TX-DS555 Audio Video Control Receiver
When I turn my receiver on it powers up and after approximately 30 seconds it will show protect and then turn off. Is there something I need to do to make it function?
sneben@sbcglobal.net
    Sergeant:
    Champion:
  • 319 Answers
Get it serviced. It apparently has a circuit problem
Posted on May 08, 2008
Onyko tx nr616 receiver keeps shutting off. Only stays on for approximately 3 seconds. Can you help?
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 30, 2014 | Onkyo Tx-nr616 7.2 Thx Certified Network...
Want to purchase a blue ray player. is there one that is compatable, and easy to hookup. I have an onkyo txds 555 reciever and and old apex tv. Want to up grade to a blue ray player( ill get the hd tv...
All of them will work just fine audio-wise with the Onkyo and on some level just about any TV made in the last 20 years if it has s-video, composite video, component video or HDMI video inputs (google them).
Choose one and follow the manuals for connection.
Here's yours...
http://www.retrevo.com/support/Onkyo-TX-DS555-Receivers-manual/id/365dj180/t/2/
Keep in mind that no video must necessarily pass from the the BluRay to the receiver but it MUST find its way to the TV. It's best to have any audio or video signal go directly to the best electronics that handles it. That's one reason they can be routed separately.
Sep 20, 2011 | Onkyo TX-DS555 Receiver
Ds-555 will come on but no sound, as well as the rec out will not go off.
There's a huge clue there. DE-SELECT the record out
Carefully examine the front panel for other clues.
Look for Speakers NOT enabled, Muting ON, a Tape or other input like MULTI-CH Input inadvertantly selected.
Register and download the manual for free at retrevo.com
Feb 26, 2011 | Onkyo TX-DS555 Receiver
My onkyo receiver wont play music loud, I can turn it all the way up and faintly hear some music, how can I fix this? The speakers are hooked up, but there is no sound, the receiver model is txsv373...
The most common cause of this is having the unit with the tape monitorswitch turned on. Check that first. If that is not the problem, the next likely problem is in the power supply. The output section is missing its main voltage. This will require professional assistance.
Please try the tape monitor first and update this with the results.
Dan
Aug 25, 2010 | Onkyo TX-DS555 Receiver
Onkyo TX-DS555 will not switch to Dolby Digital
regulated voltage to the processor circuit like drop in these onkyo after 8 years. This or a small capacitor fails in this voltage line.
Jul 16, 2009 | Onkyo TX-DS555 Receiver
Onkyo TX-SR606 Reciever - 20 sec after power on, screen is green
The HDMI version in your receiver is 1.1 or 1.2 which will not pass video as it should. It's not Onkyo's firmware at issue, it's HDMI and in all receivers up to 2008 model year this is a very heated problem! The only fix is to run FIOS directly to the TV via HDMI and run it's audio to your receiver with Digital Coaxial or Optical. Hope this helps
Jun 11, 2009 | Onkyo TX-SR605 Receiver
Onkyo TX-DX838
I went back and found a loose cable/coax. Re-attached and now the receiver works as good as ever.
Sep 02, 2008 | Onkyo TX-DS838 Receiver
Onkyo Tx-v940 Receiver/Amplifier Protection Mode
Audio amplifier IC's damaged you need to change it.Good luck
Dec 31, 2006 | Onkyo TX-V940 Receiver
54 people viewed this question
 Grubhead
Grubhead
