Kenmore washer Water keeps filling into the tub even when the timer is pushed in to the off position.
  • 247 Answers
Assuming that it's clean water (rather than dirty water siphoning back out of the drain), I think you need a new inlet valve.
If your machine has both hot and cold water feeds, you'll need to find out which one is still feeding (easiest done by turning the supplies off one at a time while listening whether it makes any difference). If it only has a single feed hose, you're spared that bit of faultfinding.
Look at where the feed hose attaches to the washing machine. The threaded inlet is actually part of the body of the inlet valve. Remove whichever cover gives you best access to this component (on front loaders, access to this bit is usually best from the top) and replace the valve with a new one. They're not normally outrageously expensive.
A.
Posted on Apr 22, 2008
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series washer. As the tub tries to
It sounds like you have a bad timer. If you change the position of the timer and it does not change what is going on the the timer has to be bad. However I am not certain what you mean by the agitator turns all the time. Is it agitating while spinning and draining?
Apr 15, 2010 | Kenmore Washing Machines
While my kenmore top load washer is pumping water into the tub, water is splashing from the rim of the tub and leaking behind the tub onto the floor. If before I turn the washer on I push the tub towards...
if it keeps failing into that position
then either your machine nneds to be releveled or there may be someting wrong with the suspension but with this model i would have to believe your machine is out of balance tword the front
relevel and try that.
Oct 27, 2009 | Washing Machines
Tub fills with water......that's it.
This is probably a bad timer motor.
Two screws on right/left of head, flip head back. You will see a small motor on the timer that operates when the timer is set. If this isn't running, then you need to replace that or the entire timer. Probably easier to change just the motor.
Best luck in your repair
Joe
Aug 09, 2009 | Kenmore Washing Machines
Kenmore W/D #110.88762793 keeps filling w/ timer in any position
If the washer does not shut off when filling, the pressure switch is usually the culprit. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
In many cases, the only problem is the air hose comes loose from the switch, or is cracked or punctured somewhere. If the air hose is intact, and the electrical connections are good (no broken, loose, or corroded wires), then I would recommend replacing the switch. The part is available at searspartsdirect.com. Just go to the website and type in the model number you have provided and go to the "Washer/Dryer Control Panel" heading for itme number 13 (part #3952465). I hope this helps you. Please let me know if you require additional assistance.
Nov 10, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 80 Series Model 110.20862990 Type 111
no the timer doesn't control the water fill the pressure switch does you have three possibility's either the pressure switch is malfunctioning or a water valve is hanging open or the pressure switch pressure hose is leaking or off the tub the pressure switch is connected to the knob that lets you select the water level in the tub if you back out the two screws on the front or back of the end caps depending on the model you can pull the control panel forward and tilt it back to access the pressure switch its gold in color and has a clear latex hose attached to it also take the hose loose and blow through it to make sure its clear with the washer empty of course lol if you need more info just reply to me be glad to help water can also leak out from the pressure switch hose if a mouse has chewed through it or its come loose from the tub
Mar 18, 2008 | Kenmore 24902 Top Load Washer
Kenmore 70 Series Top Loan - Fill Cycle won't stop when full
Does the water stop when you push the timer in or are you having to shut the spigots off?? If it stops when the timer is pushed in then you have a problem with the pressure switch. There are quite a few tricks to axcessing your machine's components but if you are handy ill attemt to help.
Jan 12, 2008 | Kenmore 24032\24036 Top Load Washer
Agitator always moving
The inner tub on some machines does rotate very slowly while filling to assist with the even distibution of the load. If the agitator is turning back & forth while in fill mode, you could have a timer or transmission problem. You need a tech.
Nov 04, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
