Question about Oster 76076-010 Hair Trimmer
Does anyone know how to fix oster horse body clippers?
  • yes what sort of problems are you experiencing?
  • 193 Answers
Yes definitely we service and repair regularly. view us at anglia clippers
Posted on Sep 06, 2009
Is there a tool to get the Motor housing back into the A5 clipper case.
No special tool you need to make sure you have removed the gear wheel in the gearbox, locate the armature inside the motor frame first then slide the motor housing complete with the armature into the body of the clipper sometimes you may need to twist a little to get it in. I have put a link below so you can see the parts I have mentioned.
http://www.angliaclipperservices.com/Clipper_Parts/Oster/A5_Golden
Dec 31, 2014 | Oster Turbo A5 2-Speed Horse Clippers W/10...
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Feb 06, 2013 | Oster A5 Turbo Clipper Kit-10,40 Blades&5...
I have oster titan clippers. The brass anchors for the blade mounting mechanism are pulling out of the plastic housing. How do I fix this?
ok if the brass inserts are allowing the hinge to move away from the clipper this will obviously cause a few problems, you will need to replace the body housing (new housing comes with a different design) you can view the clipper parts here
Aug 04, 2011 | Oster Golden A5 2-Speed Universal Motor...
Hi where can i sent my clippers to get repaired
Many people send clippers to www.angliaclipperservices.com most parts are in stock for Oster, Andis, Aesculap, Moser/Wahl, and horse clippers, the turnaround is only a week.
Jun 17, 2011 | Oster Golden A5 2-Speed Universal Motor...
Oster A-5 Golden clipper blade is not flush against the clipper so wont clip you have to hold the blade down tight so it will clip.
see if the blade and hinge have moved away from the body of the clipper, the two screws either side of the hinge assembly may need tightening, or the main body may need replacing,
If its just one blade then there must be a problem with that blade.
Oct 19, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster A5 clippers blades stop moving when put into the horses hair. checked without the blades, everything moves fine. Put new blades on, cleaned the silicone off with blade washed and have lubricated with...
How old is your clipper, Oster clippers need to be adjusted for more power and speed, also what clipper blade are you using to cut the horse hair and how long is the horse hair, Also the blade may not be sharp, some new blade are sharp maybe defective.
Feb 25, 2010 | Oster Golden A5 2-Speed Universal Motor...
Using T-84 Andis blade for horses and cutting
Check the two screws either side of the hinge assembly make sure they are tight, the problem appears to be with the clipper if all blades do the same.
Jan 16, 2010 | Oster Golden A5 2-Speed Universal Motor...
The metal blade fell off my O classic 76 shaver, how can i put it back on? it is the metal changing part
The part that holds the blades on came loose on my Classic 76 clipper. It turns out that the two holes for the inserts are too big. I fixed the problem by removing the inserts from the clipper body (easy since that is the problem), cleaned the inserts and holes in the clipper body and super glued the inserts back into the holes. Be careful not to use too much glue! It only takes a little.
Oct 31, 2009 | Sunbeam Oster Blade 918-306 Size Texturing...
My A5 clipper is not clipping at all.
If the blade mover is going when you turn the clipper on than all you need to do is take the blades apart and clean them well with a Oster spray and then oil them. I would recommend cool lube.
May 12, 2009 | Oster Golden A5 1-Speed Universal Motor...
Newbie Clipper needing advice
This is from the Oster book:
Changing Blades
To Remove: IMPORTANT- stop motor; push latch with thumb while lifting blade away from clipper and slide off tongue.
To Replace: turn motor on; insert blade on tongue fully and then snap blade into place.
Note: if the hinge is flush against clipper, lift it up with a screwdriver.
From me - Never take your blades apart to clean them. You can slide them one side to the other to get the hair out. (One little hair, can stop them from cutting.) You need to buy a can of clipper blade cool from oster or andis both are good, and it really helps to lubricate the blade and keep them cool while clipping. If you live near a dog groomer, petsmart or something of the like. Ask them to show you how to remove the blade and I know they will be happy to show you. I tried to submit an image from the book, but I don't know if it will get here or not.
Mar 31, 2009 | Oster Golden A5 2-Speed Universal Motor...
Oster 76076-010 Hair Trimmer Logo
82 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
