Question about Dryers
Getting ready to replace thermal cut off and both wires are red. I don't know which one goes where. Maggie
It doesn't matter, they can go either way.
Posted on Apr 22, 2008
  • 247 Answers
Thermal cutouts don't mind which way round you connect them, so provided you're confident that both of the wires you've got were originally connected to the old cutout, feel free to stick them onto the new one whichever way round looks neatest.
A.
How to wire a toggle switch for non working horn
My suggestion ask that mechanic to do it for you on the side maybe and see how much he would charge if you don't know anything much about going under the hood that would be best, if not here goes. First find the horn make sure you can get to it there should be a connector or plug on it should being the key word. Find it and remove it, you will need a wire long enough to run from the horn around and through some place in the firewall next to the wall between the engine and inside and back out to the battery so make sure its long enough to do that as well make sure the wire is 2 different colors inside sometimes they come copper on one side and silver color on the other or you can find black and red coated wires an 18 gauge speaker wire should work 15 to 20 ft should be plenty tape the ends of the wires with 8 inches excess hanging to the battery one end and the other to the horn not connected just so it holds the wire while you run it to inside the car string the wire around under the hood so its not all over the engine but around it and not on anything that gets hot to melt it. Make sure you know when you run it inside which side of the bend (you will have to bend it to get it inside the cab) make sure you know which side was going to the battery and which to the horn when you have the wire inside the car cut the wire on the copper side or the red side but dont cut the black shave back the plastic on the cut wire so you can get to the bare wire on the toggle switch any kind with 2 connectors on it is ok or you can also get a push button kind so it works like the horn find the positive connector on it and negative connector, connect the side of the red/copper wire that is going to the battery to the positive side if it has no positive or neg it doesn't matter either side then. Now connect the other side of the spliced wire to the negative or other side of the switch. once this is done under the hood look for positive and negative on the horn strip wire ends so you can get to bare wire connect the red/copper to the pos. and black/silver to the neg. You can use connectors for this or you can twist the wires around the connectors like a twist tie and tape with black electrical tape not clear tape. then on the battery put the red to pos. and black to neg. I would splice off enough plastic coating to wrap wire around battery terminal connector not the post make sure you connect the pos. last and don't touch the neg wire to anything else. then test the horn if it is working unhook the pos. side of the wire on the battery until you get ready for inspection and when done remove this so you don't have battery drain or other problems. Good luck
Nov 29, 2011 | Pontiac Sunfire Cars & Trucks
I am trying to take the back off of my Whirlpool clothes dryer model LEQ8611LW1 to replace the heating element, but the back will not come off. How do I get to the heating element?
The dryer doesn't have a removable rear access panel and the heating element is accessible through the bottom front panel. Using a flat-blade screwdriver, locate and release the two bottom front panel clips approximately 4 inches from the sides.
Once the panel is off, locate the heating element housing is on the right side and remove the hex-head screw from the heater shield.
Remove the hex-head screw from the side of the heater housing and slide the heating element out then slide the new heating element in and secure it with the hex-head screw.
Note:
The heating element is not necessarily busted and needs to be replaced when the dryer fails to heat up. The first thing to look at is the thermal cut-off. It blows open and cut power to the heating element if the high-limit thermostat is faulty. Disconnect the red wire from the thermal cut-off and the red/white stripe wire from the heater. Connect the red wire disconnected from the thermal cut-off to the heater terminal where the red/white stripe wire is disconnected from.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards.
Apr 01, 2011 | Whirlpool Dryers
Blower on my 06 caravan has stopped working, what do I do, all fuses have been checked and are fine.
open your glove box, squeeze in both sides and let it drop down. Directly behind there, is the blower resister, its approx. 3" x 1.5" with a 5/16 screw on each end and two wiring connectors. (one big one small)
Remove that, there is a piece of wire that runs from one end to the other on the back side that has a small bullet shape thermal fuse built into it (prob. red on one end). You can test for continuity with a multimeter on each side of the bullet shaped fuse. It is a thermal fuse that goes bad often. If you are handy with a soldering iron, you get one from Radio Shack and replace it for $1.49 (240/10a/144 deg) take the resistor and these numbers and they should be able to help you. Let me know if you need the specific R. Shack part #, I may have it at home.
Just clip the stiff wire ( don't cut at the base, I cut where the wire is bent at 90 deg. on each end to leave some to work with) and remove the old thermal fuse. Slip the new one in and solder it to the old wire and clip the excess. Tin your wires first with a bist of solder and work quickly so you don't overheat the new fuse. Too much heat could ruin it to.
Reassemble.
Hope this helps. (of course you could just buy a new resistor for $20-$30, probably an easier solution
Jan 15, 2011 | 2005 Dodge Grand Caravan
Hello< My dryer is spinning no
The problem when the dryer runs but doesn't heat is usually caused by a failed high-limit thermostat and a blown thermal cut-off both located on the heater housing. Verify this by bypassing both parts for troubleshooting purposes then running the dryer.
Disconnect power then remove the screws attaching the bottom front panel to the bottom flange of the cabinet. Slide the panel down and off the cabinet to access the heater housing.
Remove the hex-head screw from the heater shield and remove the shield.
Reconnect power then start the dryer. The problem is indeed with the two bypassed components if the dryer heats up. Replace both the thermal cut-off and the high-limit thermostat and it should solve the heating problem. Do not use the dryer with those parts bypassed due to high risk of fire hazards. Let us know should you need further advice.
Jan 11, 2011 | Kenmore Dryers
The unit light goes on but it does not heat. Therefore, we cannot make waffles.
Actually, I was able to contact the service center and Waring and was pleased to find out it was still under warranty. They are replacing it for us.
Dec 29, 2009 | Waring WMK300 Professional Belgian Waffle...
Griddles do not heat.
just fixed mine with info found on hear. If you're a little handy or have someone who is it's a simple fix. Under bottom plate a thermal fuse is connected in black wire under white insulation. I picked one up at radio shack2_bing.gif (http://www.radioshack.com/search/index.jsp?kwCatId=&kw=thermal%20fuse&origkw=thermal%20fuse&sr=1) got the 228 dgree C. I cut insulation and removed. I then cut black wire at connection at each side. I then placed new fuse in line and crimped small connectors on each side. Placed insulation back on and taped up. Screwed back together and it worked fine. Fuse cost $1.69. To think I almost tossed it.
Dec 28, 2009 | Waring WMK300 Professional Belgian Waffle...
Dryer heating element
To the heating element goes Red and Red with White.
To the Hi-limit thermostat goes Red with White and Black.
To the Thermal cut-off goes Black and Red.
Dec 11, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer Thermal Cutoff Wiring
the thermal cut off wires do not matter how you put them on.. The high limit is wired in series with the heating element.one red thick wire to element the wh/red top side of the high limit stat out of the high limit sat(other side) then goes to the other side of the heating element
Feb 20, 2008 | Dryers
Dryers Logo
87 people viewed this question
Top Dryers Experts
