Question about Freezers
No ice saved
I have kitchenaid superba ice machine, that makes ice, but the ice melts as soon as it has been cut into cubes. will not save the ice. MODEL KU1S15NRHB6
    Scholar:
  • 150 Answers
Your problem is slow production. this unit does not refrigerate the ice. the bin is but an insulated storage device so the ice is constantly melting away. the output should be somewhere around 50 lbs in 24 hours which is more than the capacity of the bin so it should fill up and shut down on a full bin within that period. unless of course it is on your back deck facing west in july! these machines are very finicky. many different things will affect production make sure you do the system clean trip at least every 6 months more often if you use alot of ice. also check the condensor coil every 90 days and vac it off if dusty. it is located at the front of the machine behind that panel at the bottom 4 1/4 inch cap screws to remove it it is tricky to get off and on because of the lower hinge but you can do it. many other things can slow down production.
Posted on Apr 23, 2008
  • 145 Answers
If it's makes a good slab of ice the only reason it would melt would be a drain blockage holding water in the bottom of the unit or the water pan overflowing into the bin when it fills up. If you check the slab when it falls on the cutter and see a hollow looking spot in the middle you may have an evapoator leak. Yhis would require a service tech to repair.
My maytag MFI2569YEB ice cubes are melting around the coil in the tray. What could be wrong?
if you are talking about the bucket the cubes go into, most likely you do not use a lot of ice. the ice isn't melting, it's evaporating. usually winds up in a big clump at the bottom.
Oct 31, 2013 | Maytag Freezers
My ice cream is melting and things have started to thaw
Turn the t'stat up to 9. You want to save the meat and ice cream. It sounds like you may be losing freon. Get it looked at soon so you won't come home and find meat soft and ice milk.
Mar 06, 2013 | Whirlpool EV160NZTQ Upright Freezers
Blue Ice cube maker only make 4 instead of 12 cubes ?
It may just need a cleaning. Use approved cleaner for this modle and sanitize the bin after the cleaning. If it is making some ice, most likely there is not an issue with the charge.
Jan 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Ge frezzer goes into defrost mode and defrosts EVERYTHING! Ice cubes refreeze solid as one. HELP!
sounds like your defrost termination switch is not cuttin off heater when ice on evap melts.switch is surpose to cut off heater when it reaches a certain temp. replace defrost termination switch
Aug 27, 2009 | Freezers
Water leaking onto ice and outside panel on Hoshizaki KM-500MAE
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
Feb 12, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Ice builds up kitchenaid superba icemaker kuis18nnjx4
Hi.
Sorry to have taken so long to respond to your post
Unfortunately I am not a refrigeration expert, so am not able to help you with your prob.
Find an expert on freezers, there are plenty to choose from.
Once again , sorry I cannot help you.
Jan 08, 2009 | Freezers
Ice Machine FIM600 Ice is making too big
remove front cover to view control panel. there is a cube size adjustment there. use a small screwdriver and turn it counterclockwise to make the cubes smaller
Jan 07, 2009 | Franklin Freezer Chef FIM70 Commercial Ice...
Ice cube shape
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Oct 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Freezers Logo
96 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
