07, 2009
Take it to the man with the tool in his han!
Posted on Jan 11, 2009
Logik freeview no signal
freezing is a sign of poor signal , if you connect to cable , try a DVD player if the picture still freeze that mean the TV is bad and has to be returned and replaced. if the picture is good with DVD player as your service provider to give you a better service by boosting the signal
Mar 11, 2012 | Televison & Video
Freezing
It is most likly the lens try (very, very, very) lightly rubbing the lens (small round glass thing connected to a metal plate)
for any more help please pm me
Jun 18, 2009 | Denon DVD-800 DVD Player
Dvb t vcr/dvd recorder drvt 43 freezes after being plugged in
I have the same problem. Telephoned Daewoo and they said that there was a download available that will fix it. Unfortunately, the contol keeps freezing so I can't do this. Therefore, I have contacted the retail supplier and they are sending a replacement and also letting me have relevant info to send the defect one back. Hope this helps.
Jan 25, 2009 | Daewoo DVRS04 DVD Recorder/VCR
Player suddenly freezes
Try running a dvd cleaner through it first, before trying anything else (the type that looks like a DVD with a brush underneath).
The regular DVD might have been a fluke (scratches, rental?, burned dvd?)
Was there anything special about the new Blu-Ray Disc - what was the tile? On certain titles, you may need the firmware upgrade found at:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS300
Mar 07, 2008 | Sony BDP-S300 Blu-Ray Disc Player
Players freezes up after playing about 10 minutes
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 17, 2008 | Cyberhome CH-DVD 300 DVD Player
Zenith dvc2550 freezes up
Have you tried a diff dvd? also does the unit have anything on top of it? Overheating may be an issue.
Sep 15, 2007 | Zenith DVC2550 Multi-disc DVD Player
Player freezes at same time on almost every disk, and recorder programs won't play on anything else.
The last problem is probably because you have not ?finalized? the DVD yet. Basically what that does is modify how the data is stored on the DVD so that a normal DVD player can read it. It also prevents you from modifying or recording to the disk any more so make sure you?re done before performing this. The part about the freezing is more complex, are these commercially recorded DVDs or something someone else recorded?
Jan 01, 2007 | Samsung DVDR120 DVD Recorder
Yamaha DV-S5350 DVD Player Logo
362 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
