Question about DISH Network 301 DTV Receiver
Satellite dish receiver error LNB Drift detected
Have two dish 110 and 119 signal on the 119 Channels error test detect LNB Drift detected
  • otherone77 Apr 10, 2010
    Im a dns tech and changed all lines in house,changed lnbf(tripple 1000.4),changed 222 reciever and still getting lnbf drift
    Problem Solver:
  • 8 Answers
That's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
Posted on Aug 13, 2008
  • 51 Answers
Actually both responses would be considered correct, except at this point with new software lnb drifts should no longer cause issues with receivers. lnb drift is a fluctuation of signal frequencies to the "crystal" in the feed horn. with current software ability to watch tv will not be effected by this
Posted on Aug 29, 2008
Call Dish.
If it is showing + or - 5 on your system info screen, then you need to have the LNBF replaced.
Posted on Apr 28, 2008
I have a foxstat -HDR humax box and I am getting no or bad signal on the TV downstairs. I can get some channels but not all.
I suspect that the box upstairs is a Freesat box; a Freeview box requires a feed from an aerial, not a dish.
The problem you are seeing may be caused by water in the cables, if they are not sealed at the LNB. The LNB may be failing, but dish misalignment is more likely.
As there is an unused output on the LNB, try swapping one of the feeds with a poor signal to it.
Jul 27, 2015 | Humax Televison & Video
Dish network receiver model 512 switch test says I am getting fewer sattelites than previously detected
were you getting all the Satellites before? could be Tree limbs in the way (very very common) could be the Dish had moved.. rotten boards, etc make sure the dish is mounted solid. could be the LNB gone bad. or coax has corrosion etc, many things can cause it. but usually a easy fix..
Jun 08, 2014 | DISH Network Vip 222k Hdtv Satellite...
Humax Freesat was working fine then lost signal and now is not reognising postcode. We have unplugged/repluged, checked all cables (all OK) and tried to restart but as it is now not recognising postcode...
This can happen if the dish is slightly misaligned. I believe the postcode tables are read from a satellite which is about 0.3 degrees away from the Astra satellites. If your dish is slightly misaligned it may not be able to receive it correctly, also the following is the standard procedure which you've probably already been through, but I hope it helps:
1. Freesat Detection Fails / Invalid Postcode
  • Unplug the Foxsat-HDR from the mains and unplug the cable from your dish which is connected to the LNB IN
  • Check that the "F-type" connector is firmly on the end of the cable.
  • Power on the and follow the Installation Wizard again.
2. If still not Detecting the signal or verifying postcode
  • Select NEXT through the Installation Wizard and then FINISH at the end.
  • Press the OK button to enter the SETUP menu and Select Manual Tune.
  • Select the following Transponder (11428 H 27500 A) from the list of Transponders.
  • Check that you are receiving stable levels for both Signal Strength & Signal Quality or >50%.
  • If you are not receiving sufficient Signal on this Transponder then you may require an installer to check your
    Dish Alignment, LNB, cabling, or connectors.
Nov 16, 2017 | Humax FOXAT HDR DTV Receiver
We got home from a trip and have no signal, did reset, called tech support they say they had to send out a tech in a week. did a test and it says we have less satellites than previously detected??
Hi my name isMike Houston of DISH Network and I see when you got home from your trip therewas no signal. With it saying "you have fewer satellites than previouslydetected" means you will not have all of the channels in your package, if youwill please e-mail me at michael.houston@dishnetwork.comI will be more than happy to assist you.
May 01, 2011 | DISH Network ViP 612
I have Dish 322 receiver. Everything was fine; a week or so ago satellite 119 reception was spotty, now we can't get 119 at all. We get 110 but only about 34%. Sometimes the receiver will power itself off...
It looks like you have lost the signal for the 119 satellite from your dish. Are you getting an error message, either 002 or 015, saying the satellite signal has been lost or acquiring satellite signal? First, check the cables on the back of the receiver to make sure they are secure. You can also run a check switch test to see if there is a problem between your dish and receiver.
Press the Menu button on your remote. This will bring up the Main Menu on your TV screen. Input the numbers: 6 (System Setup), 1 (Installation), and 1 (Point Dish). On the right side of the Point Dish screen are 3 buttons. Select the Check Switch button. Within the 2 large boxes are satellite numbers and green or red boxes. Make a note of the satellite numbers (should be 119, 110), the trans, the device, and switch. Super dish and alternate should not be checked. Select the Test button on the bottom of the screen. If a box pops up with a warning about TV 2, select Yes. It will now run the check switch test. Let it complete the test. After completion, the screen will automatically go back to the Installation Summary screen. You may get a message stating that the Check Switch test has found fewer satellites than previously detected. If you get this message cancel out of each screen (do not save the results) till you are back to the TV screen and it is acquiring Satellite signal.
If you don't get that error message, see if the information on the Installation Summary has changed. Then select Done on the next 2 screens and cancel out of the others till you get the message, Acquiring Satellite Signal. After it finishes acquiring satellite signal and downloads the program guide, see if you are getting a picture - try different channels. If you still have problems, please email me at, If you are still experiencing problems, we will need to send a technician to fix the problem.
Ray Calo
DISH Network
Apr 23, 2011 | DISH Network 322 DTV Receiver
I have a dish tv disk at my home. I have troubling in dish tv channels just few channels are working like star news zee action national geographic and some channels like colors sony max tv are working in...
The problem with checking signal strength is you have to know exactly what sattelites are used and what transponders there on. dish net uses 119 and 110 and sometimes 61.5 your best bet is to check sattelite menu. Hit menu once that comes up hit button number 6, then button number 1 then button number 1 again. then you have to run a test switch its right in the middle, If it finds anything or low signal there will be a check details or error message in red on the bottom of the screen, it will tell you exactly what is wrong. Also one more thing is you can go to menu then hit button number 6, then number 1, then number 3. If the signal is good on the t.v. then it is probably what they call L.O. Drift or Lnb drift which that check will tell you, this is common for older dish systems especially super dishes, which are the big dishes if this is it then you have to schedule and appointment and they will upgrade your dish. If this is too much to take in, you can always call customer service they will walk you through the same thing step by step.
Sep 04, 2010 | DISH Network 311 DTV Receiver
Hi. I need help finding 119!
I looks like you are picking 110W with the LNB on your left if you are facing the dish.
Try to get 119W first if you connect the cable to the 119 LNB, once you find 119W that way, you will also have 110W.
Good Luck.
Feb 24, 2008 | RCA DISH Network(r) 311 Satellite System
Dish 311 won't detect switches
dishnetwork is kind of tricky on the detect switch thing. sometimes if you are having troubles on just one receiver you have to run detect switch over and over again, sometimes as much as maybe 20 or 30 times. if it still doesn't work, hope you have a service plan so they will send you another unit to switch out. also try a different LNB ( low noise block downconverter) and check switch a few times. i know that sounds kind of stupid, but it works sometimes.
Feb 17, 2008 | RCA DISH Network(r) 311 Satellite System
Lost locals thru multiswitch
Do you have at least a 2-channel LNB on your system?...accordianman
Oct 15, 2007 | Samsung SIR-S4040R DirecTV DTV Receiver /...
DISH Network 301 DTV Receiver Logo
2,578 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
