Question about Nokia 1100
My nokia 1100 phone shows not charging please give me solution
    Problem Solver:
NOKIA 1108 NOT CHARGIEG
Posted on Jul 23, 2010
    President:
  • 1,561 Answers
Check with another charger to see if it will charge, if it is still same problem, the problem is from the charging port on your phone.
You will need to replace or change the charging port on your phone to solve the problem.
Take the phone to any local phone repairer to help you replace the charging port on your phone, the cost is next to nothing, this the solution to your phone not charging.
Take care.
    Genius:
  • 1,478 Answers
If your phone is not charging, try use a similar charger to charge to see if it is charger problem, if the similar charger did not charge your phone, it means the problem is the charging port on your phone.
The charging port of your phone is bad and will need to be replace. Replace the charging port on your phone to solve the problem of your phone not charging.
Once the charging port is replaced, the not charging problem with your phone solve.
Take care.
5 Suggested Answers
SOURCE:
SOURCE: how to reset the security code of nokia 1100
you willbe uese the cod *H7370H or new soft
Posted on Aug 07, 2008
nonontech
  • 4737 Answers
SOURCE: my 1100 mobile phone showa not charging
There are several reasons, like bad battery, bad charging connector, bad charger, charging pin problem, charging ic, etc..
You need to try with another charger and with another battery. If changing the charger and battery don't help, follow the instructions below;
First, remove the battery, clean the contact points on the battery and also clean the battery interfaces on the mobile. You also need to check the charging connector and clean whatever is possible. Use soft brush or cotton with Ipa solution or alcohol/spirit/acetone to clean all the metal contacts. Try charging again.
If the above method don't help, you need to change the charging pin;
Still the problem persists, then check the charging ic. Perhaps jumpering will be necessary.
If you are not sure what you gonna do with ic, I don't recommend to play around with it, rather take it to a mobile repairing shop or nokia service center and get it fixed. You may damage another components.
I wish you good luck.
Thanks for using FixYa.
Posted on Jul 24, 2010
jjee
  • 16 Answers
SOURCE: showing not charging display on screen when we hold for charging the mobile.
cause of the fault sometimes is in the charger it might not compatible with your phone try to use another charger, if the fault remain, refer it to service personel, I suggest it is the charging pin problem try to replace it, or maybe in battery terminal should fix the contact to battery.
Posted on Jun 24, 2007
  • 86 Answers
SOURCE: nokia 1100 shows battery low even after full
your mobile battery is dull check battery first by using another mobile
Posted on Jan 18, 2010
Nokia 1100 not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 01, 2010 | Nokia 1100
Nokia 1100 shows battery low even after full
Jan 18, 2010 | Nokia 1100
Nokia 1100 invalide sim
well dont mess with it u just need to call you phone service company and they will give you your sim code/puk code samething
Jun 24, 2009 | Nokia 1100
Charging problem of my nokia 1100
THAT IS THE PROBLEM OF UEM IC OF YOUR PHONE CHANGE THAT IC
Apr 18, 2009 | Nokia 1100
Nokia 1100 charging problem
my nokia 1100, i forget my security code, my imei # is 358363004376018
Apr 12, 2009 | Nokia 1100
China mobile jumper images
nokia 7210 charger not supported
Dec 20, 2008 | Nokia 1100
NOKIA 1100 CELL PHONE WON'T WORK
I am unable to find the security codeof Nokia 1100. so wat I have to do... Plaese give me the solution...
Nov 18, 2008 | Nokia 1100
Not charging for nokia 1100
when u conect charger if its shows NOT CHARGING,, its uem fault and u cant change uem. its better to use universal charger
Aug 11, 2008 | Nokia 1100
try replacing the charging unit on the phone
Jul 07, 2008 | Nokia 1100
Nokia 1100 Security Code Lost
i dont know the master code works for 1100 . even though the code is otherwise give it to nokia care cenetr for security code reading they charge 75 rs
Dec 05, 2007 | Nokia 1100
Nokia 1100 Logo
1,017 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
ASHRAF CA
ASHRAF CA
