Question about HP Office Equipment & Supplies
Message on printer screen says Print cartridge cradle is stuck. Clear jam then press ok. We can't see where the jam is.
  • Michael Ede
    Michael Ede May 08, 2008
    My HP Photosmart 8250 cartridge cradle is stuck......I get a prompt like print cartridge cradle is stuck.Clear jam then press ok.
    What do I do please?I just replaced one of my ink-the yellow that was depleted.
  • mima953 Oct 16, 2008
    yes, my 8250 photosmart says the cradle is stuck. I did have a jam that I corrected.
Http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00738923&lc=en&cc=us&rule=5166&dlc=tr&product=443024
got to this web site
Posted on May 24, 2008
Hi there. I couldn't get the screen to accept my credit card details - so the problems has been taken to a repair shop. Hopefully someone will fix it somehow. Thanks. Mcfud
Posted on Apr 24, 2008
My printer keeps saying print cartridge cradle is stuck clear jam then press ok, but there is no paper jam
Because it's NOT a paper jam, but a cartridge cradle jam, I suppose it's an ink jet printer??? if so, check for debrie arround the cradle shaft that could prevent the printing cradle to move from left to wright... you could also lubricate the shaft by rubbing a little bit of grease on it with the tip of your finger (verry thin layer), as ink sometimes gets on it and tends to become sticky with time...
Aug 10, 2011 | HP Office Equipment & Supplies
Print Cartridge stuck
Look at the pad on the right side of the printer under where the ink cartridges are loaded. It may have ink deposits built up into lumps which interfere with the movement of the cartidges on the rod. Clean the deposits by scraping the lumps and removing all debris. This worked for me.
Jan 23, 2010 | HP PhotoSmart 7550 InkJet Printer
I reconnected my printer and it says..''Print cartridge cradle is stuck. Clear jam and then press OK''. What do I do? Where's the cradle? I'm messing with it and I got nothing. I HAVE to print out...
>the cradle is the carriage which hold your print cartridge.
>follow the steps on this link, this should resolve your issue
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00255616&cc=us&lc=en&dlc=en&product=397810
Sep 29, 2009 | HP Photosmart 8150 InkJet Printer
Paper cartrige cradle is stuck.
print cartrige cradle is stuck clear jam then press ok in hpphotosmart 7550
Sep 08, 2009 | HP Photosmart 8150 InkJet Printer
There is a print cartridge crudle is stuck...clear jam and press ok saying on the screen of my printer what should i do?i cleared the paper jam but it still says the same thing
Remove your cartridges, pull the power out see if the cradle moves freely around by hand. Check make sure that theres no paper that stayed behind. Did you rmove the paper by force? Maybe you dmaged the paper sensor.
Dec 08, 2008 | HP Photosmart 8150 InkJet Printer
HP8250 printer
Try this: Remove both ink cartridges. Unplug the printer for a few minutes. Plug it back in and re-install the cartridges.
Jun 26, 2008 | Office Equipment & Supplies
Print cartridge cradle is stuck ican't find where it is jammed
This might help . . . Mine finished printing one doc & then made a terrible noise & sent a message to my screen that "print cartridge cradle is stuck." When i opened door, i could see it was stuck off to the left side so left cartridge was obscured. I could not get it to budge, although i kept turning it off, gently pushing & turning it back on. Finally, i got my hand inside & determined that the little door to the left-side cartridge had popped open & was causing it to remain stuck. After some struggles (turn off printer first!) i was able to maneuver it around & close it tight. Now, all is well . . .
Apr 16, 2008 | HP Office Equipment & Supplies
Print cartridge cradle stuck there was a paper jam. That was cleared, but now it says the cradle is stuck and the paper does not feed please help print cartridge cradle will not move
Hi, I have a HP Photosmart 8050. Runs good till Now. 1, ONE Sheet of paper Jamed. THe RED Light Keeps Blinking Like crazzzy. I unhooked it to re-boot. It says Print Cartridge Cradle is stuck. Clear Jam & press OK. Iv'e L@@KED 4 anything. Nothing in way. I took the ONE sheet out. Still Nothing. It's Like my X-wife. 1 item wrong and a Bunch of ****. New Ink. Got Milk. Oh wrong Commercial. Got Fix. Retired Handi-capped sanior, Ron
Mar 17, 2008 | HP Photosmart 2575 All-In-One Printer,...
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
Cartridge cradle is stuck
I have had this problem with my 7550 for a while now and I finally found this on the HP website and it seems to have fixed my problem, I also replaced all of the cartridges:
Issue While printing from an HP Photosmart printer, the printer screen displays Print cartridge cradle is stuck / clear jam and then press OK . The printer may also make grinding sounds. This can occur after a paper jam when another printer part blocks the cradle. Solution Follow these instructions to adjust the clutch on the printer.
  1. Disconnect the USB cable.
  2. Press the printer power button to turn off the printer.
  3. Disconnect the power cord from the back of the printer.
  4. Open the top cover of the printer.
  5. Remove the print cartridges from the printer.
  6. Slide the cradle to the right side of the printer.
  7. Locate the clutch on the left side of the printer.
    NOTE: The clutch is a flat, white, plastic component that rests just above the white roller gear wheel. In the HP Photosmart P1000 and P1100 printers, the clutch is black metal. Figure 1: Printer clutch c00020494.jpg
  8. Remove the rear access door from the back of the printer.
  9. Press the clutch firmly towards the back of the printer, while rolling the wheels in the back of the printer upward two full rotations.
  10. Release the clutch and roll the wheels up two more rotations.
  11. Reinstall the rear access door.
  12. Reinstall the print cartridges and secure the latches in place.
  13. Close the top cover and reconnect the power cord.
  14. Turn on the printer.
  15. Print a test page.
Nov 27, 2007 | HP PhotoSmart 7550 InkJet Printer
378 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
