Question about Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
Exploding bulb! I replaced the bulb according to specs and when I connected the power supply it exploded, taking out the projector with it.
  • N7JU Jun 19, 2008
    Where is the fuse? Same deal...
  • 563 Answers
Hi Bedlam
This could have been a faulty lamp , or if it wasn't a original - in other words a Utopia lamp - that the wattage wasn't right.
Contact the supplier and tell them that the lamp blew as soon as you replaced it. The lamp should have a 30 day warranty on it.
As for the Projector , in such cases it is normally only the fuse on the Powersupply that has blown. Replace the fuse and see what happens.
If you still struggle , drop me a posting and I'll get back to you ASAP.
Good luck and thanks for using Fixya !
Posted on Apr 23, 2008
Lg power supply
Do an internet search for lg power supply for LG37H30 replace the entire power supply! (because the damage may have caused other bad coponents do to that one ic exploding avoid a headache replace the entire power supply and start watching TV again.
Jan 21, 2013 | LG 37LH30 37 in. LCD HDTV
Loud bang from system.Unit starts immediately power is supplied.Power switch does nothing.H/Drive and players run.No video ( card OK ) checked with another card. Can the problem be motherboard?
The load bang is most like an exploding capacitor in the switch mode power supply, especially if there is a burnt electrical smell from the power supply.
I suggest you borrow a switch mode power supply, remove the old power supply and install the replacement power supply. make sure it has the same or larger wattage unit.
If the computer still does not boot up then the exploding power supply has damaged the motherboard, and you need to replace then motherboard too. This may not be a cost effective solution.
This is an opportunity to get a new and better computer.
May 16, 2011 | Computers & Internet
Panasonic PT-60LCX64. What would happen if you
you won't get another warning for 2000 more hours on a lamp that is good for only 2000 hours (give or take). so, if you don't replace it, you run the risk of the lamp exploding at the end of it's life, sending shards of glass and mercury dust throughout the projector.
Nov 09, 2009 | Mitsubishi VLT-XL2LP Projector Lamp for...
TURN PROJECTOR ON. FAN TURNS ON NO LAMP, RED SATUS LIGHT COMES ON
Bulb timer has expired. Press the left arrow, right arrow and power switch simultaneously for a few seconds. The projector should power up, but this indicates that a new bulb is required and should be fitted as soon as possible, as there is a risk of the old bulb exploding.
Sep 15, 2009 | Office Equipment & Supplies
My Sharp XR-40X DLP Projector bulb will not start. The bulb is not near the end of it's projected life nor did I get the "Replace Bulb" warning indicator. It has power and the fan comes on.
Hi Just be aware that the stated lamp projector specs "2000 hour lamp" does not mean you will get 2000 hours. What it means is that the lamp is rated to deliver up to 2000 hours. So some might get 1000 hrs, others 1593 hours etc.
The lamp may have died of its own accord prematurely and obviously unexpected.
With the power and fan coming on my first throughts are either the lamp or the lamp ballast (powers the lamp).
If you need a lamp we are able to supply replacement lamp delivered next time you need one, as we ship internationally and also the same with our revolutionary ICE Digital Daytime projection screens. Cost $US337 with lamp housing or lamp only $270. includes freight. Excludes any import taxes. http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd New Zealand http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Jun 21, 2009 | Sharp XR-40X Projector
Exploding Bulb
remove the top of the projector (remove the 6 screws on the bottom and the top 2 screws on the back), use canned air, and blow every piece of dust out of every nook and cranny. also, don't get cheap lamps from "bob's house o' lamps". get the AN-XR10XLP/1 from a sharp dealer to get the full life out of a lamp. also, make sure the vents on the projector are not blocked when you use it.
Mar 20, 2009 | Sharp XR-10X Multimedia Projector
The lamp exlpoded
I assume you have fitted a new projector lamp. If you have then I think the problem will be in the power supply, transformer. In part one clue might be the age of the lamp in terms of identifying the reason of the lamp exploding. Regards Kevin Andreassend ICE AV Technology Ltd http://www.iceav.co.nz. iceavtech@gmail.com
Nov 01, 2008 | BenQ MP610 Multimedia Projector
Eiki lc4300 projector
check to make sure your lamp is completely in and connected properly, and the lamp door is closed completely, if still no light, pull the lamp out and make sure it is not broken from transporting it or handeling it.
Making sure you do not touch and glass portion of the lamp or surroundings. only touch plastic or "metal using clean dry paper towel for metal contact" as skin oil can destroy a lamp.
"If this dosen't help please reply for more help before marking a bad suggestion, thanks"
May 08, 2008 | Office Equipment & Supplies
Christie lamp explodes
the lamp VIP300w, with Hg
the lamp have the chance to explode,if the lamp used over 2200 hours
you can replace the lamp when it is about 2000 hours
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Dec 10, 2007 | Christie Office Equipment & Supplies
131 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
