Question about Garmin StreetPilot c340 GPS Receiver
Reset button How do I open the front casing to access the reset button?
There is a small indentation at the top near the screen, put your fingernail in that and slowly lift the casing away
Posted on May 02, 2008
Where is reset button, or how can I reset a gateway 504GR
If you really do mean the reset button and not something else, it will be located on the front panel somewhere. If you can't find one, then your computer does not have one, there are many retail makers that save a nickle by not installing one anymore. In that case the only thing you can do is press the three keys: Cntrl/Alt/Delete to access Task Manager, then select reboot. OR for a hard reset hold in the power button for a few seconds and the computer will shut down, then reboot. I do not suggest doing this except in case of an extreme situation since it is possible (not probable) to cause corruption in the operating system.
If you are having problems with your computer, I suggest you join which is a free computer help forum. I hang out there as well as other techs who help people with their computer problems. In your case, post in the Hardware and Media section.
Jun 26, 2014 | Computers & Internet
Disable outside reset button
I don't know of any applications, but you could just use trial and error. Open up device manager, go down to the USB section, disable one of the items and try the button. It might take a while, but you will eventually find the right one and even if it resets on reboot, you know which one it is.
Mar 16, 2014 | Computers & Internet
Code error c0500
Open the front door, to the upper left there is a small access remove the plate press the button with the machine on that will reset the c0500 code if it comes back do NOT reset the machine it is telling you that it need fixing continue to do that can destroy boards worse case start a fire. YOU are resetting the code for the Fusing Unit which fuse the toner to the paper. GETS very hot normally.
Feb 07, 2014 | Minolta EP4000/5000 CS/PRO Copier
I have a Dell Demension 5100, and the power button got stuck. By stuck, I mean that the power button is pushed in, but not released. It's stuck as if you pressed the power button, but did not release...
if your PC have restart button then open your PC and check the power cable slots and change them into a reset mode removing reset cable to reset slots and attach to power slot. Then you can power your pC with reset button. If you can open front case then you can outside the button .
Sep 15, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
How to reset cmos or bios
Hello Friend,
There are a few ways.
The easiest way is to enter the BIOS setup screen, and select the option to reset to default settings, it should be easy to find or it would be on the save changes sections.
If you can not access the BIOS setup screen, it will take physical access to the computer's motherboard. This means you will need to open up the computer case. From here there are a few options that you can do.
change the the CMOS jumper to reset.
Press the CMOS reset buttion
Or remove the CMOS battery for a few minutes.
Please note that not all manufacturer have a jumper setting or cmos reset button. Also a CMOS battery looks like a button battery.
Also if you are going to open up the case, make sure the computer is off, unplugged, and if this is a laptop the battery must be removed. Good Luck!
Dec 20, 2010 | Computers & Internet
I forget my linksys wrt160N password. how can i open that.
In case you have forgotten the password,
You may reset router to factory setting from the reset button on the back side of the router. It may be a push botton or else use a paper pin to press the button for few seconds, the lights on the front would blink and the router would restart with factory setting. Please not that ALL SETTING WOULD BE LOST...AND YOU WOULD HAVE TO MAKE CONFIGURATIONS AND SETTING ALL OVER AGAIN
HOPE IT HELPS...Let me know if you need any further assistance
Nov 23, 2010 | Linksys WRT160N Wireless Router
DWL-2700AP reset default settings
Remove 13 screws from the perimeter of the back side of the DWL-2700AP and pull the covers apart. On the inside along the bottom adjacent from where the network cable plugs in, you will find a reset button. It is next to the white plug that leads to the antenna. You will need a flat screwdriver or something thin and sturdy to wedge between the casing and the reset button. While the AP has power, press the button and hold it in for a few seconds then release. Give it a few minutes and the factory defaults should be restored. Default IP:, Default subnet mask:
Jul 18, 2009 | D-Link AirPremier DWL-2700AP 802.11g/b...
How to do a hard reset on the router?
