Question about Philips 55P8341 55" Rear Projection Television
Cannot adjust colors
Have a philips 55p8341 model. Has a red picture that cannot be adjusted. Where can istart to fix the problem?
  • Kevin Pierce
    Kevin Pierce Jun 04, 2008
    I may have the same problem with mine, I can still see the picture, but it is all red. Could I just need to chage the CRT fluid in the blue and green? I change the fluid on a similar tv and doing so took care of the white halo's. When I go into the red convergance, I can see the cross, but when I go into the blue all I can see is a light blue blob..... Makes me thing the the fluid is contaminated. Also don't have any sound, but I don't think that those two problems are related.
  • 121 Answers
Sounds like your red tube is getting a short I can post you a web sight and they have used red picture tubes
http://servicemanuals.vstore.ca/
Posted on Apr 23, 2008
Fixing the picture in my Philips rear projection tv
As far as mostly red--turn color to zero and examine screen--if not gray or black and white it may need the screen controls adjusted.
Dark---with back cover off clean the three lens this model has--they are the light source for your picture and if dusty picture will be darker and somewhat dull looking.
Answer is based on brand/model number listed here.
May 16, 2012 | Philips 50P8341 50" Rear Projection...
Can I get instructions on how to change out the different color coolants for the philips magnavox 55p8341 rear projection tv?
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 26, 2011 | Philips 50P8341 50" Rear Projection...
I have color issues no matter how i adjust the color it stays an orange color
You have fluid in all 3 of your picture tubes on that model and the fluid in the Blue and Green has become contaminated just from usage and age. A technician usually charges about $250.00 to 300.00 to replace it. The Red very seldom ever goes bad because it runs the coolest in the spectrum. After that, you'll be good as new.
Nov 27, 2010 | Philips 55P8341 55" Rear Projection...
Need the default coloring for the Philips 55P8341 tv
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 16, 2010 | Philips 55P8341 55" Rear Projection...
Tv cloudy and faces are red
TV needs CRT coolant replaced, once this is done the focus and color level of each CRT needs to be adjusted for optimum picture. expect to pay around $300 good luck, Julio at Millenium TV , Las Vegas NV (702) 736-1091 milleniumtvsvc@gmail.com
Jul 21, 2009 | Philips E-Box FTR9965 DTV Receiver
Color adjust
Greetings!
Adjusting the picture tubes is a scary proposition, but since you have already done it...
The easiest way to balance the gray scale is to turn the color all the way down on the set. The next part is easier with two people if the screen controls are on the back of the set. This is the part you saw that has six small knobs on it. There are control for the focus of the red, gree and blue and for the screen level of the red, green and blue. You will want to adjust the screen controls in an effort to get the picture black and white (this is why you turn the color down), hence the term "gray scale". Just make slight adjustments, take your and be patient. It will take some time, but you will get your picture balanced back out in time.
Hope this helps!
Rob
Jan 15, 2009 | Philips 50P8341 50" Rear Projection...
Philips 50P8341 50 in. Rear... Problem:
You CRT coolant needs to be replaced, its a very common problem with the phillips and magnavox projection TVs. If you need more info on the Coolant Change let me know.
Jul 14, 2008 | Philips 55P8341 55" Rear Projection...
Philips projection tv
Sounds like the red CRT is defective. But could be the red drive circuit also. If you turn the color level to zero is the picture red or black and white. If the red/orange is still there i would suggest its the red CRT. I have a source for Phillips CRTs that cost 135.00 with free shipping. If you end up needing one let me know and I will post the link.
Apr 21, 2008 | Televison & Video
PHILIPS 50P8341A COLOR PROBLEM
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 15, 2007 | Philips 50P8341 50" Rear Projection...
Philips 55P8341 55" Rear Projection Television Logo
78 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
