Question about WatchGuard Technologies Firebox 1000 Firewall
Can't connect firewall
After run quick setup wizard, it gave me temp IP address 169,254.236.184/24. my computer is 169.254.236.183, crossover cable plug in trusted port and my computer. but I can't connect it
  • 42 Answers
Have you checked the subnet? i.e. 255.255.225.248, make sure both PC and firewall are set the same.
Check the firewall settings on the PC, for port 80, 8080 & 443 and the ip address of the unit if you connecting with web access.
Try to up the IP on the PC to 169.254.236.185, it some times does not like being before the device.
Aslo, some times the PC needs to have the network port reset, as windows keeps the old IP address, but shows the new. The quick way to check this, is to disable the network connection and then enable it again.
Posted on May 09, 2008
Unable to connect windows xp and windows 7 using crossover cable.
Your laptop ip address setting is correct now there is reason not able to ping windows xp and windows 7 have firewall you need to enable file sharing form windows firewall. Go to control penal > windows firewall > advanced settings > inbound rules and enable file and printer sharing.
Jun 15, 2012 | HEWLETT-PACKARD HP 630/P6200 Notebook
Can't communicate with Linksys WAP610n from laptop via straight or crossover cable. Fixed IP network won't find WAP610n either.
If on Xp go onto start then run in run enter cmd this will open a command prompt in dos
then type in ipconfig and check settings if the ip and dns settings seem incorrect then type ipconfig/release then ipconfig/renew this will reset the system hope this rectifies your problem
Mar 01, 2011 | Linksys by Cisco WAP610N Wireless-N Access...
Cannot connect to the internet on the Toshiba Netbook. Has very strong network signal.
Troubleshoot the issue by identifying the ip address that your computer has. May it be wireless or local area connection. Check IP Address thru command prompt or DOS.
· press <windows key>+<R>
· type "cmd"
· press ok button. a black box will appear
· type "ipconfig /all" then press enter key
· locate wireless connection and local area connection group by scrolling up/down.
NOTE: ignore highlighted physical address.
If the ip address is 169.xxx.xxx.xxx, this is an invalid ip address. Contact Internet Service Provider. If the ip address is 192.xxx.xxx.xxx, click start and open control panel. then open internet options. click on connections tab. click on lan settings. Make sure no tick box checked. All set your anti virus' firewall settings to default. Then try browsing.
I hope this works for you. KINDLY REPLY IF FURTHER ASSISTANCE NEEDED. Good Luck!
Mongkey
"Understanding explains better..."
Jan 27, 2011 | Computers & Internet
Connected to d-link network which is unsecured. how to secure?
You need to setup a password for the wireless connection,
1. Connect D-link Router to your computer
Your computer should be connected to the LAN port of using an Ethernet cable.Power on the router after connecting the router to your computer.
2. Log on to D-link Wireless Router
To logon to wireless router type the default IP address of the router on the address bar. The default IP address of the D-Link router is 192.168.0.1
Before log on to the router it will ask you the user name and password. For a default D-link router
User Name : admin
Password :admin(Flip the router over to know the default username and password)
3. Click on Setup Wizard
To configure the router in an easy way click on the button Setup Wizard.
4. Click on Launch Internet Connection Setup Wizard
To configure the internet connection in this D-link router, click on the button Launch Internet Connection Setup Wizard.
holygrass_21.jpg Now the wizard will show you what steps it is going to complete while running the wizard. Click Next to continue.
holygrass_22.jpg 5. Create new Password For your router
holygrass_23.jpg Setup wizard will prompt you to create a new password for your WBR-2310 Wireless Router. After entering the password click on next.
6. Select your Time Zone
Now the setup wizard will prompt you to select your time zone.
holygrass_24.jpgPost .
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | D-Link Computers & Internet
HOW TO LINK LAPTOP TO PC
If you wish to connect your laptop to your PC for sharing the resources and files. You can use Either a Wireless network or Ethernet adapter. Since you are looking for a small setup (I guess so). You can configure an ad hoc network.
