My Canon MF6530 is printing blank pages. No error messages, all 3 packing tapes have been removed. Absolutely nothing is being printed.
  • 22 Answers
Try putting the cartridge in and sliding it to the right to make sure it is making a good connection. Try to make sure the cartridge door is shut firmly as to open the Laser shutter which allows the laser to write to the drum. If the laser shutter is sticking this may help.
Posted on Apr 22, 2008
I use my MF6530 Laser Copier Printer to print checks and it will frequently print on the reverse side of the paper.
hai I give print to printer 2 side in single page, first two page print well but another two page print in opposite direction in the same paper (example1,2 page one side and 3 ,4 pages in other side but reverse direction. it mean you turn the paper to next side, you see opposite direction ) please help me to avoid this problem.
Jul 22, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Canon imageclass mf 6530 blank pages change toners still blank what is the cause of this problem
you have problem with laser shuter on laser unit. It needs to be fixed or replaced.
This is canons factory fault, and if the machine is under waranty call service.
Hope that helped!
Jul 19, 2010 | Canon imageCLASS MF6530 Monochrome Laser...
It prints blank pages
1.On new cartridge there is film overhand, which closes hole if you her(its) not remoove, will not enter air and printer will not print
2. Clean contacts by rubber for pencil
3. Sometimes exists not dense contact cartridge recommend to lay under laying on the part of for thick contact
Sep 28, 2009 | Canon imageCLASS MF6530 All-In-One...
Printing blank pages
My MF 6530 printer began printing light so we changed the cartridge and the machine began printing blank pages. When the other cartridge was put back in the machine, it too began printing blank pages. We have several of these machines in a couple of offices and have had this problem before. Canon is aware of the issue with this model, but I would like to know it as well. Can you help with what the problem is and the repair instruction? A friend of mine with this machine and the same problem, had called Canon and they had repaired it quite fast in his office. I'd like to do it myself in case it re-occurrs.
Apr 09, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Print but blank pages come out - changed the toner
I just had tech from Canon and replace a part that took hime 5 minutes. He said that the part replaced allows the image to appear on paper and it was a common issue.
May 20, 2008 | Canon Laserbase MF6530 All-In-One Printer
I am working on the same problem. While you will not like the
answer here it is for the canon mf6530. What is causing it
is the shutter over the laser is failing to open. There for
it blocks all exposer. A temperary fix is to carefully lift the
shutter and tape it open using black electrical tape. Then
try a few prints you should have an image if this is your
issue as it is mine. I do not recommending running it in
this condition very long. When I find the final answer I
will attempt to post it.
Jan 05, 2008 | HP DeskJet 880c InkJet Printer
Print out blank pages after clearing a paper jam
Have you checked the obvious things? Such as pulling the tape off the new cartridge? Also make sure the transfer roller under the toner cart. is in securely.
Jul 04, 2007 | Canon imageCLASS MF6530 All-In-One...
270 people viewed this question
jasbo
jasbo
