Question about Frigidaire 9 cu. ft. / 255 liter Chest Freezer FFC09C3A
Compressor Stopping When I turn my Frigidaire chest freezer on, the compressor will run for about 5-10 seconds, then stop. Freezer, in turn, can't cool. Please help?
    Scholar:
  • 149 Answers
Compressor is running overloaded possible problems bad relay/overload /capacitor dirty or clogged condensers if the unit uses a condenser fan suspect a bad fan. and defective thermostats are notorious for short cycling. id check the coils first and if dirty clean up maybe that can be the major problem.
Posted on Apr 23, 2008
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
FRIGIDAIRE CHEST FREEZER WILL NOT FREEZE FOOD OR KEEP FROZEN
Hello Cory Mitchell - If your freezer is not cooling, it could have a floating restriction in the lines or something more complicated like an issue with the seal system that only a professional can repair. This can conclude the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines at incorrect levels to properly cool. If the compressor was running, humming or even a little warm then that was typically normal. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and the door. Now close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing. If it proves to be ineffective, connect with a professional to accurately pinpoint any potentially more serious issues.
Feb 13, 2013 | Frigidaire FFFC07M2KW 7.2 Cubic Foot Chest...
Have magic chef mccf5wbx freezer compressor runs but shuts off in 15 seconds
Check condensor not clogged up, fan working etc. If all ok, try new capacitor and relay. If all else fails, replace freezer (compressor replacement is costly)
Aug 07, 2012 | Magic Chef Chest Freezer MCCF5WBX
Compressor comes on for about 3o seconds then trips off
possibly thermal overload located @ compressor wiring... this is normally due lack of refrigerant back to the compressor from low refrigerant or restricted metering device.
Aug 24, 2011 | Frigidaire 15 cu. ft. / 425 liter Chest...
Freezer has quit freezing only a little over a year old. manufactor date 6/2009 compressor is running will only cool down to 50 degrees thermostat set on coldest.
Is the compressor continually running? If so then there could be a leak in the system or the compressor is damaged. If it's running then stopping, the cold control (thermostat) could be damaged.
Mar 06, 2011 | Kenmore 15 cu. ft. Chest Freezer 16542
I have a chest freezer model AFFC1526DW2 it stopped freezing. The power light is still on. What could be the problem
the thermostat may not be turning on the compressor.
Do you hear a buzz and or clicking every few minutes when plugged in? If so the compressor is trying to start indicating a problem with the compressor. you could check the windings for continuity or a short and then try a 3-in-1 start kit.
May 05, 2010 | Frigidaire Freezer FFU1724
Chest freezer model mfco5mobw4 been plugg in for 2 days now set on the coldest setting not getting cold compressor is warm
God day,
Either the refrigerant has leaked out or the compressor isn't pumping properly. If you can put your ear up to the unit and it hums that is the compressor running.
No practical repair possible unless the unit is under 5 years of age in which case you are entitled to factory warranty service.
Apr 29, 2010 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire chest freezer- the compressor tries to start for three seconds or so and then the circuit breaker for the outlet trips.
This sounds like a bad overload relay or locked up compressor. If you are very technical, you can do some troubleshooting by checking to see if the compressor pulls "locked rotor" amps when it tries to start. This information should be on the unit nameplate and will be listed under "LRA". This requires special testing equipment (an amprobe). Also check for any bad connections at the plug and the terminals where the cord terminates inside the electrical compartment on the freezer.
Something else to try is to plug the freezer into a different electrical outlet and see if the same problem occurs.
If the freezer is over 15 years old and the compressor is bad, it will not be worth the cost of repairs.
Dec 30, 2009 | Frigidaire 13 cu. ft. / 368 liter Chest...
Used frigidaire
look around the back of the freeze and at the bottom you will see a small black compressor .Put your hand on it and if it is running you will feel it vibrating. If it vibrating but running very hot them it means you have no gas in the system so the freezer won't freeze. If the compressor is cold and not running then it could be eaither the relay on the compressor or the board on the front either way you will need to get an engineer in
Dec 11, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer not working
compressor is faulty. clicking noise you hear is the overload for the compressor. not worth repair and not diy
Mar 18, 2007 | Frigidaire 5 cu. ft. / 142 liter Chest...
Frigidaire 9 cu. ft. / 255 liter Chest Freezer FFC09C3A Logo
300 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
