Question about ViewSonic VA720 17" LCD Flat Panel Monitor
Troubleshooting ViewSonic Monitor
Thank you for your response. I have taken your advice and verified the monitor is working but just not visible. However, when I removed the back of the monitor and inspected the circuit card I found no signs of damage, shorts, etc near the seven (or so) capacitors or anywhere else on the board. Do you have any insight into which capacitor(s) may be the problem spot.
Also, I did some additional research on the board manufacturer Sampo. I found a couple of sources which identified this issue but stated that replacing the capacitor was only a very temporary fix and that the same issue would quickly occur due to an electrical short somewhere else within the board.
I have help with the troubleshooting and repair, but do not want to waste time on a wild goose chase lookibng for the bad component. Would I be better off replacing the board wether than trying to troubleshoot on a component by component basis? I'd appreciate any advice you can offer.
  • 472 Answers
It can be easier to replace the whole board, it's what they do quite often back at the service centres. There it is normally a cost/time issue. It can becheaper to replace the board then burn up even an hour to look for the faults.
If you decide to reppace the board, and you can find one, then try this...
Capacitors these days do not all show visible signs of damage, or shorting. They suffer a condition known as "dry caps" where the internal layers of the capacitor dry out, and one of the legs is not making good contact..hence lower capacitence.
Testing this is fairly easy. Just look for the stripe side (negative leg) and rock the capacitor with a small amount of force in that direction, then rock it back in the exact opposite direction. If one of the legs lets go under minimal pressure, then you have it.
If you find one like this, then replace the lot, hence the temporary fix some claim. It's because they replace only the ones that have gone now, not realising they will all fail around the same time..within 12 months at least.
If you can get a photo of the component side of your particular board then I can also probably point you to a few other spots to check. They use various boards in the same monitor..same schematics, then updated and revised as time goes by.
emailto:saitek@tpg.com.au
Posted on Apr 22, 2008
ViewSonic monitor is starting to go dark
See if your monitor has a brightness control. The manual is here...
http://www.viewsonic.com/us/support/downloads/search_user_guides/
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Nov 04, 2013 | ViewSonic VA1931WA LCD Monitor
Onscreen menu is blue
Check the User Guide, here...
http://www.viewsonic.com/us/support/downloads/search_user_guides/?prod_name=VX2255
Oct 28, 2013 | ViewSonic VX2255 Monitor
Screen goes black or pixelates
Aug 18, 2013 | ViewSonic VX715 17" LCD Monitor
Lost remote for ViewSonic 19" VX900 Monitor.
Please verify the model number since VX900 is just a monitor, it does not have any remote function, http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX900/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 13, 2011 | ViewSonic VX900 19" LCD Monitor
How do you take apart a vx2835WM Viewsonic monitor?
Very carefully. I only would do it after you have verified the warranty is expired per Viewsonic. If it is OOW, then you can call them for a service manual that contains schematics, troubleshooting flowcharts, etc.
Oct 28, 2009 | ViewSonic VX2835WM LCD TV
Viewsonic E72f+ OSD Locked
press and hold the 2 button... the button which has named 2 on it... for some seconds... maybe 10...
Jan 03, 2009 | ViewSonic E70f 17" CRT Monitor
VX900, Backlight Works, But no picture.
It is impossible to see defective components visualy, unless there was a serious burn-up or something like that.
Without at least a DVM you cannot even verify if the power supply is functioning properly!!!
There is no support at the component level service for these monitors. The service tech will change the main input board to solve the fault that you have. If the back plane lamps are failed, he will change the power supply for the back plane lamps. In some of these models, the back plane lamps are not replaceable. This means that the screen would have to be replaced.
If you want to service the monitor the non supported way, call Viewsonic and see if they will sell you a copy of the detailed schematics, and engineering data for the boards. Most monitor companies will not sell any schematics or service information to no authorized contractors for their service.
If you can have the details, get a digital scope, a DVM, a logic analyser, and start troubleshooting according to the service manual. This can involve hours of work to figure out the fault. Then you will have the task of seeing if Viewsonic will sell any of their proprietory EPROM's or processor type parts.
This is why when the warranty is finished on these monitors, they are not worth to send back for service. The shipping cost, plus the parts and labour can come out to more than the monitor is worth!
Jerry G.
May 18, 2008 | ViewSonic VX900 19" LCD Monitor
ViewSonic VA720 17" LCD Flat Panel Monitor Logo
135 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
