Bought a used gemini pl-90. light module works but dimmer does not.
2005 cavalier dash lights not working. all fuses are goood. replaced cluster, dimmer switch, multifunction switch
Back lighting or warning lights ? check engine , ABS , air bags , seat belt , oil light etc... ?
Interior Lamps Dimming
The second group includes lamps which may be dimmed. This group may use a combination of vacuum fluorescent (VF) illumination and incandescent lamps.
• Power window switches
• HVAC control head assembly
• Radio
• The instrument panel cluster (IPC)
When the ignition switch is turned to the ON position, the vacuum fluorescent (VF) display (radio) turns on at maximum brightness. When the park lamps are ON all incandescent back lighting turn ON at the dimming level indicated by the IP dimmer switch. At the same time all vacuum fluorescent (VF) displays dim to match the indicated dimming level. When the headlamp switch is placed in the PARK position, the park lamp supply voltage circuit provides an input to the body control module (BCM). The BCM then supplies voltage to the instrument panel dimmer switch through the instrument panel dimming lamps control circuit. The setting of the instrument panel dimmer switch determines the amount of voltage that the instrument panel dimmer switch supplies to the BCM through the instrument panel dimming lamps low reference circuit. The BCM then sends a pulse width modulated (PWM) voltage to all the interior lamps. All the vacuum florescent (VF) and incandescent back lighting lamps are provided a specific voltage and are then grounded. When the headlight switch is turned to the PARK or HEADLAMP position, all incandescent back lighting turn on at the dimming level indicated by the IP dimmer switch. When the IP dimmer switch is moved from MIN to MAX, all vacuum fluorescent (VF) displays, as well as all incandescent back lighting respond from Minimum intensity to maximum brightness in response to the IP dimmer switch.
I would have it checked for DTC'S - diagnostic trouble codes stored in the BCM !
DTC B2624 Display Dimming Input Range/Performance
The body control module (BCM) supplies voltage to the instrument panel dimmer switch through the instrument panel dimmer switch signal circuit. The dimmer switch varies the voltage and returns the new voltage to the BCM through the dimmer switch signal return circuit. The BCM uses this voltage to determine the illumination level of the instrument panel lamps.
DTC B2625 Display Dimming Pulse Width Modulation (PWM) Output Circuit Range/Performance
The body control module (BCM) receives a variable voltage from the instrument panel (I/P) lamp dimmer switch. The BCM uses this signal in order to vary the illumination level of the I/P lamps. The I/P dimming lamps output from the BCM is a pulse width modulated voltage supply used to light the I/P lamps. If a malfunction occurs in the I/P dimming lamps output circuit, this DTC is set.
DTC B2662 Park Lamp Switch Circuit Malfunction
The park lamps are controlled by the turn/headlamp switch. Positive battery voltage is supplied to the switch through the EXT LP fuse. When the turn/headlamp switch is placed in the park or head position, battery voltage is supplied to the park lamps. The body control module (BCM) is also connected to the park lamp circuit to sense whether or not the park lamps turn ON when the low beam or high beam headlamps are turned ON. The BCM also uses the parklamp battery positive voltage to power the instrument panel (I/P) dimmer output circuit. If the BCM senses that the low beam or high beam headlamps are ON and the park lamp input is not active, DTC B2662 sets.
Do the park lamps work ?
Jun 11, 2017 | Cars & Trucks
2007 Yaris daytime running lights stopped working. Dash lights stopped working.
The contacts in the light dimmer assembly module are burnt or have poor contacts.
- Take the keys out. Remove the negative battery terminal and wait 90 seconds.
- Remove the steering wheel (Note: Place the steering pad in upright position since it has airbag in it) in the center position and remove the light module.
- Remove the module lid and you will find 3 or 4 brass contacts in it.
- Clean and rub the contacts with #400 abrasive paper and install it back.
Good Luck.
Feb 10, 2017 | 2007 Toyota Yaris
DRL AND LOW BEAMS NOT WORKING, ALL FUSES AND RELAYS CHECKED
make, model, year? most likely the module & if no problem with wiring & connectors. try to unplug & clean terminals, then re-plug.
use voltmeter (or test light) to find out presence of voltages where expected when the switch is turn on .
Oct 09, 2015 | Cars & Trucks
I need a replacement for a rhine pl-190B
A PL-190B ceiling fan module is is a Wattage Limiter rated at 190W maximum. It is about 1" square and has a red, blue and white factory wired into the fan's light circuit in most cases. The AC power to the lights is run through the module to "ensure" no one puts more than 190W (about 2 amps)of light bulbs through the circuit for "safety" reasons. So four 60w bulbs and some CFLs will trip the module. These wattage limiters are sometimes feeding the fan motor in addition to the lights, however the units I have seen just control the "blue wire" going to the lights. Some suggest simply cutting it out and splice the blue and red wires (or blue and blue) that are left in the fan after removing out the module. If the module has two whites, wirenut them together separately. Otherwise just insulate or cap the single white.
