Question about RCA L37WD12 37 in. LCD HDTV
L37WD12 turns off by itself after 15 minutes.
I have a L37WD12 that turns itself off after about 15 minutes. People have told me it may be the power supply. I unplugged it for a few hours like the manuel says but still have the same problem. The set is just over a year old. Can someone please help????
    Scholar:
  • 21 Answers
Hi there, Im Kanth, i had the same problem, and i found a person in Mississauga, they fix all kind of problems in Plasma, they fixed my LG before a 7 months, its still running good, i came to know lots of ppls were having same problems, i sujest u to being the plasma to electronics @ Dixie and Britannia Mississauga, call them now 905 565 6595 or check there wesite for more info. http://dukeelectronic.com
Posted on Apr 22, 2008
TV - Mitsubishi WD-62530 Will not power up unless first unplug from wall for approx. 15 minutes prior to turning it on or it will not power up at all).
Start with changing the capacitors that look bad on the PS board...I think you will find some that are bulged when you take the cover off, should be a easy and cheap fix
Oct 22, 2017 | Mitsubishi Televison & Video
RCA TV will turn off by iteself and come back on by itself like every few minutes.
Hi!
That's a clear indication that you have a bad power supply in your TV.
If you know how to DiY...I suggest you open your TV. Locate the power supply section, it is where the end of the power plug is connected. Replace all blown or bulge or leaked capacitors with same value. That will fix your TV problem.
The hardest part is to disassembling your TV cover, cause you will need to pry off the snap in lock at the edge of your TV.
Power supply board should look like this. Examine the capacitors in the board
After replacing blown capacitors...it should work again.
Things you will need.
1. A plastic flat end screw or any object with flat ends....to fry off the cover
2. Soldering iron.
3. Soldering lead
4. Soldering pump.
5. Flat and Philip Screw
6. Replacement capacitors (of same value with the blown one) that you can buy to any electronics store.
Hope it helps
Mar 06, 2012 | RCA L37WD12 37 in. LCD HDTV
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
L37WD12 tv won't turn on, for a while if you unplugged it and then plugged it back in it would turn on and work fine but if you turned it off again you would have to unplug it again, well now no matter how...
Tv was have a failing power supply before.Now toally have dead transfer voltage to the rest of the tv circuitries.The tv power suuply board.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | RCA L37WD12 37 in. LCD HDTV
Toshiba 27af45 turns off by itself every 15 minutes..how do I fix
I think the timer setting in your TV is broken. Try fixing this.
May 07, 2009 | Toshiba 27AF45 27" TV
Need a power supply for RCA L37wd12
This power supply might not be manufactured anymore or the only place to find it is by calling RCA but that is a pricey board. You can also check this website and ask them if they have one. It appears like they do not have stock but you can call them just in case they have not updated the site.
I can also help you in repairing the defective power supply if you still have it. Write to jah2mil@hotmail.com if you need further assistance.
Apr 04, 2009 | RCA L37WD12 37 in. LCD HDTV
RCA L37WD12 37 in. LCD HDTV Logo
189 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
