Question about Brother IntelliFAX 5750e Laser Fax
Copies and incomming faxes are blank - Brother IntelliFAX 5750e Laser Fax
    Genius:
  • 2,120 Answers
Take your drum unit out and inspect. It just might be out of toner. Look at the silver pins that contact the drum unit.
Posted on Sep 30, 2008
Panasonic kx-ft981 ,no print out and copy.
Panasonic kx-ft981 ,dark print out and copy.
Jun 23, 2012 | Office Equipment & Supplies
Not receiving incoming Fax
is the number for incoming fax correct and setup properley
Sep 11, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Hi, my incoming faxes are coming through blank -ink levels are fine as I did a copy and it came out properly. Please help. MFC 495CW model
i think this problem is not ur side try to receive fax from one another number
if same
just clean mirror and a withe rod with a clooged cloth and try aging
Aug 03, 2011 | Office Equipment & Supplies
When sending a fax to someone the copy they receive has a white line through it. Our fax transmittal report also shows the white line through it. I've cleaned the glass above the scanner unit, blew through...
This is an indication that you still have something on the scan glass. Most likely some white out from an original or something. You can test for this by making a copy. If the white like is present but your incoming faxes are ok then it is in the scanner. You are going to have to look at this section very closely. Pay attention to which way your documents are scanned, is face up or face down. This will tell you which side (top or bottom) the strip glass is on. Sometimes it is stuck to this glass pretty good.
Again tho if you incoming faxes are ok, and you run a copy with a thin blank line then it is in the scanner assembly.
Dec 14, 2009 | Office Equipment & Supplies
Incoming faxes are blank outgoing faxes work ok. toner has been changed
Hello sir; Try to make a copy, if copy is OK then replace a new phone cord .if copy not OK still blank, that's means high voltage supply board have problem.
Oct 12, 2009 | Canon L120 Fax Laser Printer
DOES NOT PRINT INCOMING FAX- PAPER COMES OUT BLANK
Have you tried a new toner cartridge?
Did you pull the plastic tape on the cartridge?
Mar 21, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Blank vertical stripes on incoming faxes
1st. Print a report. If the blank stripes are still there, you must remove the drum and t6oner combination and clean the laser glass located on the bottom of the machine.
If the blank stripes do not appear, then the fault is on the scanner of the sending fax machine.
Feb 25, 2008 | Brother IntelliFAX 2800 Laser Fax
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Brother IntelliFAX 5750e Laser Fax Logo
43 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