At that point your ceiling fan and lights are like all others made before 2005 and depend on the circuit breaker and you to only use four 40w bulbs max in the fan. As indicated, some low wattage CFLs will also trip the module. Some internet sources have the PL-190B available for around $15.
Dec 31, 2013 | Computers & Internet
Instrument Panel Lights
Daytime headlight issue ? No , no sensor behind the front bumper . No Daytime time head lamp issue , doesn't turn on the instrument panel light's . This is more then likely a remote dimmer module problem .
Interior Lights Dimming Circuit Description (Pontiac)
When the park lights are on, battery positive voltage (B+) is applied via CKT 32 (YEL) to the remote dimmer module. The interior dimming switch in the lamp dimmer switch is a variable resistor which applies the dimming input via CKT 44 (DK GRN) to the remote dimmer module. The potentiometer in the lamp dimmer switch cannot provide enough current in order to operate the incandescent lights. The remote dimmer module amplifies the current, applying a variable voltage to the incandescent lights. As the amount of current increases, the lamps become brighter. As the amount of current decreases, the lamps become dimmer.
The radio, heater and A/C control assembly, instrument cluster, and passenger climate control each has a vacuum fluorescent (VF) display. When each module receives an input that the ignition switch is turned to the RUN position, each module activates the VF display at the full intensity. When the park lights are on, the radio receives the dimming level from an input on CKT 8 (GRY). The radio then relays this information to any other modules with VF displays. All modules with VF displays then adjust the dimming level of their VF display in order to match the level of the incandescent lamps.
May 16, 2017 | 1998 Pontiac Bonneville
Locator Light not working on leviton 6633-pl
6633-pl is single-pole and 3-way dimmer made for max 600 watt incandescent or halogen load. This dimmer does not work for CFL or inductive loads such as motor.
I have no idea what a 'locator light' is?? Do you mean the LED indicator that shows when power is connected?
Troubleshoot section of manual does not show any solution for LED malfunction.
Contact Leviton for email tech support:
http://www.leviton.com/OA_HTML/SectionDisplay.jsp?section=37619&minisite=10251
Aug 03, 2012 | Leviton Decora Light Dimmer Switch
The switch does not glow when the lights are turned OFF.
Pilot light switches are available in two styles, illuminated when off (to help locate the switch) and illuminated when on (to let you know the light is on - such as the case for an attic or basement light switch located on the first floor). You need to find the switch that provides the type pilot light you want.
Since you have the switch listed, you can add a module to make it work the way you want. You need a P&S #TM8LMCC8 "Snap In Light Module" to replace to narrow lower panel on the switch. The snap-in light module creates a night light effect and also causes the center of the knob to illuminate when the light is off.
Jul 12, 2012 | Electrical Supplies
I bought a Hunter fan Model 21778 that uses 2 incandescent candelabra lights. Before installing it I called Hunter support to see if it was okay to use a dimmer switch for these lights (I had already...
They're right, you don't want to control the whole thing with a single incandescent dimmer. First of all, the fan-speed and the lights will all be controlled by the same dimmer setting (dim low, low fan-speed - dim high, high fan-speed) - and the dimmer's not rated to control fans anyway which can result in exactly what they said.
There is a Skylark control, the S2-LFSQ- where half the knob controls the light, the other half controls the fan. The only problem you may (and most likely) have is that in order for that to work, between the electrical box for the dimmer and the fan, there needs to be seaparate wire run for the fan, and a separate wire run for the light so that the dimmer can individual control both.
If that's a problem, I recommend the MA-LFQM-, which includes a module that you install in the ceiling with the fan. The wall switch it comes with speaks to that module, and gives you independent control of the fan and light without having to install new wiring. I have one of those myself, I've installed one in one of my friend's houses, and they work pretty well and then you don't have to worry about what wires you've got in your wall.
Jan 19, 2011 | Lutron Skylark Incanhalogen Dimmer 600w ...
I bought dimmable energy saver bulbs and when I put the dimmer about half way down they flicker or go off. Why do they do that?
If the saver bulbs are of Fluorescent lamps type, they can not go to 0 even to 30% (depending on mains voltage: for 240V mains the range is bigger), because they need minimal voltage of about 80-100 V in order to keep the electrical arc. They vary the light level, but if by a normal dimmer give them less than about 80-100 V (max value), they will go out.
You have about 80% iconomy(compared to normal incadescent lamps) at rated voltage and it can be rased to 90 - 92% at minimum light, but not more.
You should use a special diimer if you wish to use the whole range for dimming.
Aug 07, 2010 | Electrical Supplies
Dash lights are not working
90% of the time if your dash lights are not working it's due to a blown fuse. Check your fuses for one labeled courtesy lamps. The fuse panel should be located under your passenger side dash. If all the fuses check out fine it could also be a problem with the dimmer switch. Try raising and lowering the brightness using the dimmer switch to see if this has an noticeable affect.
Apr 02, 2010 | 1997 Jeep Grand Cherokee
338 people viewed this question
 Grubhead
Grubhead
