Konica Minolta Di250 Imaging Unit
I need a new imaging unit on my copy machine and its gonna cost me 450 to buy one and get it installed. I can buy one online for 230 and install it myslef. I dont know how to install it or where to even find instructions to tell me. Is it worth it to have someone else do it or is it easy enough for me to do it myself?
  • pierrejoy Mar 18, 2009
    I get an error message on the screen"install the imaging unit"i dont know even what this means??Any manual please
  • 1,326 Answers
It is easy to install, it should come with instructions. It is like replacing a toner cartridge in fax machine. The counter for the IU unit is reset when you install the new drum unit, let it run it's setup it takes a few minutes. When it comes to READY you are done for another 60k copies.. Good Lucky
Posted on Apr 23, 2008
The imaging unit needs to be changed
Buy new imaging unit, part #4163-612
then follow instructions here: http://www.manualslib.com/manual/611548/Konica-Minolta-Di-200.html?page=56#manual
Mar 11, 2015 | Konica Minolta Dialta Di200, 200f, 250,...
Need to replace imaging unit . konica c252
http://www.precisionroller.com/imaging-units-for-konica-minolta-bizhub-c252/products.html
push down, slide out, pull tapes and fixtures off new unit(s) and replace. These IU's have chips in them to keep track of life. Another option instead of replacing the unit is to buy just the chip and replace it on the old image unit. This depends on the condition of the existing unit(s).
Jan 07, 2015 | Konica Minolta BizHub C252
Reset imaging unit on minolta copier
Can be reset but requires a fuse. And will require taking the bottom cover off the Image unit cartridge! SEE THE MACHINE WILL BLOW THIS FUSE INTENALLY TO VERIFY THAT THE IMAGE UNIT IS NEW :)
May 12, 2014 | Minolta DiALTA Di250 All-In-One Laser...
Replaced the K imaging unit. The new unit does not reflect it being replaced on the copier. Consumables screen shows the K unit at empty still.
"K" is refereeing to the black toner not being full.... I would replace the Black toner bottle. The toners do have a chip on them, you may have got a defective one..... Good Luck
Jan 08, 2013 | Konica Minolta KONICA BR BIZHUB C451...
How do I clear error message C-2558 for the Konica Minolta bizhub C253
As the Installation Manual and Imaging Unit replacement instructions mention, pay close attention to shaking the Imaging unit properly to level the toner and also keeping the Imaging unit level when installing it into the machine
Jan 24, 2011 | Konica Minolta bizhub C250 All-In-One...
Price of Konica Minolta imaging unit for Bizhub 162
You do not replace the Imaging Unit as a whole on this model. The Imaging Unit is made of of 2 parts. The Drum Unit and Developer Unit. If your "replace imaging unit" indicator is on then typically what happens is your local Konica Minolta or Independant service shop would come out and replace the Developer (aka Starter) in your developer unit and replace the drum unit part of your imaging unit. This must be done in sequence with resetting the counters in the service mode. If not done properly the counters will not reset or the new developer will fail to calibrate properly so copy quality will be poor or you will end up with a COF32 code. That being said, all I can tell you is that a fair price to perform this scheduled maintenance on the 162 is about $350.00. This will vary depending on local labor rates and how much the dealer marks up their parts. My current cost on the drum unit and developer is about $100 so you can use that as a general guideline in case some dealer tries to rip you off.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 20, 2010 | Minolta Konica Imaging Unit for DI350...
A minolta di250 gave the error message "the imaging unit needs to be changed. call your technical representative"
Then replace the image unit open the right side of the machine remove the image unit with the two handle and replace with a new one,
Jun 08, 2010 | Minolta DiALTA Di350 Laser Printer
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Nov 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta dirty copies
remove the filter and housing from the i/u and vac out the spilt developer, do the same on the underside, if background/halo is still there increase the seconary transfer value by 2 for plain paper
Jun 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
323 people viewed this question
k24674
jasbo
jasbo
