Question about Zebra 110XiIIIplus Direct Thermal/Thermal Transfer Printer Motherboard
White space between labels
I have a 110xiIII plus label printer, it was printing fine yesterday and today there is white space between labels! i chacked the label size and setting. HELP!
  • Level4 Apr 28, 2008
    I do have exactly same problem. Printer prints every second label, even I have set correct label size.
  • 33 Answers
OK, guys, I spent some time with this, and you have to do this:
If you use ZebraDesinger, go to File-Printer settings-Advanced Setup-Calibrate
The printer will need approx. 40cm of the paper (labels) to calibrate where is the begining.
After that it was working good.
Just make sure, you have input correct With and Heigh of the label.
How to do that?
-get into Label setup wizard
-choose the printer -> click on NEXT
-choose stock type and stock name (I have ALL and <NONE>) -> click on NEXT
-set Height (count with space between labels, so measure from the start of the label, till start of another and Width. -> click on NEXT
-set other settings -> click on NEXT
-set width and heigh (this time without space between labels)-> click on NEXT
-Finish
then calibrate the printer and enjoy your work.
Posted on Apr 28, 2008
Z4MPLUS doesn't recognize the MEDIA(LABEL) automatically.
you should recalibt=rate the printer.
Are you sure that your previous label was not longer?
With the autocalibrate function activated the printer should try to detect the correct length. If it doesn't the yoou have
- A problem with the label border
- Preprinted stuff which the printer detects as to fo feed
Dec 09, 2013 | Zebra Z4Mplus Label Printer
Using MS Access, I am printing labels to a Zebra 110XiIII printer. The output truncates the label to 2" instead of the 3.5" I have the report page settings saved as. I have been through the setup...
First check printer. Change setting "Print Width" to maximum width, save. Switch off. Hold down pause key while switching on (untill all but power light turns off). the subsequent prints should print across the full width. If this is OK fault is with label format.
If you are using windows printer driver check settings there this can over ride printer settings. If using ZPL the problem is most likely in the label format.
Jul 05, 2011 | Zebra 110XIIII Thermal Label Printer
We presently have a Zebra 110XiIII Plus Printer that we use for printing labels containing Text and Bar Codes from an MS Access based application. Our current printer comes with a Roll of paper, and labels...
@ gould804.
I have the same model printer and utilizing it the same way with text and bar code. My issue is not the the font but rather the text is not printing, only the bar code. Maybe we can contact and work with each other to resolve both of your issues. let me know?
Nov 19, 2009 | Zebra 110Xi III Plus Thermal Printer
I have a zebra 110XiIII Plus 300 DPI printer that is randomly printing blank reciepts. It's connected to the computer via a USB cable. There is no rhyme or reason to the blank printing, just does it...
This is usually caused by the sensors being dirty or the printer needing calibrated. Blow off the media and ribbon sensors and also do a manual calibration. If it is still skipping after this then it is software related.
Jun 11, 2009 | Zebra 110Xi III Plus Thermal Printer
The 'eye' won't read the space between the labels,
recalibrate the sensors and check your label lengths and gap size
Mar 31, 2009 | Toshiba TEC B-472 Thermal Label Printer
MY TLP2844 SKIPPING LABELS HOW CAN I FIX IT
try feeding just one label the 2 or 3.
if the printer feeds fine, check the format.
there is an unprintable area top and bottom of the label to reflect tolerances on the printer.
I usually like to keep the format 1/8" top and bottom spacing.
If you software, check that you do not have the printing too close to the edge.
Dec 12, 2008 | Zebra 110Xi III Plus Thermal Printer
Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Dec 04, 2008 | Zebra 110Xi III Plus Thermal Printer
I-class cutting issues
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Label printers are always finicky. I have strtix printers where I work and they give off wacky errors too.
Sep 19, 2008 | Datamax DMX-I-4212 Label Printer
Zebra 110XiIIIplus Direct Thermal/Thermal Transfer Printer Motherboard Logo
284 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
