Check for kinked vent or vent obstruction
youcan remove the vent from the machine and dry a load of clothes
it it dryes in the proper lenght of time the vent is the problem
DISCONNECT THE EXHAUST FROM THE BACK OF THE DRYER. RUN ONE LOAD OF LAUNDRY. IF THE LOAD DRIES O.K., THE EXHAUST DUCT IS RESTRICTED. CLEAN OUT THE DUCT WORK. IF IT IS FLEXIBLE MATERIAL, REPLACE WITH RIGID METAL DUCT WORK.
SOURCE: dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
SOURCE: electric dryer tumbles but does
Heating element has gone bad. You need to unplug unit. remove back, then find heating element and remove it. Look for what looks like broken springs, if found replace element. 99% of electric dryers not drying are the heating element. Cost around $50
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
AFTER DRYER SHUT OFF AND THE CLOTHES IS STILL DAMP AND RERUN SECOND AND SOMETIME THIRD TIME TO DRY IT