Most of the latest laptops comes with a Wireless card and and ethernet card. However in the case of PC's there might not be a wireless card. If you are looking for portability and working from distances (say from the other room) then you can buy a wireless card for your pc and setup a small wireless network.
Okey let us see how to setup an ethernet connection (it's a wired connection between your pc and laptop to enable networking between them)
You need to make sure both your computers have an ethernet port and you need a Crossover cable to connect between them (get at least 3 meters so that it will be more comfortable.)
A similar port will be there in your laptop too. Connect your crossover cable to both pc and the laptop (you can buy a cross over cable from most of the local computer shops).
Now you need to setup the ip addresses for both the computers.
Let's set 192.168.1.1 for your laptop and let's use the same ip as a gateway. We will be using 192.168.1.2 as the ip address for your pc and the same gateway (192.168.1.1). Now let's see how to setup IP Addresses
With the following instructions you can fill the above values in both the laptop and pc by individually repeating these instructions given below. Once you set both the ip addressess and gateways your network is ready to go. (You don't have to worry about the dns addresses since we are setting up a small network of two computers)
In your case the connection name will be unknown or something like that where as in the image it is Internet.
If you are on Windows Vista or Higher, Go to Control Panel (Start menu -> Control Panel)then click onNetwork and Sharing Center and you can see your active connection there; click on the View Status
Then a new dialog box will appear; click on the Properties button there
once you have in the properties dialog box; double click on the Internet Protocol Version 4 (TCP/IPv4).
Now you will get a new dialog box where you can insert your ip address, gateway and dns.
Now you are all set and ready to go.
If you have trouble following this solutions please mail me at nextdoornerd AT gmail DOT com and I will help you.
Jul 28, 2010 | Network Computing Devices (NSH800S/A)...
I want to change my username and password..i have wi-fi connection.and my router is from d-link.
To reset your wireless router to the default, hit the the reset button
46e1c92.jpg Whenever you want to configure your network or the DI-514, you can access the Configuration Utility by opening the web-browser and typing in the IP Address of the DI-514. The DI-514 default IP Address 192.168.0.1
· Open the web browser
· Type in the IP Address of the Access Point
Type admin in the User Name field (lower case)
Leave the Password blank
Click OK
The Setup Wizard page is the first page that appears when logging into the web-based management interface. The Setup Wizard is a utility used to quickly configure the DI-514. It will guide you through four quick and basic steps to help you connect to your ISP. You will be connected to your ISP (Internet Service Provider) and have Internet access within minutes.
If you need the entire user manual, follow this link and choose Product Manual. You can download a zip file with the manual in it.
http://www.dlink.com/products/?tab=3&pid=DI-514&rev=DI-514
Mar 12, 2010 | D-Link DI 514 Wireless Router (DI-514)
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
I'm looking to hookup the DVR with the PC via A cross-over cable
I have 2 DX2000's, In order for you to communicate with your pc, you need a Crossover cable, if you have a laptop or computers, connect the crossover cable to that, set your ip address on your computer to 192.168.2.108, (Note: since you never configured it, this would be the default setting). If you have the manual this is in there.,
Another method, if you don't have a crossover cable is to set the ip on your computer to 192.168.2.110 Subnet, 255.255.255.0. its a little more funky, the crossover would be easier, once you get in, then go to the configuration page and setup up the IPaddess for the DX2000, the Gateway to your Router and the subnet mask, once you do this, then you're able to get to it on your network, by typing in http://xxx.xxx.xxx.xxx:8004 .
Dec 26, 2008 | Pelco DX2000 Series 16-Channel 80GB DVR
Can't connect
it might probably a security issue , can u remember from which machine and from what ip you access the firewall before ??
Try to assign the ip from which you have last accessed your firewall
Good luck
Nov 20, 2007 | SonicWALL PRO 100 Firewall
WatchGuard Technologies Firebox 1000 Firewall Logo
281 people viewed this question
Top WatchGuard Technologies Computers & Internet Experts
David Payne
David Payne
Are you a WatchGuard Technologies Computer and Internet Expert? Answer questions, earn points and help others