A Hard Reset (also called 30/30/30) makes your router go back to a Factory Default Settings.
It's very simple to do, but doesn't works in all cases.
With your router ON, press the Reset button for 30 seconds. Unplug the power cable from the unit WITHOUT releasing the Reset button and wait 30 more seconds. Then plug in the power again BUT KEEP HOLDING the Reset button for another 30 seconds.
It does not work in all cases, but maybe can help.
Sorry for my english.
Apr 02, 2008 | Computers & Internet
Forgot password. want to reset it. Could not access to admin page.
Try this:
1) Unplug the power
2) Push and hold the reset button
3) Plug in power
4) Continue to hold the reset switch for 30 seconds
Plug your computer into one of the LAN ports, TCP/IP should be set to get it's settings from DHCP.
Open a DOS window and type IPCONFIG
Note the gateway address - open up a web browser and go to address http://GatewayAddress < Put the number there!
The default pasword for this router is smcadmin < All lower case
Jan 12, 2008 | SMC Barricade g SMC2804WBRP-G Wireless...
I had similar problem with my LG DLG2532W gas dryer:
1) Power on machine:
- Check Filter light comes on (LG says this is OK at start)
- Time lights have all dashes
- All Program cycle lights on (Air Dry up to cotton towels)
- This is all normal
2) Select program cycle (cotton towels for example)
- Check Filter light now goes off
- Time shows 58 minutes
- Dry Level, Temp Control, etc are set automatically
3) Push start (this is where the trouble begins)
- The "drying cycle" light starts blinking (good)
- The dryer starts turning (this looks good...but)
- The ignitor (heating coil that ignites the gas) never heats
- The gas never comes on (because ignitor not on)
- No heat ever is produced.
Net result is dryer looks normal and runs, but there is no heat.
There is no error code...nothing to tell you anything is wrong.
Your only recourse is to call a technician because the manuals do not explain anything in any detail.
Thank goodness for the internet. I just needed the one clue that there was a reset button on the thermostat. That fixed my problem. Here is some more detail in case someone else is having this problem:
There are apparently two thermostats in the dryer. They are on the exhast tube that houses the burner element and the ignitor. One is on the top half of the exhaust tube near the dryer wall and the other is on the bottom half of the exhaust tube toward the center of the dryer. The one on the bottom half of the exhaust tube in the one with the reset button. Before pushing the reset button PULL THE PLUG ON THE DRYER OR TURN OFF CURCUIT BREAKER. The reset switch is between two wire leads that go to the thermostat and you will probably shock yourself if you try to push the button with the power on. If you open up the right side access cover on the dryer, then you can see the exhast tube. It is about 5 inches in diameter and (looking thru the right side access port), it will be sloping up from left to right as it runs from the front of the dryer to the back. You can see another exhaust tube further away from the port and lower down, but the one you are looking for is closest to you and higher up. If you look back toward the front of the machine (left), you can see two wires hanging down from the opposite side of the exhaust tube. The wires run to the thermostat which you can also see on a bracket standing off the exhaust tube. In between the two wire leads that run to the thermostat is the reset button.
Bottom line....pull off right access port cover, look in and left for thermostat hanging down off of exhaust tube. Press button between the two wires going to thermostat. It is a 3 minuite operation if you can get to the right side access port.
If you cannot get to the right side access port, you can pull off the fronf of the dryer and get to it that way, but it is much harder. You start by popping the dryer top by pushing in a putty knife between the top cover and front cover about two inches away from the top left and right edges of the machine. This is tricky and takes some fidling. I just pryed mine open the first time, but now I see how it is supposed to be done. After popping the top, you can take off the front of the machine. There are two screws on the top and then two more on the bottn half of the door. You have to open the door to get these two screws out. There are some wires going to sensors and switches that have to be disconnected.
It is much easier to access the thermostat thru the right side access port.
Aug 23, 2007 | LG DLE0332 Gas Dryer
Garmin StreetPilot c340 GPS Receiver Logo
53 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
