Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Clothes lost in machine
The machine will not go through a full cycle and displays an unbalanced message or someting like that and seems to be not working - how do I get into the talk to get my wife's bra and socks back?
  • Kellie Fisher
    Kellie Fisher Nov 08, 2013
    Samething happened to us with the LG HE top loader. Lost 4 pairs socks, thrmal pants and some cotton boxers all in one load. somewhow got themn back in the next washer load.
  • 246 Answers
There are 2 clips (green) between where the front panel and the top come together. (use a flash light to help locate) Take a metal putty knife and push the clips towards the rear while lifting on the corner. (This is difficult as you have to work each side up a little at a time) On the top of the tub, there is a white plastic tub ring that snaps on. Remove this by pushing down while GENTLY bening the tabs out. In the middle of the basket there is a small white cap, pry it off with a flat head screw driver. Under neath there is a bolt. Unscrew the bolt and lift the basket out. (careful, the outside or the basket is sharp) Your clothes should be underneath.
Posted on Jun 15, 2008
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
On the spin cycle, it makes a banging noice, rythmic, about 2 per second....only on the spin cycle... can you help???
The spin cycle is used to rid the water by centrifugal force. As the tub spins, the water iis forced out of the clothes. The banging noise comes from the weight of clothes being on one side making the load unbalanced. The machine will absorb some minor unbalancing. If it gets real loud & the machine starts dancing, shut the machine off by raising the lid, when tub stops, rearrange clothes.
Louie Almond
Mar 27, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer has an error message "uL", the washer is full of clothes and water; but won't do anything...what should I try?
Unbalanced load uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute
the load.
Mar 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Noisy when trying to spin. display uL instead of time remaining. Stopped, opened lid and redistributed load. Started up again. cycle continued but still displaying uL. Not sure if load still unbalanced?...
REPLACE YOUR SUSPENSION RODS. You can get them at a discount applicance parts store online for about $60. Our washer is about 8 years old and has been getting unbalanced on every load. I replaced the suspension rods tonight and and it solved the problem.
Jan 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Vibration of wash machine
Hi!
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
May 22, 2009 | Danby Washing Machines
Knocking in washer
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
126 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
