    Problem Solver:
  • 9 Answers
Problem with the lights or the lens
Posted on Apr 24, 2008
While attempting to install Diablo 2 LoD on my Windows 8.1 laptop, I keep getting this error message: Line # 855, Unrecoverable internal error 6fe22flb Help!
Sounds like you could be having a reading error with the disc, I recommend you try another CD if possible, if not you could download the torrent online, and use your own serial key (that way it isnt illegal, and you are able to play it without the CD)
Nov 09, 2014 | Blizzard DIABLO 2: LORD OF DESTRUCTION...
While it's plugged in to PC in the PC start session dos screen appear and saying S.M.A.R.T. error. I formatted(Write Zero) device with WD Diagnostic Tool(9 Hour) in DOS and HDD Low Level Format Tool 4.30...
after inserting the disk just click on eror .
click on fix errors .
if this does not works its a physical can save it first and then run it as soon as you insert the disk
Nov 03, 2013 | Western Digital 2TB WD ELEMENTS USB...
My HD SAMSUNG HM500JI not work any more bad sector that cany be fix...!!!
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
Follow these steps to fix Disk Read Error::
1. Run CHKDSK /R /P from the recovery console (it will typically find no error)
2. run FIXBOOT from recovery console (typically has no result)
3. run FIXMBR from recovery console (typically has no result)
4. Run the manufacturer's diagnostic utility, downloaded from their website (it will typically find no error)
5. Changing the drives from cable select to Master/Slave may fix it.
6. Replacing the data cable may fix it, but usually not.
7. Setting the BIOS to use defaults may fix it, but usually not.
8. Changing the BIOS drive settings from auto to user-specified, ensuring that LBA is selected may fix it.
9. Pulling the CMOS battery to let the BIOS lose it settings may work.
Some helpful tips::
  • Update the drivers for the device
  • Install the latest Windows service pack
  • Fix registry errors with Reginout
  • repair install of Windows
If problem still occurs then Replace the hardware
May 04, 2012 | Acer Computers & Internet
Unrecoverable scarn error X6650 series
The " unrecoverable scan error " indicates a scanner hardware problem. Please contact Lexmark Technical Support for assistance.
Feb 03, 2012 | Lexmark Office Equipment & Supplies
Windows vista is unable to format DVD+R and with a other burner program I get the following error: 19:17:00, File(cl_DVDData.cpp), Line(193) -> Begin burning process Current drive: <G:...
have had this problem myself and wasted many discs you need a new burner but there is a work around to this problem
just leave the disc open so that more data can be added and no more problems
Jan 05, 2011 | LG GP08NU20 DVD±RW Burner
Lacie External Hard Drive FAILED
Just format the drive and u will be able to use it.
Jun 07, 2010 | LaCie (301015) 120 GB Hard Drive
Computers & Internet Logo
610 people viewed this question
David Payne
David Payne
