Question about Miele WT945 Front Load Washer / Dryer
Clothes not drying - fan ok, heat ok
I tried pushing in the little square switch (it clicked), but no luck.
The dryer is working visually; the fan's spinning, the square metal box on top of the drum is hot - but clothes do not dry.
Any ideas? - would be greatly appreciated!!
  • Andree1 May 03, 2008
    we have the same problem. Miele WT945 is washing and heating up. but the drying cycle just doesn't dry.
    Need to find a technical manual for repairs. I suspect the heating element is failing.
    Any solutions would be greatly appreciated.
    Andree
  • gbmsgb Sep 12, 2008
    We have exactly the same problem - fan ok, heater ok - close don't dry.
    Any luck finding a tecnical manual?
I just had a Miele tech fix this. There are several causes for this. One cause is a motor fault with the fan motor or a bad belt. Second issue is a blocked up condenser. Finally the issue is electronic and the electronic panel needs to be replaced. The electronic panel consists of small relays that can burn out.
My issue was the electronic panel.
To test a blocked up condenser, is to take the top panel off, and spin the fan motor (by hand). If you feel resistance, you have a clogged condenser which must be replaced (Always run 'Remove Fluff' cycle so this never happens after every dryer use).
To test the fan, take the connector off and 'carefully' connect to 220v to the fan motor (checking polarity). Only do this, after you reset the switch (found in the rectangle box in the middle of the Miele metalwork on top) and made sure the fan does not work automatically when a drying cycle is selected.
The most expensive repair is the eectronic module which costs £175 plus £99 Miele callout.
Posted on Aug 29, 2008
  • mariusz_godz
    mariusz_godz Mar 03, 2013
    Ji Merouby, would You please describe where the electeric module was located ?
  • merouby Mar 03, 2013
    Electronic module is right behind the front switches
Dryer was working when I left, came home clothes were dry, but now will not restart. Pushing start button does nothing. Light is on in tub when I open door.
this sure has all the suspicions that it's the thermal safety switch , (1) it worked on last load
(2) nothing happens when start is pushed
( 3) tub light works ok
both gas and electric models have one , and they both do go bad , the switch is mounted usually at top of air outlet tunnel on back of dryer , some do have reset buttons , but rarely do they trip for false reasons , something musta happened to cause a high heat build up in dryer ,Lint build-up is most common reason I can think of
May 18, 2015 | Dryers
Not drying efficiently. Air moving ok, heat appears to be ok. Would like to open it up to visually inspect it. With event off slight burning smell. Would like to verify clean of lint.
If it tumbles and it heats up but your clothes don' t dry disconnect the vent tube from the the wall and run a load of wet clothes if they dry then your homes venting is clogged and if it still does not dry then it could be your thermal fuse.
Mar 30, 2014 | GE Dryers
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
My hotpoint BWD129 , dryer does not work clothes are barely warm
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Washing Machines
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
Dryer won't heat...replaced heating unit...and still no heat...dryer is eletric...dryer still runs...just no heat
Visually inspect the heating element, burner operation, ignitor, thermal fuse.
Make sure there is nothing blocking the front of the dryer. Air flow is key to efficient drying. Make sure the dryer settings are appropriate for the clothes you want to dry. The timer selection, fabric selection, and the temperature selection all play important roles in proper dryer operation.
Good Luck and have a nice dayRating the solution is highly appreciated
Jun 29, 2010 | Roper RES7646KQ Electric Dryer
Dryer has heat in back but cloths won't dry.
Howdy: Some models have a little fan that blows the hot air into the drum. I do not know what model you have but I would start there. Sorry - Good luck - Doug
Dec 09, 2009 | Maytag Dryers
Dryer not drying clothes
Check your heating element your lint trap and your exhaust hose.
You can check the element by opening the door pushing in on the switch and turn it on,you will feel or see the heat.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 18, 2009 | Maytag Performa PAV2200
Clothes Dryer not drying
Hello, check to make sure that the dryer is venting properly, is the hot air getting out of the vent ?. If not clear the restriction or unkink the vent then try again. good luck
Dec 16, 2008 | Hotpoint NVL333EY Electric Dryer
Intermittant heat for drier
check for flow of air through the dryer arts as it sounds like the clicking is the thermal cut out activating, this prevents the dryer from overheating, the common cause for overheating is blockage (no air flow) or the fan that blows the air round the machine is not working, or not working properly, so check the fan see if its turning etc hope i have helped, if so please rate me
Oct 03, 2007 | Dryers
Miele WT945 Front Load Washer / Dryer Logo
491 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
