Question about Cell Phones
How do I replace the LCD screen on my i885 cell phone?
    Genius:
  • 3,422 Answers
HI,
The first thing is the availbility of the screen part.You will have to contact the manufacture for this.I strongly suggest you not to replace it by urself it requires certain tools and you will have to take your phone apart.The best thing is to get it repaired or replace it if is still under warranty.
Goodluck..
Please don't forget to rate the solution
Posted on Apr 25, 2008
  • Priya darshan Apr 25, 2008
    OK,i have got two cool links which may help you out.
    Please CLICK HERE
    Please CLICK HERE
    And also you will need a T-6 screwdriver to remove the inside screws.Please CLICK HERE for more info.
  • 3,037 Answers
Check out this video at the following link
http://www.wonderhowto.com/electronics/iphones-pdas-cellphones-video/how-to-replace-the-lcd-screen-on-a-nokia-6280-cell-phone-162782/
Since all cell phones are fairly similar, you should be able to replace your screen just like the one on the video.
If you get stuck or need any more help or pointers, please let me know and I will address them
thank you
  • Benjamin Patri
    Benjamin Patri May 03, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of how this website works and in order to receive any credit in helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
    Genius:
  • 2,035 Answers
Do can get fixed in a local cell repair center or can find parts on e-bay, and get it it fitted manually
  • Anand Kumar
    Anand Kumar Apr 25, 2008
    1. Remove faceplate. ( FOLLOW INSTRUCTIONS FOR REPLACING FACEPLATE )
    2. Remove damaged LCD by taking pointed tool and lifting clips on all four corners of the LCD one at a time, until the LCD is removed. Look at damaged LCD to see which direction the contact strip (sponge with wires)is facing to replace the same direction.
    3. Insert contact strip into LCD, if using your hands make sure they are clean first, oils and dirt from your hands can damage the contact strip. The contact strip is inserted the same way the strip is in the screen you are removing, some face up some face down. LCD usually includes two contact strips, in case of corrosion.
    4. Replace new LCD wide metal frame is top. Remove plastic protective cover on screen, do not touch screen, LCD will snap into place. Remember to check that the contact strip is installed.
Unlocking motorola phone
See www.cables4phones.co.uk for free codes
Apr 21, 2014 | Motorola Mobility (BT60) Nextel i580 i880...
How to remove lcd screen on kyrocera hydro
  • Remove the battery cover from the back side of the cell phone. Remove the battery from its compartment and set it aside.
  • Use the screwdriver to remove the Phillips-head screws from the back panel of the cell phone. You may also need to remove the antenna from its retaining slot and remove it from the cell phone if you can
  • Separate the back panel of the cell phone from the rest of the cell phone's body. Place the cell phone face up and then remove the cell phone's faceplate from the rest of the cell phone. This should leave the LCD screen, keypad and circuit board completely exposed.
  • Tilt the LCD screen downward and then disconnect the LCD screen's ribbon cable from the LCD screen and set the screen aside.
  • Repeat this procedure in reverse to replace the LCD screen and reassemble the cell phone.
Mar 17, 2014 | Boost Mobile Kyocera Hydro Smartphone
Country lock code of motorola i885
You can get the country lock code for your Motorola I885 either from your service provider or from online sites. Theunlockarena.com is where i unlocked my phone. Check it out!!
Sep 02, 2012 | Motorola Mobility i885 Cellular Phone
I need the steps to replace the lcd screen.
Many cell phone users wrongly sell, or give away their cell phones when the LCD screen cracks, breaks or goes bad. Removing and replacing the LCD screen yourself is much cheaper than buying a new phone. Most cell phone parts or components can be purchased online at cell phone repair website such as CellularDr.com or Cellphonesshop.net. Replacing the LCD screen yourself, however, may void your warranty agreement.
Switch off phone,
Get a screw driver and unscrew the top where the screen is located,
(screw is located when flip is open).
Carefully remove screen from hook(when it is Pinned too),
Fix the replacement screen and screw back necessary screws on the phone.
And your Dawn.
Good luck.
Jul 15, 2010 | LG TRAX Cellular Phone
Sell nextel i9 i877 i876 i880 i580 phone
GOSTARIA DE SABER COMO TIRAR CODICO ESPECIAL DE NEXTEL
Jun 03, 2009 | Nextel i860
W810i Broken Screen
Check out the following link for instructions for replacing your broken w810 LCD screen and link to buy the LCD screen from ebay.
W810 LCD Screen Replacement
I hope that helps out
May 10, 2009 | Sony Ericsson F305 White +512MB Unlocked...
Nexel i885 backlight not working
I think what u might have 2 do is call the Boost costumer service and have them maybe restart the whole phone for u. Maybe if they were 2 restart ur phone it might work again
May 09, 2009 | Nextel BOOST i835g i835 LTD. ED UNLOCKED...
Motorola i880 white screen flashes i880 won't charge
the i880 & the i885 needs a quality charger, if you get a original Motorola charger IT WILL WORK. There are some aftermarkets that will work, but not many.
Mar 24, 2009 | Motorola Mobility i880 Cellular Phone
I HAVING TROUBLE UNLOCKING MY PHONE
http://www.tanbigo.com sell:
NEXTEL IC902,IC502,IC402,I930,I885,I880,i876,i870,i860,i850,i836,i833,I830,
i760,I730,I95,I90,I60,I530,i335,I580,I265,I670,I560,I205,i450,i455
Housing/mainboard/flex cable/lcd/lens/keypad/spare parts /battery/rotor/flip
if you are interested in our oem products,please contact us.thanks
We look forward to have a pleasant cooperation with you!
Tanbigo Industry Limited
Email:Jack@tanbigo.com
MSN:Jack@tanbigo.com
skype:jack881138
Jul 02, 2008 | Nextel i730
Cell Phones Logo
293 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
